12-30-2020, 08:24 AM | #23 |
7484
Rep 12,305
You most likely have a bad battery but it is still good practice to get a battery tender if you're not going to drive it over a week at a time. This is not just a BMW thing and cannot be compared to an old Acura TL. These battery tenders are not overly expensive
12-31-2020, 10:48 AM | #24 | |
Rep 249
I don't drive my car much (was ED, put 800 miles on in Europe, and only 1,200 since being back in the states), but it is kept on a trickle charger for at least a day or two if I'm not driving it for at least a week or 2. I started getting the "battery discharged, please start engine" notification almost every time I started the car - though never had any actual issues with it not starting back up or driveability/power issues when this notification comes up. Took the car in for it's second oil change (first oil change since the 1,200 break-in service), and mentioned the battery drain issue to the dealer. They ended up testing the battery, and also noticed that one of the battery cables was apparently loose, and said that the battery was good and didn't need to be replaced. This was a couple months back, and have driven the car with a similar frequency since and have not received the message again. That being said, one of my good friends with an M2C daily drives his, but still gets the battery drain message every once in a while, so I really don't know. I also find it hard to believe that a loose battery cable could've been the culprit for me, but who knows? Maybe your battery cable is also loose and that's actually what's causing it. What trickle charge do you use? FWIW, here's the one I purchased a couple years back: https://www.amazon.com/BMW-Advanced-...113381&sr=8-25 |
12-31-2020, 11:43 AM | #26 |
Rep 438
@ROASTM
I have it on the charger as we speak lol Ctek charger is what I have . Also another thing to add. My car was on the lot from new for 4 months . It didn't get driven much so before I even got the car I don't think the battery was full. Plus it has not been driven much in the past 4-5 months too . |
12-31-2020, 12:07 PM | #27 |
Rep 8,972
Sounds like you have a defective battery, so get it checked.
Trickle charger shouldn't be necessary unless we're talking extended non-useage like over winter storage. But for what it costs, a Ctek is a great investment anyway and will sort out the battery if it is a little tired but not completely f88ked. |
12-31-2020, 12:57 PM | #28 |
Rep 438
It just finished charging , full voltage 12.38volts .
I might use the reconditioned method , but since I'm due in 6 weeks I will wait to see what the dealer says first . |
02-13-2021, 11:24 AM | #29 |
381
Rep 731
Low Battery
Anyone know if these batteries can have distilled water added to them like older batteries? My battery is 42 months old and constantly informs me it is low on charge?
At a Point above 7,000 RPM.
02-13-2021, 02:40 PM | #30 | |
Rep 7,413
If your battery keeps showing as discharged I have a few recommendations: 1) replace it with another agm battery of the same specs then code it. 2) pull the battery and try an agm reconditioning cycle with a ctek, I can't recall correctly if agms can be reconditioned so double check before you do this.
chief1richard381.00 |
02-13-2021, 03:45 PM | #31 |
Rep 73
My 997 drains the battery - very slow to turn over (crank) after more than 2 weeks without driving or being on a trickle, but it has a Tracker and is parked 2 floors down under solid concrete, so constantly trying to send a signal...
I suspect the iDrive/ Connected tracking on the M2 will also drain the battery in a similar way, but also have the M2C on a CTEK trickle charger as leaving any car battery for 2+ weeks without a trickle is not great/ shortens the life, even if cranking amps sufficient to start it. I've permanently wired a quick hook up CTEK connector in the boot battery (not bypassing the battery mgmt system) with an extension so I can close the boot lid without damaging the seal (the extension is a narrow gauge cable). Maserati GT drain is way worse than the Porsche, but again has a tracker (and Italian electrics ) CTEK MXS 5.0 is the way forward! |
02-13-2021, 03:51 PM | #32 | |
Rep 7,413
Personally I prefer how I hooked it up under the hood, that way you never have to open anything to access the CTEK connector, and it is also water proof in this area. https://f87.bimmerpost.com/forums/sh....php?t=1756713
02-13-2021, 04:25 PM | #33 | ||
Rep 73
Appreciate checking / your follow up. Cheers Last edited by JustDrifting; 02-13-2021 at 05:42 PM.. |
02-15-2021, 02:08 AM | #34 | ||
Rep 98
02-15-2021, 02:20 AM | #35 | |
Rep 7,413
If that is indeed the case then replacement would be the option. Also this just came to mind but I would scan the car for fault codes before replacing the battery. Make sure there aren't errors that is causing excessive battery drain.
02-18-2021, 04:00 PM | #36 |
Rep 7,413
There's a TSB for bmw m2 battery discharge issues: https://www.carproblemzoo.com/tsb/bm...017-bmw-m2.php
Scroll down a little bit and you will see it.
02-18-2021, 07:15 PM | #38 | |
Rep 7,413
So with a TSB if the dealer says that your symptoms don't match no repairs will be done.
02-18-2021, 08:50 PM | #39 |
a coffee drinker
96
Rep 162
Ccm displayed “increased battery drain” caused by controller
SIB 61 05 20
CCM DISPLAYED “INCREASED BATTERY DRAIN” CAUSED BY CONTROLLER Hmm... see attached. I am not sure what to make of the problem and the solution. Hope it helps someone. |
Pray for Mojo429.50 |
