12-17-2020, 10:28 AM | #1 |
Rep 438
Battery still not charged after 120km
I have seen a lot of complaints about the battery discharge warning if you don't drive the car enough .
I haven't driven the car for 10 days . Today it started up fine but I got the "discharge" warning . I went for a 120km drive on the highway got back after driving it for an hour and after I turned off the car ...I still got the battery "discharge " .. Yes go to the dealer I know but anybody having the discharge warning after driving for over an hour ? Is this just the nature of the car ? I miss old cars let me tell you ...my old Acura TL could sit in -30 for a month and never have a battery issue . |
12-17-2020, 11:49 AM | #2 |
Rep 438
After talking to a dealer they said bmws are notorious for this , especially in colder weather and the car must be driven 45mins to an hour at least twice a week to keep the battery happy .
Love this car , but that's my only gripe about it ! |
12-17-2020, 11:58 AM | #3 |
Rep 359
The battery doesn't charge all the time just because the wheels are turning. There is an indicator that let's you know when it is charging. It only charges when there is no gas input so on the highway, unless you're going downhill for a stretch you tend to be constantly on the gas to maintain speed.
12-17-2020, 12:18 PM | #4 |
Rep 438
Ok I will pay attention to this ...so you technically will get a better charge letting it idle then on the gas driving ...interesting .
12-17-2020, 08:55 PM | #5 |
Rep 3,842
If you don't drive your car for 10 days, especially in cold months, it's best to get a trickle charger. Letting the battery drain like that will decrease the life of the battery.
12-17-2020, 09:56 PM | #6 |
Rep 438
This would be the first car that I would need to charge for not driving it for 10 days .
Granted I never had a car that used up so much juice on accessories . Am I confused or do most other cars constantly charge the battery from the alternator the whole time the car is running ? I mean weather I used the gas peddle or not the car was on for over an hour . I'm going out again tomorrow , if I get the same warning after driving all day she's going in for a new battery or alternator check. |
12-17-2020, 11:06 PM | #7 |
Rep 359
Not idle. Hitting the brake initiates the charger. You nee to tap the brake and let it cruise without hitting the gas and the blue gauge lights up which means it's charging. Hitting the gas turns the blue gauge red and moves to the right which means it's not charging. They did this for performance.
12-18-2020, 04:46 AM | #9 | |
Rep 9,709
The reason modern BMW's are more sensitive to being left for weeks without use is because for eco reasons, the battery is considered 'full' at 80%. This is to allow capacity for the supercharging regen events, and the fact that the last 20% takes significantly more energy to add charge. The advice to use a trickle charger is sound for the infrequent user. |
12-18-2020, 06:13 AM | #10 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
Optimate. Namaste
12-18-2020, 11:22 AM | #11 | |
Rep 359
12-18-2020, 02:17 PM | #12 | |
Rep 9,709
But yes it also has an intelligent battery charging system which can cut charge rate under hard acceleration. As well as reducing ancillary drain when battery levels are low. |
12-18-2020, 03:20 PM | #13 |
Rep 364
Drives: M2C X5M M4
The alternator charges all the time as far as I'm aware the efficient dynamics is on top of that. If you put a volt meter on your front posts and check battery voltage it should be 12.4 to 12.6 on a good battery and starting it up should push that to 13.5 to 14.5 volts
12-18-2020, 04:39 PM | #14 | |
In the Details
1810
Rep 866
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
12-18-2020, 05:48 PM | #15 | |
Rep 8,972
45 mins twice a week??? He is mad.! I often leave my M2C unused, outdoors, for weeks at a time in winter, never missed a beat on startup same as previous M6 and 335i, 330i etc. Faulty battery is not an uncommon issue... |
12-18-2020, 09:31 PM | #16 |
Rep 438
@doughboy exactly I never had a car that wouldn't start after 2 weeks so I'm going to monitor it and see how much the voltage drops after a couple days and might bite the bullet and bring it in .
12-27-2020, 12:32 PM | #17 | |
Rep 13,093
During the lockdown I drove my M2C at least once every 6 weeks for an hour or so to ensure recharging the battery.
///M is art ↔ Artemis
Robimplicit15.00 |
12-27-2020, 12:51 PM | #18 |
Rep 3,514
Take it to the dealer. My wife's X3 had a defective battery and was replaced under warranty after almost 4 years of use.
///M Power-Belgium63296.50 |
12-28-2020, 10:35 AM | #20 |
Rep 438
So I threw a multimeter on the battery yesterday after a drive and it read 12.41v.
Today less then 24 hours later the battery reads 12.08 volts 🤔 I have a scheduled service in 6 weeks , we will see what the dealer does . I will keep it posted . |
12-28-2020, 10:36 AM | #21 | |
Rep 3,842
Even if the battery has enough charge to start the car, repeated draining of the battery will substantially decrease it's lifespan. A LifePo4 battery would be a different story, but we're talking about a lead acid battery. |
12-28-2020, 11:48 AM | #22 |
ghost user
243
Rep 248
I'm not using my car at all almost all year this year. Only starting in December did I start seeing the battery discharge message. The only place the car goes is to the grocery store once every 10 days, and the grocery store is only 2km away.
So now I've started to have some drives. About one hour of driving then go to the grocery store. Now I do not get the message any more. |
