12-11-2020, 10:45 AM | #1 |
Rep 17
Battery Charger/Tender
I did a quick search and did not find what I was looking for. Looking for recommendations on Battery Chargers/Tenders. Is it worth the money to purchase one with a BMW logo on it or not. Maybe some background, I mounted winter wheels and will drive in the cold temperatures in Michigan, but I will not drive in Snow/Salt conditions, which means there is a chance that for weeks at a time, I will not put on many miles in the coming months.
Any recommendations would be appreciated. Thanks in advance.
2020 F87 HS|Exec|6MT
Sold: 2017 Audi SQ5, 2012 F20 120d, 2011 E90 M3 6MT, 2008 Audi TT 3.2 6MT, 1999 E36 Z3M 5MT, 1966 911 RIP: 2008 E92tt 6MT |
12-11-2020, 04:52 PM | #2 |
Rep 295
I have upgraded audio and custom installed radar detection and my limited weekly driving is not enough to keep the battery charged. I got the BMW labeled CTEK and it works fine. I have a couple of Battery Tenders that I use on my other vehicles when I'm traveling and they also work well. My issue (also a good thing) is nobody else in the family drives my toys so they just sit if I'm away or unable to use.
12-11-2020, 06:41 PM | #3 |
Rep 79
Yup, Ctek is an easy score on Amazon. Expect to pay $75 to a hundo. Can spend more if u want more bells and whistles (which u probably don’t need). Will say the extended lead/quick-connect is nice for easy under hood hook up.
12-11-2020, 07:20 PM | #4 | |
Rep 2,672
12-12-2020, 07:21 AM | #7 |
Rep 5,322
Battery Tender since new. I run them on all my toys including my X7 M50i. I prefer the 4 Amp models as they have enough to even keep the two big batteries in the X7 at optimum charge.
https://www.amazon.com/Battery-Tende...dDbGljaz10cnVl I have a quick connection that goes right up be the lower windshield. I don’t even have to raise the hood when I connect. |
ROASTM163.50 |
12-14-2020, 02:37 PM | #8 |
Rep 2,475
I ran a battery tender in my last 3 BMWs when I lived in MI, MN then IL. It definitely helps keep your battery healthy and I noticed how much it helped when car sat for more than 2 weeks in cold temps.
I currently have a CTEK MXS 5.0 for the M2C. Essentially the same as Porsche and BMW branded variants. It's very versatile and has a lot of smart tech packed in. Reasonably priced on Amazon and other online retailers. Highly recommend the CTEK.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
12-14-2020, 08:24 PM | #10 |
Rep 17
Thanks for all of the feedback, I will check out the CTEKs. I imagine buying it without the BMW logo on it is the cheaper way to go.
I believe my father still has a porsche battery tender (maybe CTEK?) from his 2006 Cayman S, maybe that will also work. I will take a look.
12-15-2020, 09:27 AM | #12 |
Rep 55
I've been using my Ctek 2 years and it's been flawless up until now. Currently when the battery is fully charged, the orange light switches to green like it should be but the orange light stays on in a flickering state. Has anyone experienced this? Ctek says it's could be a sign of a defective battery. Is it possible that Ctek doesn't want to admit that I have a defective charger?
My 2018 M2 only has 21,000kms. |
12-15-2020, 02:37 PM | #13 |
Rep 139
Always discover something new on this forum.
Is there an issue with the M2C battery that necessitates a tender? Or is this specific for low mileage winter owners? |
12-15-2020, 02:52 PM | #14 |
Rep 55
I store my car in the winter. Using a battery tender will stop the battery from draining completely which will surely happen with all the electronics that exist in newer cars. My understanding is that keeping a battery fully charged will extend the life of the battery as well.
12-15-2020, 03:35 PM | #15 | ||
6634
Rep 4,145
Drives: '18 M2 6MT
01-11-2021, 01:28 PM | #16 |
Rep 266
Bringing back a slightly old post back to life. I recently purchased a Ctek Mxs 5.0. It worked great after I figured out that the suspention bolts were not a good grounding source. The Ctek sat at the stage 1-Desulfation forever. Once I changed the ground to the bolt holding down the fender brace it moved quickly to stage 3 - Bulk. So if you don't get to stage 3 right away after connecting, it's most likely you have a bad ground. After that charging took about 10hrs.
01-21-2021, 11:57 PM | #17 | |
16302
Rep 8,395
It's the best body ground under the hood, and that's exactly why it's factory installed in that location
tenkies147.00 |
01-22-2021, 05:13 PM | #18 |
Rep 266
