12-30-2021, 03:36 PM | #1 |
Rep 182
Drives: 2017 BMW M3 Competition (LCII)
NGK or Bosch spark plugs?
Hi all,
What spark plugs should I use when replacing them? I've heard that the original OEM plugs are not used (or recommended) by BMW anymore. I'm unaware of what plugs I should now use. Having said that, I have a few bolt-ons (an upgraded charge pipe, intercooler, turbo inlet pipe, boost pipe and cold-air intake), but stock software and downpipe. Look forward to hearing your thoughts, thank you. Regards, |
12-31-2021, 06:15 AM | #3 | |
Rep 182
You were actually replying here too; someone states to stay away from Bosch platinum plugs. I also found this thread: https://f87.bimmerpost.com/forums/sh....php?t=1775023 In that thread there's talk about an updated plug. Any thoughts? |
12-31-2021, 06:42 AM | #4 |
844
Rep 1,962
The one I mentioned above replaces the RB ZMR5TPP339 which was found in the F10 5 series, and F12/F13 6 series, so that might be it?
Neither of those links appear to work for some reason. Last edited by M Fifty; 07-22-2022 at 12:41 PM.. Reason: Spelling |
///M TOWN16075.50 |
12-31-2021, 07:06 AM | #5 | |
a coffee drinker
96
Rep 162
Spark Plug Change https://f87.bimmerpost.com/forums/sh....php?t=1606451 Which NGK Spark Plug and Gap for Stock Engine? https://f87.bimmerpost.com/forums/sh....php?t=1775023 |
01-03-2022, 08:32 AM | #7 |
Rep 182
01-16-2022, 01:56 AM | #8 |
Rep 182
Mate, so I received these: ZR5TPP330, not the ones you said I should get. Would these work too? I believe they would, but I notice a rather large difference in price, so maybe the ones I have aren't the correct ones.
01-17-2022, 03:38 PM | #9 |
Rep 7,420
Ok lets clear up some spark plug information, I have not really been clear enough on this in the past and have also made some small slip ups so I want to also clarify it here:
1) If you are buying the bosch plugs you should avoid ZR5TPP339 this is the one that have cracked insulator issues. OEM part numbers for the faulty plug is: 12120038832, 12120038894. So ensure these part numbers are not present in the spark plugs part numbers and you are fine. Here is the bmw TSB https://static.nhtsa.gov/odi/tsbs/20...48022-9999.pdf This spark plug should be discontinued so the chance of accidentally buying this defective plug should be low to impossible now, unless you get some really really really old stock - so just check the part numbers on the box when you get it. 2) You should be purchasing the ZR5TPP330A version which is the updated one found on the S55 and m2 n55. The OEM part number for this plug is: 12120039634 Note these plugs can also be called "RB ZMR5TPP330" without the A at the end, so to ensure you got the correct plug see if the plug has these MFG numbers which are correct: ZR5TPP330A ZR5TPP330 0242145541 ZMR5TPP330 0242145590 8179, 8165 After that make sure the compatible OEM part numbers has the one bmw provides as well, then you can be sure you got the correct plug. But the important part is it is the 330 version, not the 33 version, because the 330 version (1 step colder than stock n55) is for the S55 and n55 m2 while the 33 version is for the normal n55. Here is the FCP euro link for the correct 330A/330 spark plug that you should be buying. https://www.fcpeuro.com/products/bmw...sch-0242145541 Here is the FCP euro link for the incorrect 33 version of the 33 bosch spark plug: https://www.fcpeuro.com/products/bmw...037580#fitment 3) Gap: this one has been hard to find but when I get a chance I will look at ISTA again. But the stock gap for the s55 and n55 should be 0.028", while the stock gap for the n55 is 0.032". The bosch plugs IIRC come gapped from 0.032-0.035 so you proabably have to gap down to 0.028".
01-18-2022, 07:14 AM | #10 |
Rep 22
I'm planning on going stage 2 this week so I ordered the ZR5TPP330A to start with new spark plugs.. what should the gap be?
