M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > LCI gaugle cluster Speedo needle below zero
      04-03-2024, 07:36 PM   #1
willym04
Unhappy LCI gaugle cluster Speedo needle below zero
Hello as the title states on my 2018 m2 the speedo needle is resting below zero.
This happened after I opened it up to adjust the tach as its a canadian car and the person who imported replaced the insert poorly.
However, now I am having this issue.
Is there away to reset the position?
I've tried doing it manually but when the car is started the needle sweeps to below zero.
      04-04-2024, 02:02 AM   #2
bmwstephen
Drives: 95' M3, 17' M2
when the car starts up at ignition, do you see all the needles turn all the way clockwise before resetting back to its original position? It is a standard test procedure all cars do on startup.
If not, you likely need to recalibrate it or replace the gear.
      04-04-2024, 05:26 PM   #3
willym04
Well I figured it out if anyone else ever has this issue.
You just turn the needle counterclockwise till you feel resistance then keep going and set it at the 0 position
