M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 2018 M2 Manual Service Intervals
      07-01-2019, 08:20 PM   #1
jclaib7
jclaib7's Avatar
142
Drives: 2018 M2 Black Shadow Edition
Is there a good document that shows the service intervals? Not the mileage intervals but the exact services that are required at intervals up to 50,000 miles or more?
Audi had a nice one. See below.
Service intervals in miles 5,000 miles1 Standard Maintenance Service with tire rotation 15,000 miles2 Major Maintenance Service with additional items 25,000 miles Standard Maintenance Service 35,000 miles Major Maintenance Service with additional items 45,000 miles Standard Maintenance Service 55,000 miles Major Maintenance Service with additional items 65,000 miles Standard Maintenance Service 75,000 miles Major Maintenance Service with additional items 85,000 miles Standard Maintenance Service 95,000 miles Major Maintenance Service with additional items 105,000 miles Standard Maintenance Service 110,000 miles Timing Belt Replacement (Audi TTS only) 115,000 miles Major Maintenance Service with additional items 125,000 miles Standard Maintenance Service with additional item 130,000 miles Timing Belt Replacement (2.0L TDI and Audi A3 e-tron only) 135,000 miles Major Maintenance Service with additional items 145,000 miles Standard Maintenance Service 155,000 miles Major Maintenance Service with additional items
1) First standard maintenance service at 5,000 miles or 1 year after delivery, whichever occurs first. Standard maintenance services thereafter occur at intervals of 10,000 miles or 1 year after the last standard maintenance service, whichever occurs first. 2) First major maintenance service at 15,000 miles or 2 years after delivery, whichever occurs first. Major maintenance services thereafter occur at intervals of 20,000 miles or 2 years after the last major maintenance service, whichever occurs first.
The intervals shown in this table are based on vehicles operating under normal conditions. In case of severe conditions, such as extremely low temperatures, excessive dust, etc., it is necessary for certain operations to be carried out in between the given intervals. This applies particularly to engine oil changes and the cleaning or replacing of the air cleaner filter element.
Time-Sensitive Maintenance Items Service interval by time (and mileage where applicable)
Maintenance item
Every 2 years regardless of mileage Replace brake fluid (all vehicles) Every 2 years regardless of mileage Check cloth top function and rollover protection with cloth top down (Audi A5 Cabriolet, S5 Cabriolet, R8 Spyder only) Every 2 years regardless of mileage Crash active headrest - Check function (Audi A8 only) Every 3 years regardless of mileage Haldex clutch - replace oil (Audi A3, Q3, Audi TT & TTS only) Every 4 years regardless of mileage AdBlue® Fluid - Replace only if AdBlue has not been filled within the last 4 years (Audi A6 3.0L TDI, A7 3.0L TDI, A8 3.0L TDI, Audi Q5 3.0L TDI, Audi Q7 3.0L TDI only)
10/27/20152
Standard Maintenance Service First at 5,000 miles or 1 year after delivery, whichever occurs first. Thereafter, every 10,000 miles or one year, whichever occurs first. ‰ AdBlue fluid – Fill completely with fresh fluid (maximum capacity: 24 liters) ‰ Brake system - Check for damage and leaks, thickness of pads, and brake fluid level ‰ Brake system - Check that the vent caps are mounted on calipers and check the condition of the brake hoses ‰ Cooling system for electrical components: Check coolant level according to description in ElsaPro (Audi A3 e-tron only) ‰ Engine oil / Oil filter - Change oil and replace filter ‰ Engine compartment - Check for leaks ‰ On-board diagnosis - Check (flex fuel vehicles only) ‰ Service reminder indicator display - Reset display ‰ Tires and spare wheel - Check for wear and damage. Check tire pressure. Reset Tire Pressure Monitoring System (TPMS) ‰ Water separator in fuel filter: Remove water (Audi A3 TDI and Q7 TDI models) ‰ Windshield washer and headlight washing system - Add fluid if necessary. Check adjustment and function ‰ Wiper blades - Check condition and replace if necessary
Additional item at 5,000 miles or 1 year after delivery, whichever occurs first. ‰ Rotate tires. Reset TPMS
      07-02-2019, 03:08 PM   #2
Tano
Tano's Avatar
Hungary
375
You can use this one.
      10-21-2020, 11:31 PM   #3
SebsM2
SebsM2's Avatar
652
Drives: 2017 LBB M2
Do you have a new link you could recommend?
Instagram: SebsM2
Build thread: A Tastefully Modded FBO M2
      10-25-2020, 03:20 PM   #4
Tano
Tano's Avatar
Hungary
375
Unfortunately not online. But you can download ISTA-D and you can find everything in the docs section.
      11-03-2020, 09:28 AM   #5
Dalmango
BMW have made it so complicated they don't know themselves:
I enquired twice & got two different answers from different members of staff.
Put it in for it's second service & the service expiration date was different to both of the above answers LOL!
I think their servicing specification is going to cost them a lot of customers in the future.
