07-01-2022, 02:00 PM | #23 |
Rep 7,299
07-01-2022, 04:55 PM | #24 |
Rep 3,806
My M Performance carbon spoiler was installed at the port and it's attached with betalink. The biggest giveaway that any part is attached with betalink is
a) it's completely flush with the surface. 3M tape will have a 1/16 gap (width of tape) b) if you get your fingernail on an edge and try to flex it upward, and it doesn't budge, it's likely betalink. 3M tape will flex up and down |
buckybadger1389.00 |
07-01-2022, 05:40 PM | #25 |
Rep 147
@buckybadger I did this 2 months ago. Carefully take the spoiler off. Use 3M adhesive remover and the tape/glue was off in 20min. Then cleaned well. Used 3M adhesive promoter to area marked out with tape to make sure the spoiler goes on perfectly. Then 3M tape on the spoiler. I put it out in the sun for the rest of the day. Was only about 70 degrees at the time. And I can vouch it is on solidly. It doesn't even wiggle.
buckybadger1389.00 IcewaterPete2146.50 |
07-02-2022, 01:27 PM | #26 |
Rep 503
No, I installed the M Performance using the same 3M VHB. I didn’t use Betalink because I wanted it to be easy to remove in case I decided to get a different style.
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2 |
chris7197334.00 |
07-02-2022, 01:35 PM | #27 |
Rep 7,299
Ah, mine was ordered with the car (I didn't spec it, alas). Since it was installed at port, I am going to assume it's on there for life. Really don't want to destroy the paint just for a spoiler change.
07-02-2022, 03:48 PM | #28 | |
Rep 3,806
Take a look at this link: https://www.bimmerfest.com/threads/s...moval.1289134/ |
chris7197334.00 |
07-02-2022, 06:11 PM | #29 | |
Rep 3,006
https://www.3m.com/3M/en_US/p/d/b40069527/ For example... https://www.autogeek.net/3m-auto-tape.html may also want to use this but ONLY where the spoiler will cover it. https://www.autogeek.net/adhesive-promotion.html |
07-02-2022, 06:14 PM | #30 | |
Rep 3,006
https://www.dupont.com/brands/betalink.html |
chris7197334.00 |
07-03-2022, 04:44 AM | #31 |
Rep 219
I used double sided 3M tape not betalink for my M Perf CS spoiler on my 2020. Removed it from that Comp, using fishing line and adhesive remover and transferred it to my newer '21.
It's a PIA removing tape, but really not as bad or hard as some would lead you to think. The 3M holds very well even at high speeds, and Ive had no loss of adhesion. My BMW dealer also only uses 3M. https://youtu.be/tZ-l-A_Sm_4
BMWCCA M Chapter & NJ chapter
'21 BMW M2C BSM 6MT MDrivers Pkg |
chris7197334.00 |
07-04-2022, 06:30 PM | #32 |
Rep 436
infinitekidM2C4206.50 |
07-04-2022, 07:00 PM | #33 | ||
Rep 3,806
07-05-2022, 05:51 PM | #34 |
Rep 210
Drives: 2021 F87 M2 Competition
Can confirm that they only use K1 for port installs; had a hand in providing feedback for the port install instructions, or at least for Canadian vehicles.
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
07-06-2022, 02:30 PM | #35 |
Rep 4,254
It's not fine. Use betalink!
///M Power
07-06-2022, 03:12 PM | #36 |
Rep 7,299
07-07-2022, 08:35 AM | #37 | |
Rep 4,254
There is a reason BMW uses and recommends betalink.
///M Power
07-07-2022, 03:15 PM | #38 |
Rep 163
But BMW does not use Betalink for the stock lip spoiler that comes on the car from the factory. They must not care about those just falling off.
2013 Toyota Tacoma - TRD Pro Wheels, Bilstein Leveling Kit
2021 BMW M2C Special Content |
chris7197334.00 |
07-07-2022, 04:16 PM | #39 |
Rep 3,806
Let's not argue over something so silly - any spoiler that's applied with 3M tape OR betalink is not going to fall off if properly applied. It is mostly a decorative piece and doesn't create near the downforce necessary to unbond it no matter what the method. BMW recommends a lot of things for a lot of different reasons, that doesn't mean it has to be done that way.
Fred Conoway365.00 chris7197334.00 |
07-07-2022, 05:14 PM | #40 |
Rep 52
Drives: 2021 M2 Comp
OP
I too am in the same predicament. I bought a high kick PSM but am swapping it out for the less aggressive CS. As far as install, removing my factory M2C spoiler was not hard. Painters tape, trim tools, and patience. And then I carefully used an adhesive removal wheel on my drill. |
11-29-2022, 02:37 AM | #41 | |
BMW forever!
1389
Rep 2,418
I hope you are doing well. Thanks for all your tips with the installation. Quick question, please let me know which 3M VHB tape did you use for the M2 CS spoiler? There are quite a few 3M VHB tape versions, so trying to figure out. I found the product on the website below: https://www.3m.com/3M/en_US/p/c/tape.../i/automotive/ Please let me know the website/shop where you purchased the product for your application. Thanks!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
12-05-2022, 11:16 AM | #42 | |
Rep 3,006
https://www.3m.com/3M/en_US/p/d/b40069527/ |
