01-04-2024, 05:49 PM | #112 |
Rep 1,393
01-10-2024, 01:14 PM | #115 |
Rep 1
Hi,
First of all, sick build! Really like how you make everything work. I’m about to order the m2 csr wheels (same as you) and was curious about the fitment. On the m2 cs racing they use a 40+mm spacer and you only need half the spacer. Is it because you have the gts knuckle? I don’t mind running spacers but 40+mm seems alot. |
01-10-2024, 01:39 PM | #116 | |
Rep 1,393
Depending on what suspension you have you can go with 25mm spacer, with gts knuckles I can run without spacers. |
01-12-2024, 02:20 PM | #117 |
Rep 1,393
A few days ago this happened, the stabilizer link support broke, the link was also bent... I wrote an email to KW and I have no response, they are not serious... I decided to make the supports in 7075 aluminum, along with hexagonal endlinks, and I also made the parts where the uniball heads are attached in stainless steel to prevent rust.
New parts Anodized Mounted The cooling ducts also broke... New ones mounted After a wash with reload application |
01-12-2024, 02:58 PM | #118 |
///M Powered for Life
11505
Rep 10,338
Shameful to see the KW suspension break like that! How surprising to see that failure
01-12-2024, 03:30 PM | #119 |
Rep 3,608
Looks like your end link was in bind - I had this issue all 2023. Snapped some rod ends and even sheared off the sway bar tab on my strut. More to do with where the sway bar tab on the strut sits relative to the connection to the sway bar itself. I had to use spacers and a softer position on my bar to correct the geometry.
Current: F80
Prior: F82, F32 |
01-12-2024, 03:47 PM | #120 | ||
Rep 1,393
You will have to bring me a 3-way set in summer Quote:
I also have it in soft position, I hope it doesn't happen again... Last edited by Track/S; 01-12-2024 at 03:57 PM.. |
SYT_Shadow11504.50 |
01-12-2024, 04:16 PM | #121 | |
Rep 3,608
Current: F80
Prior: F82, F32 |
01-12-2024, 04:28 PM | #122 | |
Rep 1,393
I have steering stoppers, don't have much turn, with full wheel turned I can move the tie rod a little by the hand. I use gt4 rod ends. |
01-12-2024, 05:56 PM | #124 | |
Rep 3,608
These links are just examples, *if* you do go this route, you will want to source some from a manufacturer/supplier you trust (possibly the manufacturer of the GT4 ends?): https://www.qa1.net/automotive/rod-e.../pc-pcy-series https://www.pegasusautoracing.com/pr...p?Product=3064
Current: F80
Prior: F82, F32 |
01-13-2024, 12:38 AM | #125 | |
Rep 1,393
RugbyBro Full turn GIF Last edited by Track/S; 01-14-2024 at 02:08 PM.. |
01-15-2024, 04:45 PM | #126 |
Rep 1,393
01-16-2024, 02:09 PM | #127 |
Rep 1,393
chris7197378.50 D_SheerDrivingPleasure1100.00 |
01-16-2024, 02:11 PM | #128 |
11505
Rep 10,338
The arch trim, it this something BMW offers? For M3/4/2?
Kevin_The_Clean13385.50 |
01-16-2024, 02:25 PM | #129 |
Rep 1,393
01-30-2024, 03:13 PM | #130 |
Rep 1,393
SilverLakeM3242.50 chris7197378.50 |
