04-22-2020, 03:14 PM | #2421 | |
Rep 8,970
Anyhow I used this recommended BT OBD dongle for Bimmercode, works perfectly and fast too. Also comes with basic diagnostic tools that work on all cars so I use it on all our cars. Merc, VW, Audi, Honda, Peugeot etc https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1 AFAIK K+DCAN cables are for E series and older? For Esys and "proper" coding you need a ENET-OBD cable as per all F&G series cars. |
Venom375.00 |
04-22-2020, 04:41 PM | #2422 | |
Rep 2,388
Drives: M2 Competition
Being in Cali and having the social distancing and wfh in effect, I have had much more time to drive the fun car(m2c) but realized how much of a literal headache I get with the fake sound. Thank you for the link, ordering now! |
04-22-2020, 05:11 PM | #2423 | |
Rep 1,466
This is the reason you cannot use an ENET cable, and you need a different dongle. If you want to use your E-NET cable and you have time to learn (due to Covid), download a copy of E-Sys and do your coding the right way... the safe way... with Ethernet to your laptop.
2018 ///M2 LCI, LBB, 6MT...
04-22-2020, 05:24 PM | #2424 | |
Rep 7,431
More proof that a wireless connection is perfectly fine is that BM3, MHD, and ECUtek all offer wireless flashing capabilities. BMW's own ICOM system offers wireless flashing of the car as well. Successful read/writing to the ECU's is all dependent on connection stability which falls on reliability of the wireless connector. Enet is typically the most stable and reliable since it is just a cable, but that is not to say a high quality wireless adapter cannot be just as reliable. Also note I have experienced crap quality ENET cables from China before where the wires were all bare inside of the connector which could have led to short circuits.
04-22-2020, 06:27 PM | #2425 | ||
Rep 1,466
My point was more that E-Net uses Ethernet / IP as the communication protocol, which has quite a bit of checking for packet loss etc. Whatever Bimmercode is using isn't IP (I asked the developer about this in the past), and that made it inherently slower, which lead to the failure in my case (a time out because coding was taking too long). Quote:
I believe, but don't have first had experience, that MHD and ECUtek whilst wireless use WiFi and therefore IP, rather than the Bimmercode approach.
04-22-2020, 07:47 PM | #2426 | |
Rep 7,431
Oh I didn't know BM3 didn't flash over wifi, I thought that's what the wireless agent was for. Enet to the car and wifi to your phone. Ecutek uses bluetooth iirc, if you option for their ecutek connect or whatever it is called.
04-22-2020, 10:48 PM | #2427 | |
Rep 1,466
04-23-2020, 12:50 AM | #2428 |
Rep 7,431
It still does on my Bluetooth adapter. But not on my MHD adapter.
04-24-2020, 09:35 AM | #2429 | |
Rep 183
https://burgertuning.com/products/mh...30318091141235 So it will work with Bimmercode? |
04-24-2020, 09:47 AM | #2430 | |
Rep 183
04-24-2020, 02:25 PM | #2431 | |
Rep 7,431
04-25-2020, 07:07 AM | #2432 |
Rep 126
Today i receive my OBD adapter for bimmercode. The first things i wanna code is asd off and start/stop memory active and seatbelt gong.
The rest i will see after a while Can i code all these things at once or do them seperatly?
@Rub1con76
04-25-2020, 07:32 AM | #2433 |
Rep 7,431
If it's in the same module then yes, iirc they're I'm different modules so you gotta do it one by one.
04-27-2020, 10:30 AM | #2434 | |
Rep 919
Drives: F30 328d Sport Line
I made the mistake of trying to change parameters across multiple modules without coding them separately, so thought I would add detail here. |
4
04-27-2020, 12:01 PM | #2435 | |
Rep 7,431
04-27-2020, 01:32 PM | #2436 |
Remove Before Flight
6825
Rep 1,611
Ok guys-- almost 2500 posts on this thread and I'm sure there's maybe 1-2 of them that might might answer my question.
Simple question: For not doing *advanced* coding-- Carly or Bimmercode? What are the differences? Other than Carly requiring a Carly-Specific OBD adapter, they sure seem to do about the same thing. What am I missing? TIA-- R. |
04-27-2020, 01:39 PM | #2437 | |
Rep 919
https://blog.uobdii.com/bmw-coding-e...vs-bimmercode/ |
flybigjet6825.00 |
04-27-2020, 01:44 PM | #2438 |
6825
Rep 1,611
04-27-2020, 01:53 PM | #2439 | |
Rep 919
I've had great success with BimmerCode, absolutely no issues with my F30. I do not personally have experience with Carly but the overall reviews are positive. There are also many YouTube video tutorials for BimmerCode not to mention a wealth of knowledge on Bimmerpost. |
04-27-2020, 02:03 PM | #2440 | |
6825
Rep 1,611
Not sure what Carly does that Bimmercode doesn't and vice versa. I got an OBD reader from Amazon, but I can still return it. I was planning on Bimmercode, but I didn't realize that Carly requires a proprietary OBD reader. I guess the simple question is: What does Carly do that Bimmercode doesn't, and/or what does Bimmercode do that Carly doesn't? This is WAY to frustrating than it should be. Thanks again. R. |
haagm58809.50 |
04-27-2020, 02:09 PM | #2441 | ||
Rep 919
According to the website I referenced above, Carly is an older platform and was developed for E gen cars and newer, whereas BimmerCode was developed for F series cars and newer. BimmerCode is very easy to use, since you already have the OBD2 adapter, I'd start there. |
04-27-2020, 02:57 PM | #2442 | |
6825
Rep 1,611
R. |
