BMW M2 Forum > BMW M2 CS Model > Alcon rotors for 2NH
      10-04-2020, 11:32 AM   #1
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
FYI, Alcon is willing to create a bmw hat to fit there 400mm and 380mm rotor options that would fit the 2NH option. I'm inquiring about what a full set of rotors would cost and if partially or fully floating. Since I'm sticking with steel I Would be looking for saving a few extra pounds if possible. My googling suggests about 6lb lighter on front and 3lbs on rear. Never going to be CCB savings, but every bit helps.
      10-04-2020, 01:03 PM   #2
medphysdave
Anyone have the hat dimensions that would be necessary? I'm guessing they would need lug pattern dimension and hat depth to appropriately position rotor in stock caliper.
      10-04-2020, 04:56 PM   #3
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
Cool
Please keep us posted on any developments
      10-04-2020, 04:59 PM   #4
2020M2Competition
429
Drives: Yes
Don't know what the hat dimensions are (sorry)
The lug pattern is 5x120mm
The thread pitch is M14x1.25mm
The center bore is 72.56mm
      10-04-2020, 05:44 PM   #5
Fudz
Drives: 2015 435I 8speed
is this any help?
      10-04-2020, 05:59 PM   #6
medphysdave
Originally Posted by Fudz View Post
is this any help?
Any chance you can grab me a higher resolution image? I'm sure this is the type of data they are after. I told them they already make a hat for the m2 CS racing, but unsure if it's the stock position since that also use an aftermarket front caliper.
      10-04-2020, 07:15 PM   #7
Fudz
Google that Brembo part number for the high res
      10-04-2020, 08:06 PM   #8
cncmastr
cncmastr's Avatar
Drives: E46 ZCP, F85, E70, G07
2018 X5 M  [0.00]
2020 M2 CS  [0.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [0.00]
boom!
https://www.bremboparts.com/europe/e...isc/09-C399-13
CLOUT49.50
      10-05-2020, 12:41 PM   #9
medphysdave
Alternately
https://www.girodisc.com/Girodisc-Fr...rs_p_6855.html
I'm sure they can put together some rears.
