M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Will it fit?
      10-24-2015, 11:01 AM   #1
TselaG80
Drives: SMB G80 M3 X-Drive
Will it fit?
That's what she said hahah all jokes aside.
I feel like the M2 will looks much better with wider rubber.
I'm thinking of swapping the rear 265s up front and installing 295s in the rear. The 10" rear wheels will have no problem holding 295s.
I'm just wondering if the 265s will rub up front.
What's everyone's thoughts on this idea?
      10-24-2015, 11:19 AM   #2
Makman
Sweden
231
Drives: BSM M2
My friend is setting 295 rear and 255 front on his 1M. Idk if they are comparable in this matter tho.
jnoyes35.00
      10-24-2015, 11:41 AM   #3
M3 Adjuster
Albania
7906
It's probably possible. I would try immediately on delivery. The 1m rear 10l wide wheel and tire will fit up front. Most people don't try and run square with OEM wheels likely due to cost.
On the oem wheels 265 runs slightly and 255 does not run at all so most people do 255.
For track I run apex arc 8 18x 10 all around on my 1m.
285/35/18 fits all four corners for track. A 315/35/18 fits on The rear with 18x10.5 and even wider is possible.
Hope this carries over on the '2. All these turbo cars nee d more rubber
I'm
      10-24-2015, 03:42 PM   #4
gthal
gthal's Avatar
1904
Drives: 2018 340i xDrive
Given the M2 uses the same wheels as the M4, I suspect if a wheel/tire combo fits the M4 it will fit the M2. What you suggest works on the M4.
Having said that, no one knows yet so it is purely speculation.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      10-25-2015, 11:34 AM   #5
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
In order to keep the balance, I would consider moving the 265s to the front and put 275/35s on the rear. They'll be closeer in diameter that way too. Yeah you can't rotate front to rear but that doesn't matter to me at least. 295/30s might be too much grip in the rear but maybe that's needed.
      10-25-2015, 09:56 PM   #6
Twix
Twix's Avatar
657
Drives: 2011 e91
Even though a 295 will fit on the factory 10", it will look grossly bulgy.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      10-26-2015, 06:11 PM   #7
TselaG80
The f8x has 10in rear wheels, and if seen a few with 295 section rear and it looks perfect actually.
      10-27-2015, 12:18 AM   #8
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
As you know it depends on which tire you use. I agree with Twix that a few of them might work but will look bulgy.
Here is a Michelin PSS 295 on a 10" wheel.
      10-27-2015, 12:28 PM   #9
kovsky
Drives: M2, finally
Here is a popular thread over on the M4 forums detailing tire options for stock wheels. Lots of good info already compiled there.
http://f80.bimmerpost.com/forums/sho....php?t=1089535
      12-31-2015, 04:16 PM   #10
remmib
General
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
But the M2 has slightly narrower tires though, 245/35/19 and 265/35/19 vs the 255/275 on the M3/M4.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      12-31-2015, 06:04 PM   #11
Twix
Twix's Avatar
657
Drives: 2011 e91
BMW says the larger M4 rubber won't fit. I call bullshit. They probably reduced the width to slow the car around the ring, otherwise, it'd be too close to the M4 in terms of performance.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
      01-01-2016, 01:18 PM   #12
gthal
gthal's Avatar
1904
That's complete BS from BMW... 10mm on the tires is largely irrelevant unless clearance is already REALLY tight. No manufacturer specs cars that tight from the factory. I bet big money people will be running 265/295 (or bigger) sizes on the M2 once wheel manufacturers get offsets that will work.
      01-01-2016, 01:39 PM   #13
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
As I said in an earlier thread the M2 has less room than its bigger siblings so to get that extra safety margin that the manufacturer needs (for snow chains etc) they opted to go down in size. Under no circumstance would BMW release a car that could risk rubbing in any situation that might occur.
Fitting wider tires will be no issue at all, probably not M3/M4 offsets but adding 8-10 mm should be doable when looking at the photos. This is of course just my amateur opinion from looking at way to many Long Beach Blue M2's.
