12-30-2023, 08:50 AM | #1 |
Rep 159
Gold Wheel Weights?
Definitely being nit picky on this one, but the silver wheel weights on my gold wheels are starting to become a bit of an eye sore for me and I’d like to hear if anyone has a solution? I don’t see gold weights “off the shelf” so wondering if anyone has sprayed or coated a set to match, and then balanced?
Know I’m being pretty particular on this one, but I’m sure there’s a few CS owners who feel the same |
12-30-2023, 09:49 AM | #2 |
The Seeker
13863
Rep 3,326
You're not being picky, I'm the very same. Luckily I have a nearly black barrel and black weights.
I think you'll need to paint your weights, and I fully recommend CKAuto, they are flatter, and you can use less of them. |
chris7197334.00 |
12-31-2023, 05:28 AM | #3 |
Rep 159
Thanks - nice weights and agree I think painting may be the only way. Waiting to see if anyone came up with anything clever here but if not, I’ll just go to paint route this winter while they’re off the car.
01-03-2024, 12:28 PM | #4 | |
The Seeker
13863
Rep 3,326
However, since the wheel weight itself isn't subject to much heat, you could just mix the Testors gold (1144c) and silver (1146c) model paints until you get a similar color and no one would be the wiser. |
01-03-2024, 03:24 PM | #5 |
Rep 159
Good idea - will experiment - assumed since there will be times when the weight is close to a hot caliper for an extended period (parked after a hot run and in perfect spot near caliper) that I needed high temp. Was going to see if u could track down a generic gold high temp spray and see how that looked…good news is I have time now to play around as the winter setup is complete and Goldie’s are sitting out the cold. Love the dual personalities I have now - car looks completely different for such an easy swap, fun to have both and the brakes look nuts on black wheels!
Crossmax51.00 |
