02-14-2020, 08:18 PM | #1 |
Rep 21
KW v3 Rear Drop Height Inconsistencies
Edit: Disregard, I'm an idiot.
Hey guys, I recently put in a set of KW v3 coilovers on my M2C and have been in the process of dialing in the ride height. One thing I noticed was that the rear drop has not correlated at all to the specs that KW provides in their instructions. For example, they mention the rear measurement on the adjustment thread (see below) to be between 15mm-35mm (which would be 1.8"-0.8" drop, respectively) I set it at the lowest setting (15mm) assuming I would get a 1.8" drop, however I only saw ~0.85". Went from 14.1" wheel hub to fender distance to about 13.25". The fronts I've had no issues with & everything seems to be in-line with the specs in the instructions. Wondering if anyone else here ran into this same problem with their KWs? Not sure what I can do to go lower for the rears at this point.
02-14-2020, 08:20 PM | #2 |
Rep 269
From what I understand the drop takes time to settle in, more or less "break in". The springs will continue to settle and lower as you drive for the first few hundred miles or so.
Please correct me if I am wrong as I haven't bought KW coilovers yet but have been looking into them. |
02-14-2020, 08:35 PM | #3 | |
Rep 21
02-16-2020, 01:28 PM | #6 |
Rep 21
02-16-2020, 01:58 PM | #7 |
844
Rep 1,962
There may be a few installation issues, based on these pictures?
I think you're meant to take the steel cups at the top out before fitting the adjusters and main springs (helper springs and platforms go at the bottom as shown). |
VFK_by_Midnight78.50 |
02-16-2020, 02:52 PM | #8 |
Rep 21
I think you might be right here, the rubber housing at the top might be the issue. I'll see if I can't get that out, hopefully that'll solve the problem.
02-21-2020, 04:03 PM | #9 | |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
02-21-2020, 10:48 PM | #10 |
Rep 21
Yeah, I need to re-learn how to read instructions.
02-26-2020, 05:28 PM | #11 |
Rep 5,728
Drives: 2019 M2 Competition
