08-16-2021, 08:51 AM | #45 |
24199
Rep 190,807
Congrats!!!
Im happy to hear you finally got it fixed. Sounds great BTW!!
No_curebimmer637.50 |
08-16-2021, 10:26 AM | #46 |
Rep 35
Unfortunately I live in NYC and 70% of my driving would be within drone range.
08-16-2021, 01:45 PM | #47 | ||
~Spyder
638
Rep 870
Drives: '19 M2C Hockenheim 6sp
PS I highly recommend welding all connection points…leaves zero room for error or something hitting. I read quite a few EL and/or axleback customers went back to the install shop because something was rattling or moving…welding will eliminate that
Skål från Sverige...via Texas y-all
08-16-2021, 01:54 PM | #48 | ||
~Spyder
638
Rep 870
AA EL (non resonated) improved the upon the OEM exhaust ~50-60%. But the Dinan axle back brought it to life…i am looking for every excuse to drive it. The exhaust is GLORIOUS! What axleback did you end up with pairing the AA El with? Remus, AA MPE?
08-16-2021, 06:26 PM | #49 |
Rep 2,353
Sounds fantastic! Definitely will be my setup, resonated version though. What is your best guess on the total weight savings over stock? Just curious..
BSM ///M2cs, 6spd
08-16-2021, 06:32 PM | #50 | |
~Spyder
638
Rep 870
Weight-wise, I would venture the Dinan is ~ 1/2 the weight of the OEM, so probably about 30lbs of weight savings ??? I could easily pick up the Dinan with one hand Note: if you go resonated EL, your sound will be more muted than what you hear in my setup. I don't particularly think my setup is loud, far from it; loud enough in a gentlemany-aggressive way.
08-16-2021, 07:12 PM | #51 | |
Rep 2,353
I love the clean sound your car makes. I am not a fan of a super loud cabin. I bet the resonated AA would still sound good. Worst case would be to spend a few extra $$ and get the AA pipes to replace the resonators.
BSM ///M2cs, 6spd
08-17-2021, 10:55 AM | #52 | ||
~Spyder
638
Rep 870
I am not sure if I noted this: I have coded out both ASD (BimmerCode) and burbles (BimmerLink). The interior cabin sound is great: I get to hear every nuance my engine and exhaust make. In Sport+, it's about 30-40% louder than OEM, and in efficient is about as loud as stock Sport+. It's 100% livable (it's not a hybrid, Camry or something ) It's a great addition overall, inside and out! Personally, it's not too loud, and I wouldn't choose the resonated EL…the dB/loudness level is perfect for a sports car that can be a DD and/or track focused. Having experienced this, I would be upset to have it any quieter
M3R12168.50 |
08-17-2021, 12:35 PM | #53 | |
Rep 1,681
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
M3R12168.50 |
08-17-2021, 12:56 PM | #54 |
Rep 35
Post videos when you can, this may be my combo as well.
08-17-2021, 01:06 PM | #55 | ||
~Spyder
638
Rep 870
FYI, if you find the resonated EL too quiet, I believe AA makes just the connection sections with or w/o resonators. Are you going to weld the connection points or will install with included clamps hw?
Nicname351.00 |
08-17-2021, 01:10 PM | #56 |
Rep 1,681
There will be some welding around the connecting pipes between the exhaust and the EL. They've done a few equal lengths and no one has complained of any rattling/unwanted sounds so fingers crossed.
Current: ///M2C
08-17-2021, 01:21 PM | #57 | |
~Spyder
638
Rep 870
My recommendation (see attached). Marked pictures before Dinan install, using AA supplied hardware. - green mark-up: are solid, just spot weld - red mark-ups: no clamps, only weld
inTgr8r2431.50 |
08-17-2021, 06:16 PM | #58 |
Rep 73
Looks and sounds amazing. The stock muffler is the main cause of the tin can sound and I can't wait to get rid of it. Ordered a meisterschaft titanium axleback with an estimated date in september. Hoping to do similar custom fabrication. of course can't weld it completely because titanium and steel don't mix, or does it. The vibrations tin can sound should be a thing of the past! I really recommend anyone who wants the EL midpipe to ditch the stock muffler.
Drew41561.50 No_curebimmer637.50 |
08-17-2021, 06:22 PM | #59 | |
~Spyder
638
Rep 870
I don't think titanium- SS welding could be done by a regular muffler shop, so you may have to resort to the included clamping system.
atruong24732.00 |
08-17-2021, 06:41 PM | #60 |
Rep 2,353
This is the exact set up i decided to go with. I do not want loud, the stock DB's are fine. A change in sound will be great, however my motivation is to remove the ball sack and not cut up the factory exhaust.