I have an N55 M2. Don't plan on tracking, drag racing etc... Just want more power for spirited driving around town and occasional highway pulls. |
01-18-2022, 09:20 AM | #11 | |
Rep 196
https://www.fcpeuro.com/products/bmw...plug-ngk-96987 NGK 97506 are the industry standard when you begin tuning, majority of people who are stock turbo FBO N55 running pump or emixes use those plugs. The stock ones are hot even on the stock tune, 97506 is a more appropriate temperature range (2 steps colder). .022 is suggested for most stock turbo applications, I use a lot of ethanol and I'm manual (longer + more sustained load during pulls) so I am .020
14' Alpine White M235i 6MT, BM3 Stg2+, VRSF DP-CP-FMIC, Dinan Muffler, GFB DV+, 3.5 bar MAP, Dorch Stg1 HPFP, NGK 97506, BM3 Flexfuel Kit, CDV delete, KW V3, EDC delete, Powerflex Camber LCA bushings, VMR 801 18x8.5/9.5 et45, Conti Extremecontact 235/265
Next step: M2 Competition or Manual Supra MKV build Summer 2022 |
01-18-2022, 12:58 PM | #12 | |
Rep 7,420
Here is what I posted about plugs in another thread: "Ok so you have 2 real options for spark plugs: 1) The OEM bosch plugs which are totally fine to use in high power level situations, and their heat range is also fine up to 700 whp (GTR's run a similar best range plug deep into the 700 whp range and they don't have issues). Now the part number is Bosch ZR5TPP330A (the A version iirc is the updated one that doesn't crack there was TSB on this). With Bosch plugs the 3rd digit is the heat range so this has a bosch heat range of 5 which is equal to NGK's heat range of 7. 2) NGK 97506 the ngk heat range of this plug is 8 which is equal to a bosch heat range of 4. This plug is 1 step colder than the m2 n55/s55 stock plugs and 2 steps colder than the stock n54 plug. With plugs like I said earlier no need to go colder for no reason as it can lead to bad combustion, but that doesn't seem to be an issue on these cars so it is your choice which option you want. For me I am happy with the stock plugs and they are also 1/4 the price of an NGK so i'm also saving money in the process. But do not let money savings prevent you from doing what is right for your car, if your car calls for it go for what it needs - but since I don't see many high 600whp-700 whp m2's there really is no need for it (it's like buying botique oils for no reason). Also remember to read your plugs when you change them to see if you do need to go colder, that is always the key to moving heat ranges, the 700 whp number is just a guide line it is always best to read your logs and plugs to determine if you need to switch - just like you would with a used oil analysis. For gap start with the stock 0.028" gap and move your way down until the misfires stop. If you go too small you will get incomplete combustion and misfires and rough idles. Too big and your spark will blow out and the same misfires will occur at high boost conditions. Generally speaking mid 400 whp you won't have an issue with stock gap as that is where the m4 gts and m2cs are running. But since you are at 500 whp and with old plugs this could be a sign you need to get new plugs (tuned cars should get it ever 20k miles or less, and every 4 years as per bmw). If you gap gets too ridiculously small like smaller than 0.022" then you probably should get upgraded coils. For the S55 there are no offerings yet (because of the air to water intercooler) - but this will change when nexyus makes the B58 coil conversion for the S55 (n55 too). This will be the best offering yet because the B58 coils make more power than the precision racewerks kit with less dwell, more spark duration, all while heating up the IGBT on the ecu less meaning better life time for that component. So wait on that kit. A result of upgraded coils is you can run a larger gap without spark blow out and thus better combustion will be had. But honestly you can get coils on a stock car too if you want, it just depends on if you want to spend money for no reason or not. Personally I would consider getting coils at a spark gap of 0.024" or less, but if you really don't want to spend alot of cash on a coil upgrade you can push it to 0.022 or less or whenever decreasing your gap sizes just don't cut it anymore and you keep misfiring no matter what. Remember our delphi coils are already more powerful than the stock n54 coils and those guys run upgraded eldor coils (same power output as our delphis so don't waste your money switching to those) for super high power builds so there really isn't a huge need to upgrade coils prematurely. So let me sumarize this last part because it was likely convoluted because I like to ramble: 1) If you have money to burn upgrade coils even on a stock car - why not. (If you have alot of money consider giving me some lol JK donate it to charity or something, or save it for the future I am ok). 2) If you really want to optimize your ignition setup and rather spend money here over an exhaust, colored engine cover or whatever, (a really good idea compared to the former) upgrade when your gap size gets to 0.024" or smaller. 3) This one over rides all of the above, when you begin to continue to gap down but it doesn't solve your misfires at high rpm. Or your small gap size at high rpm works fine but low rpm it starts to stumble you should get upgraded coils so you can run a bigger gap at all times.
