02-27-2021, 05:54 PM | #23 | ||
M///modifyer
2491
Rep 1,295
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022 |
02-27-2021, 05:54 PM | #24 |
Rep 7,431
The more options the better!
02-27-2021, 06:01 PM | #25 |
Rep 7,431
Just had a chance to take a look at some batteries and so far what I see is that the cold cranking amps are lower than antigrav, but the batteries are significantly lighter. Even the 68AH battery is half the weight of the antigrav 40 ah battery, holy crap that is light. It even has the restart tech (on some batteries) which is really nice. The price is also alot cheaper than antigrav, so tbh I think I have a new favorite lithium battery.
Thanks again man! ZM2 maybe these batteries are something you would be interested in.
ZM22813.50 |
02-27-2021, 07:09 PM | #26 |
Rep 3,696
TargaM2 F87source
Coincidently I was watching my V8 Supercars Superview YouTube subscription and the Mt Panorama race earlier today and was admiring the tiny lithium batteries in the cars (along with the E85, AP Racing brakes, and plush suspension—love watching Supercars more than F1!). This looks like a great option. They have some new models coming out, so I’ll have to go thru the specs to figure out which one would be enough for my situ, and the OEM fit bracket to go with it. Thanks! |
F87source7253.50 |
02-27-2021, 07:17 PM | #27 |
Rep 3,696
Separate, related question:
What cooling fans/pumps do our cars run after we turn the car off? Just want to make sure I get enough Ah for the car to continue to circulate air, water, oil, etc, at the track, if it does that once turning the car off. |
02-27-2021, 07:26 PM | #28 | |
Rep 7,431
02-27-2021, 07:30 PM | #29 | |
Rep 7,431
Btw 68AH and 64 AH is the only two models that you can get with 900 cold cranking amps, the rest has reduced cold cranking amps so it doesn't list the m2 as compatible. So you don't really have much choice, but not to worry the largest battery they have (68AH) still weighs 50% less than AG's smallest battery, at 3.9 kg.
ZM22813.50 |
02-27-2021, 07:32 PM | #30 | |
Rep 3,696
02-27-2021, 07:55 PM | #31 |
Rep 7,431
It probably will but then the restart tech (if equipped) likely won't have the juice to restart the car, or if the battery gets low it might not have the cranking amps to start the car after. It might also struggle in the cold, so I wouldn't go less than their race9+ or restart 9 (restart 9 if you want the restart tech) battery.
02-27-2021, 11:14 PM | #32 | |
Rep 427
I’m definitely interested in a Lithium battery when the OE AGM craps out. I made sure to buy a Lithium compatible charger/tender a couple years ago to be prepared. However, with onboard battery management that both companies offer, does anyone know if you should choose a standard AGM/Lead Acid mode on your charger, or actually use the lithium mode if you have it? |
02-27-2021, 11:30 PM | #33 | |
Rep 7,431
For AG you must use a lithium charger. For the lithiumax battery you are allowed to use a standard trickle charger if it has an agm mode. You're also allowed to use a up to an 80 amp battery charger which is amazing for people that like to flash new isteps to their cars.
bentom2335.50 |
02-27-2021, 11:50 PM | #34 | |
Rep 7,431
This is closer to lithiumax's 68AH battery in terms of capacity yet it's still heavier, and more expensive.
bentom2335.50 |
02-28-2021, 01:33 PM | #36 | |
Rep 7,431
I believe you would register the battery based on actual capacity. Talk to the lithium battery manufacture that you're going to buy from to be sure.
02-28-2021, 03:23 PM | #37 | |
Rep 427
02-28-2021, 03:32 PM | #38 |
Rep 7,431
No problem, I remember seeing it when Anti grav first came onto the scene and never saw it since.
bentom2335.50 |
03-01-2021, 11:56 AM | #39 | |
Rep 201
03-01-2021, 01:20 PM | #40 | |
Rep 7,431
Idk if it varies from different battery manufactures so double check if you buy a different brand.
ZM22813.50 |
03-01-2021, 01:53 PM | #41 | |
Rep 3,696
Are you guys going to order their OEM retrofit bracket too, or try to brace the battery a different way? The bracket also comes with the SAE posts, which aren't expensive either way. Battery, bracket, and shipping still add up to $900US with a 30-90-day wait. 5% off promo code (eddys5) takes that down to $862US. Would love to drop 45lbs, but it's still $600 more than an AGM. Last edited by ZM2; 03-01-2021 at 02:46 PM.. |
03-01-2021, 03:22 PM | #42 | |
Rep 7,431
What size are our battery posts? They are metric for sure, but what size is the question. Hmm at the $862 range it isn't as cheap as I would've liked and might be a consideration to look at AG batteries as well because they are a direct drop in as they have the H7 group 94r size battery. Maybe talk to lithiumax to see if they have any discounts at some point. But yes it is indeed alot more than a standard AGM battery, but it should last 4 times longer, so those savings should equal out.
03-01-2021, 03:55 PM | #43 | |
Rep 3,696
But, it shifts the weight balance back towards the front, which really it’s the nose that needs to lighten up for better balance on our cars. Obviously some of that can be addressed in suspension setup, but we’re already fighting 52/48 F/R and having that extra weight so low in the rear has got to help traction even if you have to sling it around laterally. So, now we’re getting into trade offs and splitting hairs. |
F87source7253.50 |
03-01-2021, 04:04 PM | #44 | |
Rep 7,431
That's true, but you can always counteract that loss with a big tank of water for your water sprayer set up Either way I have some thinking to do as well with the fact that my battery is 5 years old this year and who knows how close it is to the edge.
ZM22813.50 |
