M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Michelin winter tires a fail
      12-21-2020, 01:56 PM   #23
grl.racr
grl.racr's Avatar
383
Drives: G87 M2, MK8 R, RS6 Avant
Originally Posted by MetalM2 View Post
I have the Nokian Hakkas on my car, and used them last winter. The M2 is my daily driver, and Ottawa winters are no joke. You'll love the Nokians in true winter weather, they will get you through anything except for the ridiculously deep stuff that no 2-wheel drive, relatively low-riding car should be driving in, anyway.
Awesome! I lived for a short time in MTL and my gosh, those winters are unreal haha. A real snow tire is definitely what I've been looking for, even in these milder GTA winters.. just need the car to arrive now
Previous:
M2C / GT4 / OG M2 / STi
      12-22-2020, 04:55 AM   #24
paradocs98
paradocs98's Avatar
Drives: M2C
Originally Posted by Kankles View Post
Alpins are made for parts of EU that require winter tires be mounted but rarely get any snow. So you can still drive 250kph on the autobahn when it's dry and above freezing.
Certainly seems that way. So now the M2 driver in northern climes can have four sets of wheels/tires: summer, track, performance/dry winter, and snow.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3
Kankles1484.50
      01-01-2021, 10:35 AM   #25
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Originally Posted by paradocs98 View Post
This evening in the NY metro area and suburbs we’re getting our first major snowfall in three years. I was looking forward to putting my performance winter tires to use on the M2C—Michelin Pilot Alpin PA4s in 245/265, mounted on the stock wheels. But coming home from work in 4 or so inches of fresh snow was much more of a challenge than it should have been. The car struggled for traction, getting sideways very easily with the slightest throttle, and nearly got stuck at a stoplight on a slight incline. I made it home to my driveway, where I promptly got stuck before making it into the garage.
I’ve had multiple BMWs over the years as daily drivers, all doing just fine in snow with winter tires—E46 330Ci, 545i, E60 M5, E90 M3. All rear wheel drive, all with a decent amount of power. And they did a solid job in winter conditions with performance winter tires from Dunlop (Winter Sport 3), Pirelli (Sottozero), and Bridgestone (Blizzak). But the M2C on the Michelin Pilot Alpins was a fail today. What’s been the experience of other forum members?
A square set-up 245/40/18 would work much better. There is no advantage other than looks to use a staggered Winter set-up. I live in New England which has some severe snow and have used this set-up for three years. Works better than my 4X PU. with all seasons. Wider tires do not work well driving in snow in the Winter.
At a Point above 7,000 RPM.
gsrbri559.50
      01-02-2021, 05:40 PM   #26
paradocs98
paradocs98's Avatar
Drives: M2C
Definitely. I think of rally cars that run super-skinny studded tires during ice/snow stages. And good to know that 245s work well on your M2 in snow. I can’t help but think, though, that Blizzaks or Dunlop Winter Sports would do better than these Pilot Alpins.
      01-02-2021, 10:36 PM   #27
chris719
Drives: '08 M Roadster
Performance winters are a bit better than all season, that's it. I don't think Bridgestone LM001 or Sottozero 3 etc are any better really, same category. If you really need to drive in the snow then you need a full studless category tire. I had PA3 on my Z4M and it was fine for 1-2 inches of snow, but beyond that it's questionable.
      01-03-2021, 09:17 AM   #28
chief1richard
2018 M2  [0.00]
Winter Tires
I use Winter Tires more for the softer compliant tread compound which is needed in cold climates. Many have complained about wheel Hop when putting any power down, this is the cause of that. I have never experienced wheel hop after using Winter Tires. As far as heavy snow goes, I am fortunate enough to own a Ford F-150 for those days when there is substantial snow and salty slush. The M2 is just not the right vehicle for those conditions.
      01-08-2021, 07:25 PM   #29
gsrbri
gsrbri's Avatar
Drives: F87 6MT
Just speaking from experience, M cars with snow packages are excellent on the snow. With the right tires and set up.
My 2015M4 has Blizzak LM-32 245/18 square set up. That car was unstoppable in heavy snow.
M2 is the same chassis if a smidge lighter. My M2 winter package is a Jeep GC :-)
      01-08-2021, 11:47 PM   #30
chris719
I've driven on LM-32 and LM-001 and I don't know that I'd call them unstoppable in heavy snow... but they will probably get you home if the snow is below the front lip.
      01-08-2021, 11:50 PM   #31
Davil
Davil's Avatar
6465
Originally Posted by BigKutta View Post
Originally Posted by PrinceCity View Post
Lol. I think all tires are meant for outside. I mean, I guess there are some indoor tracks, but it's rare.
I think he's referring to a mounting issue
I think there was a mounting issue at the poster's conception.
      01-09-2021, 09:39 AM   #32
Maynard
Drives: 228iX & M2C
Nokian hakkapeliitta are truly the best it gets. Especially the studded versions - I'm on 9's, think they are releasing a v.10; noisy, but it is a performance sound so I kind of like it now that I'm used to it. The new-tech studs retract some, so they don't screw up the dry traction like the old ones would have, and don't kill your driveway. No problems with black ice or pack ice, and no worse than regular snows in the wet or on dry pavement. My 228iX is the winter car, and with AWD these things feel like you could climb walls; even in wider M2 sizing and RWD you'll outperform most. If it is just for an occasional dusting, the performance winters might be fine, but if you are going to drive an M2 in full snow, these are the way to go.
gsrbri559.50
