03-21-2018, 08:34 AM | #24 |
4972
Rep 10,200
Is that the only way you're giving up the 1M?
03-21-2018, 08:37 AM | #25 | |
7908
Rep 11,785
My E84 X1 seems more likely to be traded off someday because i would have just as much fun with flappy paddles driving around the street and track in an X3m40 or an X3M. |
03-21-2018, 11:31 AM | #26 |
Always +10MPH
1004
Rep 626
This is the way we should all think about the cars we buy, not "oh I need the new one because it's new and it must be better!"
I personally hope you never give up that BSM 1M. Drive it til the wheel fall off, fix, then repeat. That's what I'd do and will do with my car. |
4
03-27-2018, 05:22 PM | #27 |
Rep 1,136
Any idea how many will end up being produced? Sounds like it won't be as exclusive as I originally thought it was. Or not enough to warrant selling the 1M for it at least .... Decisions decisions.
03-27-2018, 06:02 PM | #28 |
Rep 846
It won't be as exclusive so its resale value won't be nearly as high and its steering feel won't be nearly as good. In every other way it will be superior. Base your decision on that.
03-27-2018, 06:36 PM | #29 | ||
this is the way
18155
Rep 8,527
03-27-2018, 06:41 PM | #30 | |
this is the way
18155
Rep 8,527
What do you base this comment "steering feel won't be nearly as good" on? |
03-27-2018, 07:11 PM | #31 | ||
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
M3 Adjuster7907.50 |
03-27-2018, 07:33 PM | #32 |
Rep 2,714
Based on the amount of M2’s that will be produced for the full production run,the MY16 M2 will have the lowest production of all M2 models.There were very few that were produced.The only M2 model that could have lower production would be the M2 CSL,which hasn’t been confirmed yet.
03-27-2018, 09:47 PM | #33 |
Rep 1,136
I’m actually kinda relieved it won’t be as exclusive. Makes my decision easier to keep the 1M
M3 Adjuster7907.50 1M Tex240.00 |
03-28-2018, 07:03 AM | #34 |
Rep 823
What is the timeline for the M2 Competition?
So, does anyone have a projected release date for the M2 Competition? I need to start making a plan for what cars to keep and which ones might go and when. I figure I let go of two leased cars(if timing is right) and keep the M2 PE until I see the CS is the one to keep.
Any guess on dates?
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
03-28-2018, 08:10 AM | #35 | |
4972
Rep 10,200
03-28-2018, 09:33 AM | #36 |
Rep 2,505
I think if you look at production capacity and end of production and factor those two together M2 comp will be semi exclusive.
BMW still cant produce as many M2's as they can since they are limited on the production line. The EOP for M2 comp will be 2020 I believe. So that's roughly just 2 years of production? I still do not see many regular M2's on the road either. Question is. Will BMW produce the same amount of M2 Comps as they did regular M2's?? If this answer is no, than M2 Comp will be semi exclusive IMO.
03-28-2018, 09:50 AM | #37 | |
Rep 2,714
dmboone254972.00 |
03-28-2018, 10:04 AM | #38 |
Chief Warrant Officer
1025
Rep 1,638
Question:
Many of us don't like the sound of the M3/M4 and blame it's "fartiness" on the S55, and hope against hope that the M2 Comp sounds better (since most of us think the N55 M2 sounds better than an M3/4). Isn't that something that can be solved by a better exhaust setup though? Why is it the engine's fault. The farty sound seems to me to be the result of a valve flapping (much like a butt cheek). Wouldn't a valve-less exhaust cure much of that problem?
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
03-28-2018, 11:14 AM | #39 |
Rep 212
03-28-2018, 11:44 AM | #40 | |
Rep 13,107
(source (March 2017): here).
///M is art ↔ Artemis
03-28-2018, 11:52 AM | #41 | |
this is the way
18155
Rep 8,527
03-28-2018, 11:54 AM | #42 |
Rep 13,107
Several models are made at the BMW Leipzig factory. Very busy production lines.
https://www.bmwgroup-plants.com/leipzig/en.html
Tag18155.00 |
03-28-2018, 12:15 PM | #43 | ||
Rep 7,594
Drives: '19 M2C
www.ReTuneTheDeTune.com
03-28-2018, 12:47 PM | #44 | |
Always +10MPH
1004
Rep 626
6 headers routed into 2 individual turbos that does not combine down the stream results in the lawnmower 3 cylinder engine sound. They designed the engine that way and chances are they aren't going to be able to change the exhaust routing without affecting the factory design. There's only so much they can sound tune. People make it louder with aftermarket stuff but it still sounds very raspy and empty There are aftermarket full length exhausts out there for the M3/4 that combine the exhaust routing to make a better sound, but still falls short when the revs go high. With what we have seen from the test cars, the S55 sound remains. |
