M2 Technical Topics > Track / Autocross / Dragstrip > Camber settings
      02-26-2021, 09:58 PM   #1
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Camber settings
What's your recommended Camber settings for DD and Track? Have just installed suspension lowered 10mm with Camber Plates, and getting an alignment. Would like Camber for street and setting for track, marked on plates. Also if you could include rear camber, that would be helpful.
At a Point above 7,000 RPM.
      02-26-2021, 11:50 PM   #2
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
-2.75 front, max out rear (about - 2.5)
Motorcity BMWCCA Member
Instagram | YouTube
      02-27-2021, 09:27 AM   #3
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
I run 2.5F and 2R. Good compromise.
Matt
      02-27-2021, 12:54 PM   #4
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
If your going to do a street setup and then bump them for track days heres what I have currently.
With 200 tires (Falken 660's, Yoko A052's or Bridge RE1R's
Street: 2.5F 2.0R Zero Toe in the fronts, a little toe in the rear is ok.
Track 3.2F, 2.0R
With R compound track only tires:
Front now moves to 3.4/3.5
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      02-27-2021, 01:11 PM   #5
chief1richard
2018 M2  [0.00]
Track 3.2F, 2.0R
That sound good. What is the reason for zero toe? Does it have to do with switching back from track to street?
      02-27-2021, 02:06 PM   #6
SEAT TIME RULES
1103
2020 BMW M2C  [5.00]
You want to run zero toe with you much more aggressive 2.5 street setup.
When you any toe at all to "cambered" tire it will act like a force multiplier.
Your already increasing wear on the front insides driving down the road leisurely. Now turn the wheel slightly off center from dead zero toe and it will eat your front tires. Lets say stock neg is 1.2 and you go to 2.5 that's doubling the tilt and adding maybe 20% more wear to the tires life. With toe added on top of that its like losing another 20-25% tire life..
I screwed around with different track and street setups back in the 90's and early 2000's.
You also shouldn't worry about what happens to the toe when you move the plates to your track settings. Its temporary and unless your Time Trialing or a top Solo 2 driver it isn't worth the effort to adjust tie rods at the track.
HTH,
HAZMAT
      03-05-2021, 11:50 AM   #7
j0oftheworld
j0oftheworld's Avatar
109
Drives: 01 S2k, 20 M2C
Mine goes from:
-2.5 / 0 toe street setting
to
-3.4 / -0.16* toe maxed at track
(-2.0 / +0.19* total toe rear)
Vorshlag plates, swift M4 springs
I ran my first session at 2.5 on chuckwalla then max the rest of the day and the extra degree really helps!! 👌👌
      03-05-2021, 01:15 PM   #8
chief1richard
2018 M2  [0.00]
HTH,
HAZMAT
When you say moving back plates don't worry about Toe as its temporary, what do you mean? Just had my car aligned at a well known
shop ,South Shore Autoworks, who do mainly Track-Set ups, and they said moving back will change your Toe settings. I've heard many say not to worry about it.
      03-05-2021, 01:21 PM   #9
SEAT TIME RULES
1103
2020 BMW M2C  [5.00]
When you say moving back plates don't worry about Toe as its temporary, what do you mean? Just had my car aligned at a well South Shore Autoworks, who do mainly Track-Set ups, and they said moving back will change your Toe settings. I've heard many say not to worry about it.
Set your plates for the street with zero toe up front and mark them carefully.
Then on a track day you push them in till you hit the marks for the track setting. When you do this your the will be different.
When its time to head home you push the plates back to the street setting and the toe will again be zero...
      03-05-2021, 01:47 PM   #10
FaRKle!
Do any of you guys use a pyrometer to check the data on your camber settings at the track? Just wondering if there's data to confirm feel.
      03-05-2021, 02:20 PM   #11
chief1richard
2018 M2  [0.00]
My son uses one to check his temps on his Evo 9. It's usually his wife's job as he pits in as it should be done as quick as possible to get most accurate readings. I don't use one, as my wife doesn't come to the track.
