06-18-2019, 07:53 PM | #860 | |
Rep 1,190
Then there's the fact that the Cayman and Boxter twins are supposed to stick around until 2024 without a refresh, meaning there's lots of time for more iterations and maybe even a ".3" version. With Boxter/Cayman sales already at a low point, Porsche will HAVE to do something to maintain reasonable sales for the next 5 years. Finally, the GT4 has cylinder deactivation, which I don't think they would include if this engine were purely intended for a single run GT variant. It's more likely a nod to ensure sufficient emissions performance to be used in a higher volume more street oriented 718 in a year or two. Something like a GT4 touring or even the 718.2 S or GTS. Finally, there are a few articles like this out there from earlier this year, as well as some spyshots of boxter/cayman with the exhaust from the GT4 but normal GTS bodywork and suspension. This could be an engine mule, but it's more likely a test car for an upcoming iteration that hasn't been announced yet. That said, the last GT4 has barely depreciated, so yeah, your main point still stands. https://www.automobilemag.com/news/p...er-engine-gts/
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
06-18-2019, 08:04 PM | #861 | |
Rep 1,190
A regular shock absorber is only truly "optimized" for a narrow range of conditions (road surfaces, driver inputs, vehicle speeds, etc.) and everything else is a compromise. Adaptive suspension adjusts the damping level based on what the driver is doing and what the suspension is doing. So if you're driving straight down a rough road, the suspension can be soft for comfort, but when the driver turns the steering wheel the dampers stiffen up for improved response and handling. The different modes determine the priority that the system places on comfort vs. sportiness. Adaptive suspensions are most capable in terms of keeping the body flat in turns and over uneven road surfaces. They are less capable of reacting to small sharp road impacts. Most people think that sport+ means that all the sharp impacts should be stiffer or louder, but that's not typically the case. Usually the main difference will be the abruptness, pitch, and head-toss that the driver feels over undulating uneven roads. Put another way, for an equal amount of body control and roll damping, a passive damper will typically have a far less smooth ride with more abrupt body motions. Sharp impacts or small road events are typically handled by the passive portion of the damper and don't change much (intentionally) between modes. This leads some people to not feel a difference, but in reality they are looking for the wrong thing or not driving on roads where the difference is apparent. The M2CS should be quite good, as it's basically the culmination of all the development that BMW has done on all the F chassis M cars, with the best hardware, in the smallest, lightest package. The adaptive suspension option should alleviate my concerns with ride quality, as that has been the main reason I haven't replaced my F80 with an M2C. A passive suspension as stiff as an M car will not be tolerable on the roads near me.
06-19-2019, 12:10 AM | #862 | |
Rep 13,097
M2: 55 kg increase (3.68% extra):
///M is art ↔ Artemis
Poochie9104.50 |
06-19-2019, 12:44 AM | #863 |
Rep 13,097
There has been a time that VINs of M2 Competition prototypes indicated "M2 CS" as model type. The S55 variant was supposed to be the "M2 CS". But apparently plans were changed due to tightened EU emissions regulations requiring the N55 engine to go extinct: exit N55 - exit "M2 CS" - enter "M2 Competition" - "M2 CS" model type got reserved for the 450hp variant.
4
06-19-2019, 08:04 AM | #864 | |
Rep 6,759
Would you buy a GT3 or GT4 with 50k miles? Knowing it’s seen it all, from potholes and salty roads to the racetrack? You’d have to factor in all the maintenance costs that will hit sooner rather than later, and which are enormous on such a car.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
06-19-2019, 08:49 AM | #866 |
Rep 3,297
Bring it
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
BLACK OPS109.00 |
06-19-2019, 10:10 AM | #867 | |
4972
Rep 10,200
But I get your point - where is all the extra weight coming from???
docalex139.00 |
06-19-2019, 10:49 AM | #868 | ||
Rep 6,635
Brake_Late1937.50 |
06-19-2019, 11:53 AM | #869 |
Rep 4,667
No one seems to be mentioning it, but something looks odd about the rear quarter panels. I'm wondering if there are brake cooling vents built into the quarter panels. I first thought it was allusion from camo, but it doesn't look right.
Brake_Late1937.50 |
06-19-2019, 12:41 PM | #870 | ||
Rep 1,369
I plan to drive my vehicle on road trips, may be more sensible with the M2CS.
IG: @rise_n_drive
Sedan_Clan25040.00 |
06-19-2019, 01:31 PM | #871 |
Rep 2,349
I like the plate Mine is BMW001, might see you around!
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
mikeahso411.50 |
06-19-2019, 03:50 PM | #872 | |
4143
Rep 6,926
M2cs will add PDK-$2900(or manual as a no cost option). Using some M2c config prices to estimate fully loaded M2cs. $58,900 +35% cs premium, +$550 met paint, +$1200 exec, +$8150 ceramic brakes, +$2900 pdk = $92,315 Last edited by hellrotm; 06-19-2019 at 04:12 PM.. |
06-19-2019, 04:24 PM | #873 | |
4143
Rep 6,926
$99k msrp for GT4 leaves a lot of room between the $80k GTS. There are those Cayman 6 and Boxster 6 rumors. Supposedly this is running around. A base looking 718 Cayman with new GT4 exhaust and a 6 cylinder exhaust note. |
06-19-2019, 10:12 PM | #874 |
Rep 149
Actual weight increase is only ~30kg when comparing apples to apples build. There are new EU regulations (guidelines?) that Porsche is now following. It means listed weight must be an 'average' build somewhere along the lines of what >33% of people will buy. That means the weight likely doesn't include things like CCB, LWBS, radio delete, etc. Andreas Preuninger said this in an interview on the 718 GT4 and provided the 30kg number. So still a weight increase, but not as bad as the numbers suggest.
dmboone254972.00 |
07-02-2019, 08:26 AM | #875 |
Rep 3,714
LOL, no it won't. There was never a 40-50k ADM on the original GT4. Maybe a GT2RS. Markup might be 10-15k tops but I bet you'll be able to get one for MSRP pretty quickly since the specs aren't very good.
07-02-2019, 08:35 AM | #876 |
Rep 1,153
The first GT4 was limited production. Porsche have already said they will make as many GT4 as people want this time around so you would be an idiot to pay a mark up...
2020 M2C 24.04.2020 delivery - Sold 24.08.22
07-02-2019, 11:36 AM | #877 |
Administrator
40801
Rep 21,240
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
07-02-2019, 12:57 PM | #878 |
Rep 3,297
I'm so glad that BMW found a way to off all of the extra parts made for the F8x platform. CCBs,,Seats , S55s, and DCTs for starters.
Good plan at the end of production for F series.
07-02-2019, 01:54 PM | #879 | |
///M
6654
Rep 3,683
Lately I am thinking instead of waiting for G80 I should see if I can find one off this bad boys for track. Not sure if I can get one
Life is too short...enjoy your life
///M |
07-02-2019, 02:22 PM | #880 | |
16305
Rep 8,398
