09-28-2023, 02:50 PM | #1 |
Rep 23
Exhaust Setup C parts
Can I buy competition exhaust/midpipe set ups for the CS?
Lots of these CS counterparts are out of stock |
10-01-2023, 08:22 AM | #2 |
Rep 327
I have a second hand Akra mid pipe and muffler on my CS from a Comp.
From a Turn 14 inquiry email years ago: “Both exhaust systems are the same. They will fit both cars. The only difference is the electronics. The Comp kit comes with a receiver control unit for the valves. The CS also has valves but it seems to be a more "PnP" which doesn't involve a separate controller that ties into the factory system.” I have the comp controller sitting in a box. I chose to install the CG Percision controller instead that is linked to the homelink buttons. |
10-06-2023, 08:12 AM | #4 |
Rep 613
Drives: F87 M2 CS
Yes.
When I got my CS, the very first thing I did was swap the entire Active Autowerke midpipe, connector pipes and axleback over from my Comp.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
10-06-2023, 02:56 PM | #5 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
Do you have the EL midpipe or the straight one? And which axleback?
10-06-2023, 03:26 PM | #6 | |
Rep 613
Drives: F87 M2 CS
But I must admit that I'm not overly thrilled with the exhaust and wouldn't buy it again. Dont get me wrong, it sounds great. However, the fitment of all the provided pipes are questionable, at best. It required getting an exhaust shop involved to add some custom welds to make it all fit together properly. I'll spare you the details of my months long headache with it (both on the Comp and CS). But if I were to do it again, I'd buy an exhaust from a brand like AWE or Valvetronic, who use proper slip joints and higher quality clamps.
10-10-2023, 06:49 PM | #7 |
Rep 4,672
Another data point. The shop that installed my Akrapovic setup said it was one of the easiest systems they've ever installed. It bolted right up. You can't even really adjust the exhaust tips.
11-22-2023, 10:52 AM | #8 |
Rep 114
Were the issues mainly with the AA exhaust?
11-22-2023, 11:57 AM | #9 | |
3024
Rep 13,764
~loud noises~
11-22-2023, 03:01 PM | #10 | |
Rep 613
Drives: F87 M2 CS
I was able to mitigate the fitment issues by having a shop custom weld the connections between the axleback and connector pipes, changing the angles to give much better fitment. But the tingy rattle at startup can't be fixed. Only solution is to use a valve controller to force the valves open. But those open valve cold starts (even with resonated pipes) get REAL loud. If you like the overall tone, the EL midpipe with OEM axleback is great. The OEM axleback is just a bit to raspy for me. But many love it.
MSH_123.00 |
11-22-2023, 10:22 PM | #11 | |
Rep 114
https://x-ph.com/active-autowerke-f8...ngth-mid-pipe/ Last edited by MSH_; 11-30-2023 at 06:19 PM.. |
12-01-2023, 12:23 PM | #12 |
Rep 917
Drives: 2020 M2CS 6MT
I have EL midpipe I’m removing from my CS tomorrow. If anyone is interested in it, I’m in Texas and will sell it for $900 if you need it shipped. I’ll give you box dimensions and weight to get a quote.
Swcc
2021 M2CS
