08-18-2019, 12:48 AM | #1 |
Rep 18
Off-center steering wheel
Hi folks, I recently started to feel my M2 steering was off center a bit after engine oil change service. (not sure whether it exists for long time or any operation during engine oil change may cause it) I never had accident on it or hit curb or anything. I want to see if other BMW 2018 M2 owners share same experience or have a lesson to give.
When my car is going straight on flat road, I can do hands-off and the car can continues going straight without being pulled to one side itself. The only problem is when the car goes straight, I feel the steering wheel is not at center (the 12 o'clock position is slightly turned clockwisely by 1 to 2 degrees, which was confirmed by a BMW service foreman after driving it). Since the off-center position did cause some uncomfort on me, I brought it in for four wheel alignment today according to BMW foreman's advice. However, after the fix, the steering position is the same (I cannot feel difference). Then I read the alignment report, to see actually there was no problem with it. Data before fix were very close to targets. I suspect BMW service did not find real problem and just sold four wheel alignment to me. I want to ask if the slight off-center steering wheel is as designed for M2 or my M2 has problems other than problems which can be fixed after four wheel alignment. Thanks |
08-18-2019, 03:43 AM | #2 |
Rep 396
It's actually quite easy to fix it yourself if you are mildly mechanically capable. With the steering wheel pointing straight, your car will steer slightly left. You just need to adjust the steering tie rods to point BOTH front wheels slightly to the right by the same amount. Provided you make one rod longer and the other shorter by the same amount, the toe setting will not change, nor will the geometric driving axis (thrust angle).
Start with half a turn on each tie-rod, take it for a drive then adjust again if need be. There is a lock nut on each tie rod (a torx socket if I recall) and the rods themselves are lengthened or shortened by a conventional crescent wrench. You don't even need a jack - although it helps if you raise the front of the car a little. |
08-18-2019, 12:40 PM | #3 | |
Rep 18
I have a follow-up question. Do you think adjusting the steering tie rods is included in four wheel alignment? In your reply, it sounds adjusting tie rods will not change data in the form, so I suspect it isn't included. Since I paid for BMW service, I want to know whether they are totally off from doing right thing. |
08-18-2019, 04:09 PM | #4 | |
Rep 1,899
I would take it to a performance alignment shop but that's just me |
08-18-2019, 04:20 PM | #5 | |
Rep 18
Thanks |
08-18-2019, 04:24 PM | #6 | ||
Rep 1,899
08-18-2019, 07:00 PM | #7 |
Rep 18
That's awesome! thank you. I will call them for an appointment.
nioh_lbbm21716.50 |
08-18-2019, 07:37 PM | #8 |
Rep 396
Looking at your alignment sheet, the only thing they obviously adjusted was to add a little more toe on the rear axle. That was an appropriate correction and the rear axle alignment is very good.
It is possible they may have slightly reduced toe on the left front wheel to bring it from 0.08' to 0.05' but since it was already reading within limits on the pre-measurement, most techs are too lazy to bother. The small difference probably falls within the margin of error of the machine rather than an actual alignment change. On the other hand, if they did tweak it slightly, this would result in a slight left turning vector which could be responsible for the steering misalignment your are now experiencing. The bottom line, as another poster has said, is the steering wheel needs to be correctly centred when the car is driven into the alignment machine and the car should also be test driven when it comes off to make sure the job is done properly. Modern cars have all sorts of controls on the steering wheel and customers are very sensitive to misalignment. It's not like the old days with nothing on the wheel that would upset your feng shui ;-) |
08-18-2019, 10:28 PM | #9 | |
Rep 18
Thanks for your reply. |
08-18-2019, 10:51 PM | #10 |
Rep 396
LOL clearly I know nothing about Feng shui. I apologise if the comment was inappropriate.
08-19-2019, 01:21 AM | #11 |
Rep 18
07-14-2020, 05:40 PM | #12 |
Rep 23
