10-10-2019, 03:50 PM | #111 |
Rep 3,842
Sort of realated...Almost everytime I do a jet wash near the passenger door handle my passenger seat goes all the way back to the rear seats by itself. One day I didn't put it back up. When I came home I had some splainin' to do.
10-10-2019, 10:52 PM | #112 | |
Rep 1,148
Also, the dealer confirmed that the TSB (or SIB or whatever they call them in BMW-land) is STILL inexplicably only for 2016 & 2017 model years - incredible that BMW never added 2018 to it since it's apparently so common (even if we only have anecdotal evidence around here).
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone) |
10-11-2019, 07:43 AM | #113 |
Rep 177
Took my new to me (less than a week) 2018 into dealer for left turn signal fault. They are replacing both right now, mine would pop up every other day
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig |
11-02-2019, 10:09 AM | #115 |
Opus Angelus
423
Rep 1,264
Took mine in for oil service. Told my SA that I was getting the error message. They took the light out and their determination was a kinked wire was causing it. Said they fixed, have not gotten the error message again yet.
11-02-2019, 07:04 PM | #116 |
Rep 443
Same exact experience for me
2018 F87 LCI gone but not forgotten
2021 G80 6MT BSM |
11-02-2019, 07:08 PM | #117 |
6629
Rep 4,145
Drives: '18 M2 6MT
Dealer just replaced my right side tail lamp assembly. 2018 with 10,000 miles.
11-03-2019, 11:55 PM | #118 |
Rep 677
I had both of mine replaced at 15,000kms. I had intermittent issues on the right side for a couple of months and the left one triggered the error once. Thankfully the dealership were good about replacing both.
11-04-2019, 01:17 AM | #119 |
Rep 447
2018 M2 with 27k miles, just had the RR taillight replaced.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
11-04-2019, 01:08 PM | #120 |
Rep 324
Got the right one replaced a few weeks ago. Now having issues with the left one lol. Annoying, but better get this out of the way now than when the warranty runs out.
11-16-2019, 09:11 AM | #121 |
Opus Angelus
423
Rep 1,264
It's come back. And it looks like the water explanation must be correct. It was the day after I washed it with a pressure washer.
11-16-2019, 11:42 AM | #123 | |
Luxury at the redline :)
9103
Rep 7,563
It's not liquid intrusion, water is a poor conductor of electricity and the harness is insulated from seepage (see below), so it makes little sense that would cause the issue but dabbing a little dielectric grease won't hurt. An overloaded ground polarity is the root cause of this problem but do whatever you feel works for you. |
11-20-2019, 09:12 PM | #124 | |
Rep 1,755
2016 428ix, r, 2018 430iC, 2018 330it
11-21-2019, 03:26 AM | #125 |
Rep 8,972
Speaking as an electrical engineer of 30yrs exp water ingress into low voltage DC control circuits is a big problem. In this case the information from the vehicle diagnostics is not conclusive as to the fault.
Yes pure water is an insulator but not dirty water. Not just the water itself but the range of dissolved contaminants it brings with it. The connector is only lightly moisture proofed and it sits in the direct path of roof and rear window drainage water full of road dirt, salts and cleaning chemicals etc. Both my connectors were full of dirty water. Anyway, the contaminants running between the pins can act as a parallel path between signal(s) and ground. This will decrease circuit resistance and increase signal driver load current as seen by the lighting control module, the lighting control module will detect this and flag a fault. The software flashes the turn light at higher speed to mimic the operation of an old thermal flasher to attract the drivers attention. Equally when the connector dries out the resulting pin corrosion from salt deposits etc can cause high resistance joints that will decrease signal current and set off the same fault trigger. If you find burned or overloaded wiring or pins then that is a different issue of course. I can only comment from experience and from the 100% success on my own car with stopping this fault. Last edited by doughboy; 11-21-2019 at 03:36 AM.. |
11-21-2019, 09:46 AM | #126 | |
9103
Rep 7,563
In the last 2 years, I did not have one single issue with rapid flashing. The reason for this issue is the mentioned lack of ground polarity and also because although the vehicle's REM (lights controller) was originally designed for incandescent bulbs, which has a "hot/cold" check for the bulbs polarity to determine a fault, BMW still left on the "hot" check for the new LED turns signals. LEDs draws much less electric current than incandescent, so when there is a lack of ground, the vehicle assumes there is a defect, as it was design do for incandescent lights, since the draw is so much lower with LEDs, thus resulting in a telltale rapid flashing turn signal. LEDs for the turn signals are not steady burning, it only draws a momentary spark of electricity (see below), so that quick flicker, with the lack of ground, causes a momentary short, which the system interprets as a fault, thus, rapid flashing to indicate such. Adding ground polarity and possible removing the "warm" check VIA coding will guarantee resolve this issue. . |
amancuso724.00 |
12-17-2019, 02:34 PM | #127 |
Rep 47
Right Tail light malfunction
Mine has been giving me trouble sporadically. I ignored it for a year since I only drive the car on weekends.
Finally got sick of it and took off the light assembly a couple of weeks ago. I found the connector was loose and it has also a small clip to keep it in place which was not fastened. I put everything back tight the way it should be and no problem since. It actually seems like the tooling at the factory needs to be re-calibrated. So many 2 series with the same problem?? |
12-30-2019, 05:13 PM | #128 |
Rep 874
I had an issue with intermittent malfunction of the left turn signal (it blinks so fast and I get an error displayed in the iDrive and the dashboard). The issue would immediately go away the second time I would try it. Took it in for service and the dealer said that the whole left rear light assembly had to be replaced because there was corrosion inside it and evidence of water having leaked into it. They said it must have been a tiny hole... (a manufacturing defect?).
Incidentally, the second reason for taking the car in were scratchy noises form the right rear speaker. This was the second time I take it in for this issue and they had replaced the RR speaker that time. This time they said the amplifier had to be replaced but that the damage was caused by water as well! They kept the car for 4 days and did many water leak tests. Their theory was that the tree leafs that that had accumulated around the RIM of the trunk were the reason because they were keeping the water from draining normally.
2018 F87 M2 | LBB | Executive | Moon Roof | Apple CarPlay [2018 F22 M240 (sold) ; 2015 F22 M235i (sold); 2006 E90 330i (sold); 1983 E30 Coupe 320i (sold)]
12-30-2019, 06:37 PM | #129 |
9103
Rep 7,563
By design, It's virtually impossible for water to seep into the taillights or harness, even if you douse it with liquid, especially if you can't see any droplets from the outside but I guess they have to justify why they're replacing it, in order to get reimbursed by BMW.
12-30-2019, 11:50 PM | #130 |
Rep 1,759
Don't worry about twiddling with wires if your car is under warranty.
There is already a case with BMW on this fault. Go straight to your dealer and have them replace your taillights! I got mine replaced and no fault since. |
12-31-2019, 08:51 AM | #131 |
756
Rep 2,149
12-31-2019, 07:53 PM | #132 |
Rep 1,759
