01-12-2021, 08:48 PM | #1 |
Rep 2
Brand new M2 Comp Radiator
Hi guys,
I'm a brand new M2 Comp owner from Sydney and, whilst driving and breaking the car in, got some splat on the front grille and radiator inside (Pics attached for your reference). Just wanting to clean it off I used the garden hose on a single jet stream setting (not overly strong but some pressure is there) right in front of the grill to find out my radiator is probably ruined now. After doing some research and a shit tonne of stressing. My questions are: - Is this anything to be worried about ? After some research, I've seen people freak out over one or two bends and obviously compared to mine, are nothing. - Upon initial view, is this enough damage (if any) to affect performance at all and the radiators cooling ability ? - Worst comes to worst, would it be expensive to replace ? Any advice would be highly appreciated thank you. |
01-13-2021, 07:06 AM | #2 | |
Rep 1,643
01-13-2021, 08:20 AM | #4 |
Rep 40
BTW you can always put a guard for the lower heat exchangers like I did since day 1, this is a way much more effective than the outer wire meshes some people been installing.
You will need to make a template and cut these to measure but the final result looks great Allstar ALL30158 - Pantalla de radiador (19" alto x 26" ancho x 1/2" gruesa) https://www.amazon.com/dp/B006K8IP6M..._lcW.FbWPWQWJS |
01-13-2021, 07:44 PM | #6 |
Rep 1,643
01-14-2021, 03:29 PM | #7 |
Rep 7,343
It's fine, bent fins are normal when you drive a car forawhile. Like others have said use a radiator fin comb, or if you are patient enough use a small plastic or metal screw driver to straighten the fins - be very patient with this if you dont want to punch a hole through the radiator.
