M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > *** M2 Competition (S55) support now available with bootmod3 ***
      10-28-2019, 10:54 PM   #661
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Originally Posted by Bimmer28312 View Post
What I don't understand is all these shops who sell and tune with BM3 can't bench flash it on their own??
I think they can but people don't want to yank their ECU's out and deal with it.
      10-28-2019, 11:23 PM   #662
Bimmer28312
Bimmer28312's Avatar
Drives: BMW N55 335xi
Don't mind the removal what I do mind and probably most people is shipping away their DME across the pond.
      10-29-2019, 12:37 AM   #663
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
Go with ECUTek then. Fuck it.
      10-29-2019, 02:30 AM   #664
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
There is no need to remove the ecu anymore [IMG][/IMG]
      10-29-2019, 03:21 AM   #665
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Remember most of these so called generic "tuners" or "tuning shops" are just product re-sellers and often not specialist in much at all (except talking BS mostly).
Using BM3 is easy, but bench flashing is a few levels up from that and most shops dont have the time or equipment expertise to get into that.
No need if you take your car to a place that will "bench" flash, it can be done in situ, but you need to find somewhere first....
Poochie9104.50
      10-29-2019, 07:41 AM   #666
Megator
Megator's Avatar
518
Drives: M2 Competition
LOL love it. Yeah I don't want to take crap appart if it does not need to be.
I hope it gets cracked b4 my warranty runs out!
      10-29-2019, 10:38 AM   #667
Trapperj
Drives: M2C
Perhaps across the pond is a figure of speech, but not as far as across the Atlantic. Shipping from Ontario (PTF home base) to me in Eastern TN was only two days via DHL. Anyone that’s considering just make certain all the documents are in order. No need to be held up by customs needlessly.
      10-29-2019, 11:32 AM   #668
CosmosMpower
2051
How does bench flash work if you don't need to remove the ECU? Do they plug into the obd2 port to unlock the ECU and flash it?
      10-29-2019, 05:27 PM   #669
CSL335i
Hungary
207
Drives: M2 and...
When bench flashing, the tuner connects its device cable directly to the selected ECU connector pins and apply a backdoor in Tricore processor to read and write the selected areas.
      10-29-2019, 09:10 PM   #670
CosmosMpower
2051
You don't have to remove it to access the pins?
      10-30-2019, 03:04 AM   #671
doughboy
doughboy's Avatar
1545
Look at the picture in post 668 above.
The term "bench flash" just means a direct connection to the ECU while it's disconnected from the car.
Of course if you want to post the ECU then you need to remove it, but if you take the car to the tuner then they can just unplug the ECU connectors and directly connect that way.
      10-30-2019, 06:48 PM   #672
brad65ford
Drives: 2022 M3
Originally Posted by brad65ford View Post
Saw the update on all the OTS tunes. Wanting to do the stage 2 93 soon and see if I picked us some measurable ET time drop ;-)
Good questions LOL. Flashed the new updates for stage 2 93 today. Not sure if its my mind but it feels like it picked up some torque downstairs. There is a difference in burble sound which is hard to explain even with the same settings as before,... I like it. Not sure why but the gts roar didn't work for me, will attempt tomorrow..
      10-30-2019, 09:00 PM   #673
AM9
Drives: M2C
GTS roar sounds like its less of a roar now but still more than stock to me on this last update.
      10-30-2019, 10:24 PM   #674
Kelvin1000
Drives: 2019 BMW M2 Competition MT Hoc
I have been noticing some throttle inconsistencies but only under the following conditions:
Sport Plus
Second gear (6MT)
When applying 50% throttle between 4,000 and 6,000 RPMs
Anyone else experiencing this?
Otherwise, the version 9.0 maps are very smooth and powerful.
      10-31-2019, 10:50 AM   #675
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
Sport Plus
Second gear (6MT)
Seems similar to this post
https://www.bimmerpost.com/forums/sh...php?p=25402957
      10-31-2019, 04:27 PM   #676
AlpsRider
AlpsRider's Avatar
2865
Heads up:
Once you flash one of the new tunes with the extra cooling feature and select extra cooling, you won't be able to turn it off and have the same cooling behavior. It will either be all sport modes extra cooling or all sport modes normal. Extra cooling in just Sport+ won't work. If you flash the stock tune then all is as it was with just Sport+ having extra cooling. Flashing back to a tune with the cooling feature will make sport modes be all cooling or all normal again.
      10-31-2019, 09:02 PM   #677
Kelvin1000
Sport Plus
Second gear (6MT)
Sport Plus
Second gear (6MT)
Anyone else have these oscillations on Sport+ around 5,000 RPMs at half throttle?
      11-01-2019, 09:29 AM   #678
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Sport Plus
Second gear (6MT)
Sport Plus
Second gear (6MT)
I am having same issue. Sport plus, MDM, 4th-5th gear between 4000 to 5500.
      11-01-2019, 10:36 AM   #679
Kelvin1000
I went back to the old Stage 1 93 Octane Version 8.7 and the 50% partial "throttle oscillation" around 5K RPMs in Sport+ went away completely.
However, Version 8.7 is not as smooth at lower RPMs as Version 9.0 which seems to have an improved torque delivery curve.
Hopefully PTF can address this on Version 9.1 since it would make the tune just about perfect.
      11-01-2019, 10:44 AM   #680
CosmosMpower
2051
Man seems like customers are doing beta testing for their tunes, kind of glad I can't obd2 flash BM3 after reading stuff like this.
      11-01-2019, 11:33 AM   #681
Kelvin1000
Don't get me wrong, both Stage 1 Versions (8.7 and 9.0) are worlds apart from stock and easily the best upgrade you can do to these cars.
Even the stock software power delivery is a bit jerky on Sport+ and the folks at PTF will continue to improve the tune and add new features.
The BM3 platform turns this car into an absolutely monster!
      11-01-2019, 12:33 PM   #682
AlpsRider
AlpsRider's Avatar
2865
Yes, I tire eating beast.
Tags
bm3, bootmod3, m2 competition
