06-08-2022, 05:58 AM | #1 |
Rep 97
Most common S55 / M2Comp issues
Hey all,
New owner of a 2020 M2 Comp with 20k miles on it. I am still within warranty & wanted to know what the most common issues either: A. on this platform B. at this mileage Obviously still being within warranty - i want to go to the dealer at the slightest inclination one of these issues may be starting to appear, either minimally or more obviously. Thanks! |
06-08-2022, 01:09 PM | #2 |
846
Rep 1,962
Well, if you read this - or other forums covering the M2 - you should expect:
- the crankshaft pulley to spin the first time you downshift - the engine management to have been coded or tuned such that the warranty is already Void - the amplifier in the boot to be full of water (and therefore defunct) following the valeting the dealership gave the car prior to sale - the front wheels to have been scored by stones trapped between the brake calliper and the wheel such that they are on the point of splitting in two - the exhaust to have been cut up and then patched to 'make it sound better' - the oil drain plugs on engine, transmission and differential to be cross-threaded through multiple changes between scheduled services by previous owners - the oil/fluid to be something other than what BMW recommend as the people doing the changes above spoke to someone who said that there were better products available and they happened to have some going for less than BMWs (or the recommended manufacturers) price - the instrument cluster to be extensively scratched by overzealous scrubbing with less than totally lint-free cleaning cloths by either obsessive previous owners or dealership valeting staff - the rear springs to snap while the car is parked and finally: - some of the many cleaning products previously used on the car may have had an adverse effect on the surfaces they were being used on. Welcome to M2 ownership and (one of the) online forums for owners - try not to worry and focus on enjoying the car as something to be driven. Last edited by M Fifty; 06-09-2022 at 12:29 PM.. |
9
KPM2C139.50 Fred Conoway365.00 No_curebimmer637.50 rogeroger73.00 RideM317.00 bentom2335.50 allinon724929.50 thegrinchboy62.00 KevinM2935.50 |
06-09-2022, 07:17 PM | #3 | |
Rep 170
PHX102160.50 |
06-15-2022, 11:01 PM | #6 |
Rep 7,438
No not just UOA's, but the oil chemistry itself, aftermarket oils that you can find at walmart like PPE/QSE 5w40, castrol edge 0w40 and 0w30 are fantastic oil with incredible base stocks and additives that will blow away bmw's oil and other botique fancy oils. There is one exception though, BMW's old shell made LL01 TPT 5w30 was amazing oil to the point where you were on the level of aftermarket oil. Bmw's LL01FE oils absolutely suck imo, they're more optimized for fuel economy rather than protection.
06-28-2022, 12:41 PM | #8 | |
Rep 129
-Left and Right rear turn signal spontaneously malfunction which has no solution. Often dealership will replace tail lights. Not to discourage you from owning the car, I still very much enjoy mine and have grown to enjoy it as a daily driver. My gauge cluster was already scratched by previous owner but it doesn't bother me. I've had the HK amp replaced under warranty although I'm still concerned since I bought a MatchUp 7 Amp. Rear turn signal error comes and goes. Even after all of that, still love the car. |
