01-03-2023, 10:09 AM | #23 |
Rep 278
I am installing my Remus Sport right now and the hangars that came with it will NOT go into my factory red hangars. I tried oil, other lubricants and c-clamps/similar to push it through and it is damaging the rubber hangar. I’m keeping the stock chassis barbs since there is just no way they are going to go in. I’ve seen multiple videos where the stock hangars were used but don’t know why I haven’t seen more about people not being able to use the once’s that come with the kid. Wondering if they are the wrong ones?
2020 M2 CS - Misano Blue, DCT, CCB
01-03-2023, 10:56 AM | #24 | |
Rep 47
https://www.amazon.com/Lisle-38350-E.../dp/B0012S9A5U |
01-03-2023, 11:01 AM | #25 |
Rep 278
Might try these but it seemed as though it just wasn’t going to fit regardless.
01-05-2023, 07:31 PM | #26 | |
Rep 237
I have the Remus Race though, didn't you have the Race and swapped to the Meisterschaft GT? Are you going for the Resonated EL + Remus Sport combo now?
2021 BMW M2C / AA / Remus / KW
01-05-2023, 07:34 PM | #27 | |
Rep 278
01-05-2023, 07:42 PM | #28 | |
Rep 278
01-05-2023, 08:47 PM | #29 | |
Rep 237
To be clear I used a table vise- maybe it gave me more leverage than a clamp, and I had most trouble getting the Remus bracket on the red rubber mount- the rubber mount to the remus exhaust was relatively easy. I had to tighten down turn by turn while making sure the "pin" on the bracket was aligned straight into the rubber mount, while feeding lube inside.I had a piece from inside the hole push out from inside, sort of deforming the rubber mount and possibly tearing inside somewhat, but I just pushed through and once the pin was out, it kind of went back inside the hole. I also considered the AA resonated EL with the Remus Sport! Just decided to stick with the Race but you might make me change my mind!
01-05-2023, 08:50 PM | #30 | |
Rep 278
drp087233.00 |
03-26-2023, 05:02 AM | #31 |
Rep 278
Well, I got my exhaust on, FINALLY. I had the same issue with the rear section hangers being backwards. Once fixing that and playing with clearances on the mid-pipe and under the rear lower control arms, I’m finally happy with it and breaking it in to enjoy the new sound!
4
