04-03-2019, 01:09 PM | #639 |
Rep 257
N/A in USA M Performance front spoiler for M2C?
I wanted to get the carbon fibre M Performance front and rear spoilers with the rear diffuser. It seems that the front spoiler is not available in USA at this time. Do you know anything about this or how to work around this issue?
New, GerryM5 |
04-03-2019, 01:37 PM | #640 |
Rep 257
Can you tell me how you installed both? Is it easy? gerrybg@gmail.com
04-03-2019, 01:54 PM | #641 |
Rep 2,956
Henry is the first person I have seen call the diffuser super easy. The spoiler wasn't that hard and I spent the most time lining it up as perfectly as possible.
04-03-2019, 02:11 PM | #643 |
Rep 3,842
I can confirm that the MP diffuser was super easy to install because it fits. Your mileage may vary with other aftermarket diffusers.
DIY tips: Pull off the tabs on both sides leaving the center 4 tabs. Gently pull so that you find exactly the place where the first center tab is located. Use a soft thin trim tool knife to pushed the tab open. You will need to tap it with your palm. Then it just releases. 3 more to go and you're finished. It took me about 15 minutes to remove the original. The new one goes in super easy. |
04-03-2019, 03:58 PM | #644 |
Rep 6
Well I replaced the front reflector and also the rear one.
I also installed an oil catch can. Some before after pictures
2019 M2C LBB, 6MT
shemeld_135652.00 |
04-03-2019, 07:43 PM | #645 |
Rep 109
AlpsRider is a bit more detailed in his method. But for me it was more simple. Remove all screws/bolts holding the plastic diffuser to the bumper. Starting from the driver side, give a quick, firm tug on the left side of the diffuser and it should pop out. Repeat the same on the passenger side and it should come free.
For the spoiler work fishing line between the trunk lid and spoiler to cut the double stick tape. Use goof off or similar to remove the tape residue. |
04-03-2019, 07:57 PM | #646 | |
Rep 537
Brandon
04-04-2019, 06:32 AM | #647 |
Rep 752
Just got the car back from its 1200 miles service
Does need to go back for a couple of quality enhancements though...
'17 S1000RR , '19 M2 Competition HS
04-04-2019, 11:07 AM | #649 |
Rep 929
Which oil catch can did you go with and how easy was the install? I'm thinking of getting one that has a drainage system because as I understand they install under the carbon fibre brace and it's a pita to remove every time to drain.
04-04-2019, 12:19 PM | #650 |
Rep 3,842
I'm interested in a catch can comparison/info. I think this will be my next mod. I've heard of a 2 can system for the S55...anyone going that route?
04-04-2019, 06:43 PM | #651 |
Rep 1,332
04-04-2019, 07:08 PM | #652 | |
Rep 3,842
I'm not sure if BMW turbo engines will benefit much from the 2 can system, but I'm all ears. https://www.enginelabs.com/news/vide...ch-can-system/ |
ContactPatch2139.00 |
04-05-2019, 08:25 AM | #653 | |
Rep 6
Burger Tuning one Literally took 5 minutes to install. The scary part was to unlock the hose from the engine. For maintenance I would say even with the draining plug it will be really hard to reach under the catch can. My plan is to just unscrew it at every 5000km oil change.
2019 M2C LBB, 6MT
04-05-2019, 09:42 AM | #654 | ||
Rep 929
04-05-2019, 09:42 AM | #655 |
Rep 277
Drives: '23 M340i, '16 X3
Day one list of "mods" (all coding done via simple mode in BimmerCode):
In the queue to do this weekend...
Current - 23 G20 M340i, 16 F25 X3 2.8i xdrive
Gone - 19 F87 M2C, 11 E90 335i, 08 E70 X5 3.0i, 04 E46 330i, 95 E36 M3 Last edited by srwatters; 04-05-2019 at 12:50 PM.. |
///M Houbi1655.00 |
04-05-2019, 10:11 AM | #656 |
Rep 6
I would say NO...it's so tight in there.
2019 M2C LBB, 6MT
04-05-2019, 11:40 AM | #658 |
Rep 929
A catch can will not prevent carbon deposits 100%... also depends on other factors such as driving habits... but I would say it can definitely slow down the carbon buildup process so that you can delay a need for a walnut blast cleaning of your valves... but if you got OCD like I do about these things then the catch can will definitely increase your own longevity by preventing stress :
04-05-2019, 11:42 AM | #659 | ||
Rep 466
04-05-2019, 12:04 PM | #660 | |
Everyday I'm shuffling
449
Rep 1,098
I plan to do some coding this weekend. Just got the OBDII dongle. Curious: Did you install fog lights? Do you have a picture of it installed? |
