M2 Technical Topics > Cosmetic Modifications > LED turn signal strips causing hyperflash
      01-04-2020, 12:28 PM   #1
M FUELED
M FUELED's Avatar
Drives: 2017 BMW M2
I purchased the hex halo rings and switchback eyebrow from bavgruppe, along with demon eyes. They sent me all the harnesses required. I’m having a local shop do the install for me. They’ve successfully installed the halos and eyebrows. The shop also went ahead and deleted my stock Amber halogen bulb, built a small “wall” there to place two LED strips as a turn signal. These LED strips are also switchback so they match the switchback eyebrow. The only problem is that the LED strips hyper blink. He’s using resistors but that’s not solving anything. Any thoughts on this?
      01-05-2020, 10:38 AM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
resistors won't work. I think you need to code your car to LED turn signals using bimmercode and then you should be ok.
      01-09-2020, 03:50 PM   #3
RossBMWZseries
Drives: '11 E92 328i LCI & '06 Z4MR
Is this something you've heard of before? If so, is Carly capable of this or would he have to use bimmercode?
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
1998 BMW Z3 Roadster 1.9L E36 SOLD
      01-09-2020, 04:02 PM   #4
nioh_lbbm2
nioh_lbbm2's Avatar
1717
I don't know about Carly since I don't use it but BimmerCode can change from "Bulb" to "LED"
      01-09-2020, 04:04 PM   #5
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
See https://www.pelicanparts.com/techart...eplacement.htm
Bimmercode allows you to code the type of lamp to LED, which eliminates the hyperflashing issue.
      01-11-2020, 10:02 PM   #6
RossBMWZseries
Great stuff guys, thank you!
      01-15-2020, 04:23 PM   #7
M FUELED
M FUELED's Avatar
Drives: 2017 BMW M2
Thanks for all the help guys!
No hyper flashing on the final product.
Here are some before and after pictures of my headlights
Appreciate 4
nioh_lbbm21716.50
epic133.50
Dabozo624.50
      01-17-2020, 06:32 PM   #8
GeraldM2
Drives: BMW M2 (F87) LBB 6MT
Can you send a link for where you got those headlights? did u reuse the OEM housing?! They look amazing!!
      01-27-2020, 09:52 PM   #9
M FUELED
M FUELED's Avatar
Drives: 2017 BMW M2
Hey sorry for the late reply, just saw this.
They’re from bavgruppedesign.com except for the two LED strips on the side used as running lamp and turn signals. Those I got from the shop where I got them installed.
It is the OEM housing but the side where the turn signal bulb is located was completely removed so that a painted black glass could be fitted in there in order to install the LED strips on it. The housing was painted black as well since I wasn’t a fan of the chrome/silver housing.
