06-09-2022, 04:34 PM | #1 |
Rep 715
Drives: 2021 X3 M40i
Return to Factory Downpipe Issues?
Hey all! I am looking at an M2 and it has a downpipe installed. I mentioned that I would want it removed (Smog purposes and I don't wnat the CEL). But I guess his "tech" is telling him that even if he removes the downpipe, it will take about 100 miles of driving for it to reset back to factory settings so he wouldn't be able to smog until after that anyway.
Is this correct or am I missing something? I assumed that I could just use my BimmerGeeks ProTool to reset the code once the downpipe was swapped back to factory. Any help or comments would be greatly appreciated!!
06-09-2022, 05:48 PM | #2 |
Rep 74
100 miles is just a rough estimate on how long it will take the car to go through all the checks in order be ready for smog after getting the stock downpipe put back on. It just needs to go through a proper drive cycle.
https://www.instructables.com/How-to...?amp_page=true |
06-09-2022, 06:40 PM | #3 | |
Rep 715
06-10-2022, 12:46 PM | #4 |
844
Rep 1,962
Out of curiosity, does it not reset to Factory if you disconnect the battery for a few minutes? It will still need to fine tune based on what it finds, but should be a lot closer as a starting point?
06-10-2022, 12:54 PM | #5 | |
Rep 715
Or is that SkyNet starting to take over...?
06-10-2022, 01:11 PM | #6 |
844
Rep 1,962
My car no-longer auto-blips on downshifts, as it has learnt that I keep my foot on the throttle during same. Can get a bit 'lurchy' when I'm not 'making progress'...
06-10-2022, 04:03 PM | #7 | |
a coffee drinker
96
Rep 162
Among the artifacts in my garage is a Schwaben scanner (rebranded or special version for ECS and related companies, by Foxwell (NT520?)). This does the trick. Sometimes you need drive a relatively few miles for the car to be smog test ready. Five years ago, I had to drive 800 miles! None of the silly charts and how-to's had the answer. Finally, I drove the car like I stole it. Benefits to a code reader are likely clear to most. This smog readiness thing is a super helpful when playing with tunes, clearing codes and so forth. |
06-10-2022, 04:06 PM | #8 | ||
Rep 715
