02-26-2022, 10:58 AM | #45 |
Rep 4,672
Man, rough couple of weeks. Cracked window and today I hit my driveway at a weird angle and damaged the underside of the front lip. You can't tell from the top. I think I'm going to try to have someone repair it. No sense in replacing it yet. Can most body shops do carbon fiber repair, or is it more of a specialty?
02-27-2022, 06:20 PM | #46 |
Mmmm... Bavarian
2129
Rep 1,690
Oof that sucks. Sorry for the bad run!
It's specialty in my understanding. Ironically boat shops are one of the few that can usually do spot repairs since they are so used to doing composites repairs.
M2 CS
2023 CB X5 45e 2018 i3 94 2014 Cayman S |
02-27-2022, 07:04 PM | #47 |
Rep 1,078
I scrape mine all the time but it's only the lip protector from IND that gets hit.
02-28-2022, 08:41 AM | #48 | |
Rep 4,672
My thought is that I can epoxy a thin piece of plastic to the inside. Then epoxy the piece that got punched out back in place. A little sanding etc and it will be good enough for me to forget about it. |
02-28-2022, 10:18 AM | #49 |
Rep 145
Ouch.
I am not a fan of most lip protectors for this reason. They lower the height of the lip in some cases and concentrate forces. You almost would need a very thin plastic scrape guard under there just to prevent incidental scrapes. But honestly if there is heavy damage it will impact and cause problems. |
02-28-2022, 10:56 AM | #50 | |
Rep 4,672
02-28-2022, 10:10 PM | #51 |
Rep 184
Some adhesive backed Teflon might work to prevent superficial cosmetic scrapes without adding significant thickness. McMaster has a few different thickness options:
https://www.mcmaster.com/adhesive-backed-ptfe/ |
02-28-2022, 10:12 PM | #52 |
Rep 875
Drives: ///M2
I endorse doing PPF, although I'm not sure if it would've helped here or by how much.
On a car this beautiful you don't want a base matte black or gloss lip. The carbon matches with the roof and trunk spoiler and it's perfect. This is just a unfortunate event but don't let it get you down too much It's honestly not that bad & I would drive it without thinking twice
02-28-2022, 10:24 PM | #53 | |
Mmmm... Bavarian
2129
Rep 1,690
I was thinking about exactly this, so you totally did the legwork!
M2 CS
03-01-2022, 07:44 AM | #54 | |
Rep 4,672
03-28-2022, 12:58 PM | #56 |
Rep 4,672
Bumping this up. Finally getting around to wanting to pull the lip. Anyone have some detailed instructions for removal? I don't want to mess it up.
03-28-2022, 01:50 PM | #57 |
Rep 855
I haven’t done the lip on the CS but did do one on my M2 Comp. I would suggest having new retaining clips on hand because they often get damaged during removal. Removing them is a mild PITA as they are recessed. I used long nosed needle nosed pliers as I recall.
03-28-2022, 02:01 PM | #58 |
Rep 4,672
Ok, I'll get new clips and new blocks just in case. Can you drive with the splitter removed without the front fascia flapping in the breeze. I could get a shop to do it for me.
03-28-2022, 03:27 PM | #59 |
Rep 855
MadBimmeRad7121.50 |
03-29-2022, 11:02 AM | #60 | |
Mmmm... Bavarian
2129
Rep 1,690
A tool like this is all you need to make it super duper easy. https://www.amazon.com/ARES-16006-5-...s%2C73&sr=8-21
M2 CS
03-29-2022, 11:04 AM | #61 |
Mmmm... Bavarian
2129
Rep 1,690
Yes, the recess makes it harder, but the tool i linked above, the bend makes it easy to get them out and works great.
M2 CS
05-03-2022, 02:32 PM | #64 |
Rep 91
05-03-2022, 04:09 PM | #65 |
Rep 174
Or get a replica carbon fiber lip, cheaper to replace, RW Carbon has one that looks identical to my eyes? I ordered their diffuser and it looks the same to the OEM carbon to me.
CURRENT: 2020 M2 Competition (BSM)
Previous: 2008 135i |
05-03-2022, 07:30 PM | #66 | |
Rep 116