///MPhatic13815.50 M2RAW121.00 |
01-18-2022, 01:00 PM | #13 | |
Rep 7,420
///MPhatic13815.50 BoltacoreMD3.00 |
01-18-2022, 01:06 PM | #14 | ||
Rep 7,420
Also do you have evidence that the stock plugs are running too hot? This is also what twisted tuning (a very reputable tuner for these cars) said about spark plugs: Quote:
ZM22810.50 ///MPhatic13815.50 |
01-18-2022, 01:10 PM | #15 | |
Rep 3,695
I also run the Eldor coils, which are better than stock Delphi. https://www.fcpeuro.com/products/bmw...or-12138657273 Or you can run the B58 coils that are even better with the conversion kit that's out, but I haven't needed to do that, yet. |
F87source7239.50 |
01-18-2022, 01:47 PM | #16 | |
Rep 196
My tuning experienced was a nightmare until I went with a colder plug and smaller gap, especially on ethanol. Tip in and high boost misfires and timing corrections all over the place that I couldn't track to any other part. Finally started gapping down and it all went away. This thread testament to one size does not fit all, OP start with stocks if you like and see if it runs right, continue to colder/smaller gap until your car runs perfect.
01-18-2022, 02:47 PM | #17 | ||
Rep 22
You're awesome dude! I already bought the CarPlay from you and have a feeling the CS transmission/diff might be next, especially after stage 2 😉 |
01-18-2022, 04:01 PM | #18 | |
Rep 7,420
But I would not run out to grab eldors as the gains are almost nonexistent vs. the delphi so imo it is wasting money to upgrade from perfectly fine delphi coils. If your stock coils are dead and you wanted a stock like replacement then it would be fine to move to eldors but otherwise don't spend to upgrade to eldor from delphi, you would be better off going to a b58 conversion. The gains are shown by nexyus's testing with a high grade scope on the other forum.
ZM22810.50 |
01-18-2022, 04:04 PM | #19 | |
Rep 7,420
Closing the gap has been common on tuned cars especially higher mileage ones where the coils start to fade. Imo I would never let it get to 0.020", I would have upgraded coils long before, and in the event that you had to gap down this far a coil upgrade actually can yield significant power gains that you were losing due to incomplete combustion.
01-18-2022, 04:07 PM | #20 | |
Rep 7,420
I didn't sell you carplay lol I think that was me recommending kubax. I also don't offer cs transmission/diff flashes either, I pretty much don't sell anything on the forums I can only refer you to people who I think do a good job. Otherwise I mainly just give advice on here and do the occasional reviews.
01-18-2022, 04:30 PM | #21 | ||
Rep 22
01-18-2022, 05:50 PM | #22 | |
Rep 196
Since the last time I did plugs (10k ago) I have replaced my delphi coils and injectors (5-6k ago) and I actually have a new set of plugs sitting in my trunk that I was going to do today. Tomorrow I'll post up a picture of the old ones that have been in for 10k and used almost exclusively with E30-E45 on stage 2+ since the summer. Let me know what you think. Great case of dunning kruger here, I thought I already knew what was up, I did not, thank you for all the info!! So overall, keep gaps as large as possible (for max spark area = better combustion), and gap down till there are no misfires up top (it's not getting blown out), because smaller gaps need more current and that overall seems like it should be avoided from an ignition perspective.
