10-27-2020, 04:48 PM | #1 |
Rep 291
Drives: 2023 BMW M2
Vibration and resonance in cabin at 35-40mph
Have a horrible vibration around 35-40mph, doesn't change with rpm or road conditions. Thinking it's either driveshaft related or maybe U- Joint? Any ideas?
Car goes into service in 2 days |
10-27-2020, 05:06 PM | #2 | |
756
Rep 2,149
Also, I'd delete this and post in the mechanical issues forum. |
10-27-2020, 05:07 PM | #3 | ||
Rep 291
Drives: 2023 BMW M2
10-27-2020, 07:24 PM | #4 |
Rep 244
Drives: 2018 M2 Alpine White
My 2018 X3 just had the same symptom, soon after that developed the check engine light came on. Turned out to be a bad injector. Not the first time it's happened, same on my 135i a while back. Both times I thought the transmission was going to fall out or had a loose motor mount. Funny how the timing goes everything starts shaking.
Connors5453463.50 |
10-29-2020, 04:37 PM | #5 | |
Rep 291
Drives: 2023 BMW M2
Change by rpm but could still explain it? I'll let my SA know! |
10-29-2020, 08:13 PM | #6 |
Rep 244
Injectors are usually progressive failures, vibrations would get increasingly worse. Come to think my X5 and VW Tiguan (x2) had injectors go bad too. I'm sure there are other failures that cause the same symptom. Loose mounts would cause that too.
All fixable stuff. Good luck! |
Connors5453463.50 |
10-29-2020, 08:21 PM | #7 | |
Rep 291
Drives: 2023 BMW M2
11-02-2020, 07:58 PM | #8 |
Rep 291
Drives: 2023 BMW M2
Update*
Took to dealer and they replaced both front wheel bearings and said the problem is fixed! Drove the car for 20 min and the noise is back! Any guesses? Taking in to check alignment this weekend! |
11-03-2020, 07:55 PM | #9 |
Rep 244
Bad tire? Maybe when it warms up or maybe you lost a balancing weight. Hubs show signs if failure so they might have been bad too....or just a symptom of the real problem. I'm a hack mechanic btw. Nothing wrong getting new parts under warranty while they play trial and error.
Connors5453463.50 |
11-03-2020, 08:05 PM | #10 | |
Rep 291
Drives: 2023 BMW M2
11-04-2020, 12:21 AM | #11 | ||
Rep 330
Usually happens if you overheat them. Could also be a balance/tire problem or even a damaged wheel. Did you smack a curb while tracking it? |
Connors5453463.50 |
11-04-2020, 12:24 AM | #12 | |||
Rep 291
Drives: 2023 BMW M2
11-05-2020, 06:41 AM | #13 |
Rep 1,389
ah more warped rotors, here we go again. it's incredibly rare for rotors to actually warp
Connors5453463.50 |
11-10-2020, 06:22 PM | #14 |
Rep 244
Agree Probably not warped rotors. Dust deposits maybe.
Connors5453463.50 |
11-10-2020, 06:24 PM | #15 |
Rep 291
Drives: 2023 BMW M2
Update: front left tire has a flat spot and a high spot on the other side..... going to replace soon
