12-31-2020, 10:29 PM | #1 |
Remove Before Flight
6822
Rep 1,611
Can I use OEM wheel bolts w/ a 5mm spacer?
Enquiring minds want to know.
Can I use the OEM BMW wheel bolts (and lock bolt) on the front wheels of my 2020 M2C if I use a 5mm/.2" spacer? I'd figure 5mm/.2" is probably not a thing, but I figured I'd double-check w/ The Collective. Thanks-- R. |
12-31-2020, 11:07 PM | #2 | |
Rep 2,526
In reality you probably could. But I would highly caution against it. |
01-01-2021, 08:38 AM | #3 |
6822
Rep 1,611
I didn't realize that they were so easy to find. That's simple enough.
Suggestions on where to find them inexpensively? Or, what the OEM M2C dimensions are for a wheel lug? Of course, I suppose that this makes getting a wheel lock that's 5mm longer and matches the other locks problematic. Grr. TIA-- R. Last edited by flybigjet; 01-01-2021 at 08:53 AM.. |
01-01-2021, 09:06 AM | #4 | |
Rep 2,526
Where did you get the spacers from? They generally come with extended lugs. You can find the extended lug bolts all over. Here's some from bimmerworld https://www.bimmerworld.com/Wheels-T...Bolts-M14.html You'll want ones that are M14x1.25. |
flybigjet6822.00 |
01-01-2021, 09:51 AM | #5 |
6822
Rep 1,611
I ordered the spacers from Apex with the wheels. I'll see what they have in the way of lugs and locks since I'm on back order anyway.
Thanks!
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
01-01-2021, 10:38 AM | #6 |
Rep 2,526
Apex sells stud kits or extended lugs. Reach out to them and have them added to your order. They'll know exactly what you need.
