10-21-2021, 01:20 AM | #991 | |
Rep 4,140
And they will be better performers than the Wagner products. |
10-21-2021, 05:21 AM | #992 | |
New BMW owner
325
Rep 842
10-21-2021, 05:25 AM | #993 |
New BMW owner
325
Rep 842
I actually wanted to get that IC (first choice) but messing around with the brackets ...just didn't want that. PnP was what I was after.
VisualEcho6633.50 |
10-21-2021, 10:56 AM | #994 | |
6634
Rep 4,145
Drives: '18 M2 6MT
1. I prefer to buy quality products so I don't have to buy them again. Of the IC's you mentioned, which would be your choice for quality? 2. I like parts to fit correctly if at all possible. Which charge pipe would you recommend with your above IC recommendation? 3. I'm a safety guy, like to set-it-and-forget-it, and only use 93 octane. I don't want to mess with logs, and will never race my car. Would you say that an OTS BM3 Stage 2 93 octane map would be safe under all normal circumstances, or should I use 93 octane but use the 91 map? I appreciate your responses. I didn't realize there was any fiddling that needed to be done with the ER. Thanks for the tip! |
10-21-2021, 12:19 PM | #995 | |
378
Rep 348
Logging is not so cumbersome that an enthusiast like yourself can’t handle it. You’re particular about everything else with your M2, why not lay eyes on how healthy it’s running? If you’re going to put your head in the sand, I would push to S2 91 AT MOST from what I’ve seen running higher than 93 octane in a hot/humid environment like yours. |
VisualEcho6633.50 |
10-21-2021, 01:07 PM | #996 | |
6634
Rep 4,145
Drives: '18 M2 6MT
S2 91 octane using 93 exclusively has always been my plan, but lately I've been reconsidering because I can't find a single instance where running the common mods (DP/IC/CP/BM3S2) has caused any damage. So if it's just going to pull a bit of timing when it's extremely hot, what's the big deal? Unless you've heard of damaged street cars? |
10-21-2021, 01:58 PM | #997 | |
378
Rep 348
I totally get your point, but this isn’t simply a pass/fail exercise for me. If it is for you, I wish you nothing but luck. Not causing “damage” isn’t my definition of success though as I plan to put 80k miles plus on this car. Will it survive some pre-det and go 50k-100k miles as you’re describing? Maybe? Probably? Last edited by Wolfman’s Brother; 10-21-2021 at 02:20 PM.. |
VisualEcho6633.50 |
10-21-2021, 02:32 PM | #998 | |
Rep 201
10-21-2021, 02:36 PM | #999 | |
Rep 201
gphung193.50 |
10-21-2021, 04:15 PM | #1000 | |
6634
Rep 4,145
Drives: '18 M2 6MT
10-21-2021, 08:11 PM | #1001 | |
New BMW owner
325
Rep 842
I've never come across a YT vid mentioned this "off-angle" issue. Of course that doesn't mean it doesn't exist. I've only read about it and personally never really encountered it myself. YMMV. Last edited by vrooooom; 10-21-2021 at 11:13 PM.. |
10-23-2021, 12:29 PM | #1002 | |
Rep 259
Sundinisagod107.00 |
10-23-2021, 01:12 PM | #1003 | |
6634
Rep 4,145
Drives: '18 M2 6MT
10-23-2021, 11:47 PM | #1004 |
Rep 267
what type of gains can i expect from a VRSF charge pipe and VRSF 5" intercooler upgrade on a stock engine? I probably wont be tuning for another few months.
Im mainly looking for better throttle response and less turbo lag. |
10-24-2021, 10:48 AM | #1005 |
378
Rep 348
Peak power maybe 5-10whp? More importantly it’ll help prevent it from losing power up to during multiple pulls.
BallHog5873174.50 |
10-24-2021, 06:20 PM | #1006 | |
Rep 201
The bigger the intercooler the more lag. The tune, down pipe, inlet pipe and diverter valve should offset the lag from a larger than stock cooler. |
BallHog5873174.50 |
10-25-2021, 09:51 AM | #1007 | |
24185
Rep 190,777
Upgrading the intercooler will make the car more consistent even on the stock tune. Depending on the ambient temp and how hard you push the vehicle, an intercooler can easily make a 20-30 whp difference. Make sure to plan long term, if you will be going stage 2 eventually you are better off getting a larger intercooler (6 or 7") Also get the charge pipe and intercooler at the same time as some vendors (like us) offer combo deals when bought together
BallHog5873174.50 |
10-25-2021, 10:35 AM | #1008 | ||
Rep 6,635
10-25-2021, 11:09 AM | #1009 |
378
Rep 348
10-25-2021, 12:32 PM | #1010 | |
Rep 267
I was planning on buying them together. And I won't go past stage 1 in this car. |
10-25-2021, 01:48 PM | #1011 |
Rep 4,140
BallHog5873174.50 mike@x-ph.com24185.00 |
10-25-2021, 01:50 PM | #1012 | |
Rep 4,140
mishutka - clear your PMs, I can’t message you back |
VisualEcho6633.50 |
