08-09-2019, 05:08 AM | #1 |
Rep 7
Suspension that does not drop ride height
Hello From India
I have a 2019 M2C and drive on broken tarmac roads here in India and the roads here also have hude speed breakers. The stock ride height is just about OK on 80% of the speed breakers here. I am looking to get a suspension system that does not drop the ride height at all. Any suggestions. I deal would be something line KW DCC but they drop the ride height by 20mm. |
08-09-2019, 11:33 AM | #2 |
844
Rep 1,962
If you fit the reinforcement rings between the strut tops and the body, that will give you another 15mm at the front. A similar approach at the back should give you the clearance you need.
08-09-2019, 12:17 PM | #3 | |
Rep 385
08-11-2019, 07:11 AM | #4 |
Rep 4,515
M50 - which reinforcement rings are you referring to ?
Current '22 X3M LCI.. |
08-11-2019, 07:19 AM | #5 | |
Rep 4,515
https://www.bimmerpost.com/forums/sh...php?p=22819157
