01-15-2020, 08:58 PM | #1 |
Rep 177
2019 M2 Competition Turbo Oil Leak - Dealer Says it's Normal...
2019 BMW M2 Competition - 5500mi - California weather - Daily Driven
BMS intake for approximately 500 miles is the only performance modification I took the car into the dealer after this was brought to my attention and was told it is normal for the turbos to "sweat" a moderate amount of oil. While I do understand their point, to a degree, I find it hard to believe this is a normal amount of oil leaking from a 5k mile car. Has anyone else noticed a leak similar on their S55 equipped cars? If so, can you please share your experiences? Last edited by waldrops; 01-15-2020 at 08:59 PM.. Reason: spelling |
01-15-2020, 11:48 PM | #3 |
Luxury at the redline :)
9106
Rep 7,563
The oil leak is normal, it's apparently just blow-by from the PVC valve and a common S55 issue..
Turbo leaking, but dealer says nothing is wrong https://f80.bimmerpost.com/forums/sh....php?t=1545217 |
Economatic173.50 |
01-16-2020, 02:59 PM | #4 |
Rep 181
I strongly advise you to go to shop and make them write it down. Oil leaking in a closed system is never acceptable.
I mean, some of it looks like its oil in its liquid form and some like a build up of gas/carbon. You even have a spot of it on the turbo, above the black spots. |
01-16-2020, 06:32 PM | #5 |
Rep 484
If you haven't already, I would ask the service manager to get involved. An oil leak should not be "normal" in this age where we lost our oil dipsticks because of "emissions".
01-17-2020, 11:43 PM | #8 |
Rep 2,505
Could one contact Pure Turbo and see their thoughts if normal or not? I would ask them what is normal and what is not since they specialize in turbos for the S55. I wouldn’t trust the dealers response at all.
To the OP. Is it hard to take off the under pan? Next time I change my old in the car. I want to take that lower cover off and inspect underneath for leaks. |
01-17-2020, 11:53 PM | #9 | |
Rep 177
In regards to the underpan, at least while the car was on a lift, it took no more than 5 minutes |