BSM ///M2cs, 6spd
08-18-2021, 02:08 PM | #61 | |
2432
Rep 11,667
This is definitely the way I plan to go. |
08-18-2021, 04:57 PM | #62 | |
~Spyder
638
Rep 870
1. first bought & installed non resonated AA EL, and lived with it for about 1.5 months - exhaust improvements max 50%, but also experienced 30% more raspiness/tinny noises than stock, especially < 2k RPM. I became laser focused on fixing that, it was that annoying - some weight savings (dont have any empirical data) - faster/easier acceleration 2. Installed Dinan axle-back (although it is sold as a mid-catback, comes with the x-pipe) - exhaust improvements…full/max/dope level!!! - removed all traces of raspiness I previously had with AA EL only - deepened the sound DRASTICALLY - cleaned it for all RPM levels - maximized the overall enjoyment factor of my car - saved ~30 lbs vs OEM muffler - similar acceleration gains vs the AA EL Just the other day, I lingered by the rear end and listened to the exhaust while idling: now it has a fantastic growl that neither OEM nor AA EL by itself produced. Just listening to this, one would know this M2C means real business A few more (very subjective) notes I would like to share: - didn't particularly liked the higher pitch exhaust the Remus makes (nor the higher cost), so that crossed off my list - I listened to the AA valved exhaust posted here: https://f87.bimmerpost.com/forums/sh....php?t=1845670. To my ears, while definitely louder and somewhat more aggressive, the AA EL + AA axleback still exhibited similar raspiness as the AA EL only, so that didn't seem to help with my 'zero raspiness' goal - didn't consider others like MPE, Akra,
atruong24732.00 |
08-18-2021, 05:00 PM | #63 | ||
~Spyder
638
Rep 870
I am happy to answer and install questions, and gladly endorse Dinan axleback + non res AA EL exhaust setup for the S55.
08-21-2021, 11:50 AM | #64 |
Rep 606
Drives: M2C
Nice!! Glad you finally got a setup you love.
So just to confirm, you think loudness did not change between EL + OEM muffler vs EL + Dinan muffler? Instead it just helped you (1) eliminate the rasp you used to encounter and (2) get a deeper tone across all modes but esp in spots/sports+ ? |
08-21-2021, 02:03 PM | #65 | |
~Spyder
638
Rep 870
If I were to guesstimate: - efficient/non res AA EL/Dinan muffler is about as loud as Sport +/non res AA EL/ stock muffler - as I mentioned above, with the Dinan axelback and AA EL, the overall note is much lower pitch/growl/frequency than either full stock or AA EL+ stock muffler Some scientific blah blah write up (some may find it useful. Well, maybe) LOUDNESS (dB) vs FREQUENCY (Hz): I am a hifi enthusiast (and engineer by trade) where I do my own in room acoustic measurements (REW, 3D imaging, full frequency response analysis, etc) - and I can tell you that our human ears have a harder time hearing lower frequencies (say < 250Hz) vs higher ones (> 250Hz) even if loudness is of same dB level. You may relate to this if you're into HT movies…most turn up the LFE/bass channels because it doesn't seem as loud as upper frequencies (of course I am not taking into consideration null points, Schroeder frequency/transition freq, room modes, subwoofer placement, x-over freq, etc…). Simplified Case E.G. (measurement taken at same reference point, same microphone) SOUND SAMPLE A : a noise/sound at 50dB (loudness) and 3500 Hz (frequency) vs SOUND SAMPLE B: noise/sound sound at 50dB and 500Hz Although both are played at the same loudness level, we will always perceive SOUND SAMPLE A as 'louder' because of its higher frequency How this is applicable here?? Non Resonated AA EL + Dinan axleback has an innate lower frequency growl (achieved internally by baffles and/or resonators) , and it will be perceived as 'quieter' than say other setups that are sporting AA EL + Remus/MPE/Akra axle backs. Hope the above proved useful…especially since I read MANY comments on this forum stating that the Remus exhausts are typically 'louder'….true, they may be perceived as such simply because they have a higher pitch/frequency than most other axlebacks. They may still exhibit a louder dB level, but loudness should always be in the same context as frequency.
08-21-2021, 02:11 PM | #66 |
~Spyder
638
Rep 870
You can easily discern between the Efficient vs Sport vs Sport+ towards the end of my parking lot video, the stationary revs (sorry I am not into social media, video editing SW etc) but the commentary would go like this:
- after full stop: a few Sport + revs - switched to efficient for a couple of revs (noticeably quieter) - next up was Sport…growling increased - last was Sport + Biggest delta was between Efficient vs Sport. Sport vs Sport+ wasn't as evident.
