07-04-2019, 03:29 AM | #1 |
Rep 117
F87 Harman Kardon
Been quite unhappy with the speakers in my car. Compared to my previous 340i which also had Harman Kardon speakers the sound is much lower in my M2. On the 340i I could have the volume up to 40% and it would be pretty loud. In my M2 on the other hand I usually put it up to 50% and that would be like having it at 20-25% in my previous 340i. Ive asked some other people and for them the sound is pretty low on the M2 as well. To my question, how much can I safely turn the volume up to not overload and blast the speakers?
07-04-2019, 06:24 AM | #3 | |
Rep 1,608
Boostm3
coldM250.50 |
07-04-2019, 08:31 AM | #5 |
Rep 6,917
Drives: 2018 M2 AW DCT
Get rid of ASD. Code it out or use the bypass harness.
07-04-2019, 09:02 AM | #7 | |
Rep 3,003
07-04-2019, 02:07 PM | #8 |
Rep 643
Low means turn it up. Might as well use the entire volume range. Just because it’s not as loud at same volume level doesn’t make it poor.
I find much different results depending on source. CarPlay is very quiet vs Sirius. Also. Use the tone controls and turn up the treble. |
07-04-2019, 07:49 PM | #10 |
Rep 1,608
Someone, move this to the audio section of the M2 technical forum.
Boostm3
Thescout134944.00 |
07-04-2019, 10:57 PM | #11 |
Rep 3,888
BMW's changes which transform the 2-series into an M2 don't include anything related to audio or any entertainment electronics for that matter. It's a shame we all can't just use a common 2-series "Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics" forum for this topic as you'd have more visibility and discussion.
coldM250.50 |
07-05-2019, 02:41 AM | #12 |
Rep 117
Well, the volume loudness is pretty much the same in bluetooth mode or connected via USB port. I would very much like to turn the volume up close to maximum but I would not want to blow the speakers.. Compared to the 3-series H/K with "standard audio settings" the loudness is just waay too low..
07-05-2019, 09:05 AM | #13 |
Rep 2,956
It is the first car I can remember where you have to turn the volume to 3/4 to overcome road noise and it's not because the car is overly noisy.
07-07-2019, 01:20 AM | #15 |
Rep 3,225
07-08-2019, 02:20 AM | #16 |
Rep 117
07-08-2019, 07:51 AM | #17 |
756
Rep 2,149
2-series has a different amp than the 3-series. 2er is 360 watts and 3er is 600w. Also 2 series is missing 4 speakers that the 3 series has in it's rear doors. Other than that, they appear to be the same... I checked part numbers on realoem.com as well.
https://www.harmankardon.com/bmw-2-series-coupe.html https://www.harmankardon.com/bmw-3-series-sedan.html Can you swap in the 600w amp into the m2? Would it be cheaper/better to go third party? I don't know. Someone else would have to answer that. Audio is my worst subject. |
coldM250.50 |
07-11-2019, 02:22 PM | #19 |
Rep 120
07-11-2019, 02:49 PM | #20 |
Doc Brown
1176
Rep 2,174
Not Much more info that I can give, but check out the links. It was actually the bimmer-tech amp not the Bav Sound, sorry. It is a direct plug and play from the original HK amp in the trunk. I got a great deal on it from a forum member who was selling his car. But here is a link:
https://www.bimmer-tech.net/speakers...ifier-for-bmw/ and here is the BavSound for comparison https://www.bavsound.com/BMW-Amplifier-Upgrade
07-11-2019, 03:10 PM | #21 | |
Rep 1,899
07-11-2019, 04:50 PM | #22 | |
Rep 780
1 - upgrade to the matchBMW amp. 2 - replace all the front speaker except the middle one. 3 - Tune the amp to hardly use the middle speaker 4 - Replace the underseat subs with the 2 ohm earthquake subs ( these are not perfect but with 160 watts from that amp they go way lower than stock. 5 - If you want to drop another grand trunk sub and additional amp. Hope this helps.
