04-10-2023, 02:02 PM | #1 |
Remove Before Flight
6822
Rep 1,611
Cup2 Connect or RE-71RS for HPDE/Open Lapping?
Tires will be track-specific and used *only* for driving to the track (90 min on the interstate), doing HPDE's/Open Lapping, and then driving home.
I've narrowed it down to the Michelin Cup2 Connect 240 OR the Bridgestone RE-71RS. Cup 2 Connects for sure fit the front of the car. TireRack says the Bridgestones will fit as well. 255/35/19 on a 9.5" wheel w/ M-P suspension and camber plates. I do 20 minute sessions in both HPDE and Open Lapping in June-Sept, so the track's a mite toasty. Worried about heat cycling on the Bridgestones, but they're significantly cheaper. No AutoCross, racing or anything else. A little help making the decision from the Collective? Half the reviews I've been able to find favor the Cup's, half favor the RE's. And a lot of them are AutoCross, which isn't quite what I'm doing. TIA.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
04-10-2023, 05:28 PM | #3 |
Rep 489
04-10-2023, 08:38 PM | #4 |
Rep 422
Drives: F87 M2 DCT, F15 X5
This is a tough one. I considered both for my M2 but ultimately ended up with PS4S because it is my daily and didn’t want to buy a set of tires each year. I’d go for the Cup 2 in your shoes. They are a little more expensive, but I think they will give you more consistent performance for hot lapping. Plus you have some comfort knowing they are used on just about all the track special versions of sports cars. I think the RE-71RS is more of a autocross tire. The HPDE and Gridlife events I’ve been too, no one really runs the RE-71RS. Cup 2 is popular though.
flybigjet6822.00 |
04-10-2023, 08:50 PM | #5 | |
Rep 422
04-11-2023, 11:39 AM | #6 | |
6822
Rep 1,611
okla_m2c96.50 |
04-11-2023, 11:44 AM | #7 | |
6822
Rep 1,611
I'd read (and re-read after you linked it) that article-- it puts both the -71RS and C2 Connect in the "autocross and single-lap time trials" category. And? *Literally* not a single other tire listed comes in 255/35/19 and 275/35/19. On the plus side, it *did* kill an evening on researching tires! Still 50/50 between the two-- the -71RS is new enough that there's not a lot of data out there. Tire Rack says it's got a squarer profile on the edges, so I'll have to play around with the car to try to get some measurements to see if it'll clear the front of my M2C. They said if I mount to check clearance but don't drive, I can return them if needed-- THAT'S a good thing. I've got about two more days worth of rubber on my current C2 Connects-- so after mid-June, I'll have to make a decision.
04-11-2023, 12:27 PM | #8 | |
The Seeker
13863
Rep 3,325
If you know anything at all about heat-cycling then you know that driving a sticky tire to and from the track will cycle it out very quickly, losing you all that grip you want so much. This is the reason you see guys hauling tire trailers behind their FD's... Between the two, the Cup2 fits your situation best, no question whatsoever. |
04-11-2023, 12:30 PM | #9 | |
6822
Rep 1,611
The Cup2 Connects are harder to find (esp. the front in 255/35/19), but at least they're a known quantity. I wish I could pop on dedicated track tires, but there's just no realistic way to make that happen-- and the sizes I'm running pretty much rule out any track-specific tire. I wish I could run 18's, but the expense of a brake swap would be cost prohibitive. And by expense, I mean "divorce". Thanks again for the tilt towards the Michelin's. R.
///MPhatic13862.50 |
04-11-2023, 12:37 PM | #10 |
Rep 296
I would run the Cup2 if you are driving to and from events. I found about 2.5 deg neg camber in front was about what they liked to be able to obtain even temps across the face of the tire and run them at the proper pressures.
Wouldn't a dedicated set of track tires/wheels in the end cost about the same as running one set for everything? I would think the Cup2's would wear significantly more on track than a semi-slick on a dedicated set of wheels. Just trying to help you justify! |
04-11-2023, 12:46 PM | #11 |
Rep 582
The old RE71s did not heat cycle out, not sure if the new ones do.
In my experience, neither the RE71 or the Cup2s are optimal HPDE tires, if you run a faster pace. Both offer excellent grip for a single/couple of laps but then overheat and get greasy. This sometimes makes enjoying a full 15/20 minute session a challenge. NT01s in 18s can often be found for around ~ $1k. I enjoy these much better than the RE71s or Cups, plus they are cheaper.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
04-11-2023, 12:56 PM | #12 | |
6822
Rep 1,611
04-11-2023, 12:58 PM | #13 | |
6822
Rep 1,611
the -71's/Cup2C's ARE the dedicated track tires— I normally run MP4S's for street. But, I can NOT find a street legal tire that'll fit my wheels. So, I'm down to those two choices for track days. Between the 19x9.5/10.5 wheels, already tight clearance on the front of a M2C, M-P conical springs— there's just not a lot of options.
04-11-2023, 01:41 PM | #14 |
Rep 199
Given the choices you have, I would lean more towards the RE71RS as they will last longer than the Yokohama A052s that are also available in 255 front/ 275 rear, are better from a fitment and performance perspective than the Falken RT660s in 275/30/19 front and 305/30/19 rear, and less expensive than the Cup2 Connects.
If you start going through tires at a fast rate then the choices becomes whether to invest in a BBK like the AP kit that will allow you to run 18s which will then open up a wider tire selection. |
04-11-2023, 03:55 PM | #15 |
The Seeker
13863
Rep 3,325
They would with standard 75 mph highway driving. They'll last, but will eventually get hard because of it. I think the Cup2 (240, not 180) is better at this. Ring Taxi's use it almost exclusively because of this.
I miss my old 71R's. I hope the new one is as good. |
04-12-2023, 07:12 AM | #16 | ||
Rep 42
I had cup 2 tires on previously, and similar to you, went to RE71-RS due to price and availability Quote:
04-12-2023, 07:20 AM | #17 | |
The Seeker
13863
Rep 3,325
04-12-2023, 03:33 PM | #18 |
Gary O
24
Rep 11
Hey Flybigjet.
I drive at HPR and commute nearly the same distance as you with my M2C. I have found the Cup 2's to be excellent. I am running about -2.8 camber and yes, they will wear the inside shoulders out. But they are good for 8-10 HDPE events depending on how hard you push. In warm conditions they get greasy after 5-6 quali laps, the price you pay to play. The summer time temps / conditions at HPR can be brutal......for your car and most of all the tires. Fortunately BMW built a solid cooling system into the S55 and I've never had issues with overheating (ie e46 M3) I admit to not having tried the Bridgestones but I'm reading the same tea leafs you are and they seems to be more targeted for autocross use. Cup 2's are spendy but I think they are worth the little extra cash. Cheers Bigjet......See you out at the track [ |
flybigjet6822.00 |
04-14-2023, 09:06 AM | #19 | |
Rep 1,759
All the fastest M2C lap times I have seen in the last few years were on Re=71RS or A052, not one was on Cup 2. The RE-71RS has more grip than the Cup 2 but that is not the reason why it is a great track tyre. It is a great track tyre because when you drive it beyond its limit, it will recover its composure fairly quickly. Secondly, its stiff sidewall aids steering precision and contact feel, and in many cases requires less steering input (less turn in) during high lateral G than some other tyres. |
