M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > THOR - GTS, CS, Comp. Flasher Android and iOS
      12-05-2018, 03:08 AM   #1
THOR_Flasher
Austria
90
Drives: BMW M2 | M3 | M4 F8X
THOR - the M Flasher
Dear M2 Community, on this thread I would like to introduce our Android and iOS app „THOR - the M Flasher“ and give you a insight into this DIY solution.
Increase the performance of your DCT gearbox and optimized your dynamic stability program (MDM mode), your electronically controlled limited slip differential and your steering with the Dynamic Package. Choose from the OEM quality settings Road&Track (CS) or Clubsport (GTS) and bring even more performance in your vehicle.
Attention to all BMW M2 N55 drivers! We have adapted the THOR G.T.S Clubsport Map for you. Now you can control the Drive Logic levels via your Driving Experience Switch even with a G.T.S Flash! The Dynamic Package includes additional Dynamic Maps for M2 Drivers as well - M2 Competition Maps.
Recommended Maps for BMW M2 F87
- THOR G.T.S (DCT)
- THOR Competition Map OEM Competition Maps (Dynamic Package)
Choose from the OEM quality settings Road&Track (M3/M4 C.S OEM Maps), Competition (M2 Competition Maps for N55 M2 - dynamic package only) or Clubsport (M4 G.T.S Map) and bring even more performance in your vehicle.
You can choose between 2 respectively 3 different packages.
Packages / Maps
- Full Flash Package
- DCT Package
- Dynamic Package
DCT Package
The DCT package consists as our two gearbox maps Road&Track and Clubsport.
Dynamic Package
Our Dynamic Package combined the three codings/flashs
- electromechanical steering
- dynamic stability control
- limited slip differential
and offers you also our two different maps Road&Track, Competition and Clubsport.
The Full Flash Package is our saving special and includes both Packages (DCT and Dynamic) with an 20% price advantage.
THOR highlights:
- faster and smoother shifts
- improved MDM Mode
- earlier upshift in comfort mode (eco tune)
- more traction
- improved clutch pressures
- update safety
- GTS or CS Flash made quite simply by yourself
- individual M2 G.T.S DCT maps and additional Competition Files for N55 M2
- THOR can be removed at any time and your vehicle configured back to the default condition (update safety)
Screenshots
THOR is compatible with:
- BMW M2 F87
- BMW M2 F87N
- BMW M3 F80
- BMW M3 F80N
- BMW M3 CS F80N
- BMW M4 Coupé F82
- BMW M4 Coupé F82N
- BMW M4 CS Coupé F82N
- BMW M4 GTS Coupé F82
- BMW M4 Cabrio F83
- BMW M4 Cabrio F83N
Required accessories:
To use THOR – the M Flasher, you’ll need an OBD II WiFi adapter or D-CAN Cable (Android only). THOR is compatible with the THOR OBD II WiFi adapter, ENET cable, MHD adapter in orange and black and the BimmerGeeks Pro Cable.
EU: https://www.bimmer-connect.com/thor-wifi-adapter.php
US: https://www.bimmergeeks.net/product-...p-wifi-adapter
More informations at https://www.thorflasher.com
FAQs: https://www.thorflasher.com/faq/
Download for free THOR on the App Store
https://itunes.apple.com/us/app/thor...l=de&ls=1&mt=8
YouTube Promo Video
YouTube Tutorial
M2 THOR G.T.S Map
THOR Review Evolve Automotive
THOR Review Blake's Garage BMW M3
I hope you enjoy it. If you require any further information, feel free to contact me.
Mail: office@thorflasher.com
Facebook: https://www.facebook.com/thormflasher/
Instagram: https://www.instagram.com/thorflasher/
      12-05-2018, 10:44 AM   #2
jetbill
jetbill's Avatar
126
Drives: F87
Can you provide a video of your DCT flash behavior during normal casual driving in automatic, with the car in sport or sport plus on the M2 ?
Smiler1.50
      12-05-2018, 10:44 PM   #3
akkando
Why not just provide Euro MDM and the most updated (CS) steering? At least then people would know what they were getting. I already have a Wifi OBD reader, I don't need another.
      12-06-2018, 02:25 AM   #4
963mw
BMW Fanatic
963mw's Avatar
This can easily be done on E-Sys.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
gphung39.00
      12-06-2018, 05:49 AM   #5
THOR_Flasher
Austria
90
Of course, I will create a video in the next few days.
In terms of our OEM quality maps.
Road&Track = CS like
Clubsport = GTS like
By the way. If you flash your vehicle back to series with THOR, you get the Euro MDM.
We know, a lot of us owns a WiFi Adapter. The THOR Adapter is the only compatible at the moment. Unfortunately, but flashing does not work with the adapters who are available on the market.
Our adapter is compatible with following apps
- THOR
- xHP Flashtool
- Bimmergeeks Pro-Tool
      12-06-2018, 07:16 PM   #6
SeanWRT
SeanWRT's Avatar
2571
Drives: E90 M3 & F87 M2
THOR_Flasher, I'm very glad that you bring this TCU flash to F8X.
There is a consensus in the M3/M4 community that OEM GTS works brilliantly with S55 engine. It clamps better, shifts faster and removes all the jerkiness at lower gears.
The same cannot be said to F87 M2 N55, with which throttle and shifting cannot be separately configured. The DCT seems not to be fully compatible with OEM GTS transmission software. The "symptom" after you flash through, is that however you toggle between C/S/S+, the shifting gets always stuck in GTS comfort, throttle response adjusts accordingly though. Also, you have C1/C2...C7 gear display on dash, instead of D1..D7 prior to flash.
I was the early trier of GTS gearbox in early 2017 and flashed back to stock in a few weeks.
If your software just codes GTS/CS file to F87 M2 N55, the symptom said above could happen.
Please double confirm that your software is not only flashable with F87 M2 N55, but also "properly working" with it.
I'm 100% in, if THOR software works as intended.
Lemania 2320
jetbill126.00
963mw274.00
      12-07-2018, 03:07 AM   #7
THOR_Flasher
Austria
90
Hi Sean,
thanks for your input and your comment about the “symptom” on the BMW M2. It’s correct, because the Drive Experience Control is different between BMW M2 and M3/M4 as you described it.
And YES, it happens with THOR too. A lot of our Users love the C mode while driving in the automated mode. But if you love it or not it depends very much on your driving profile.
Some of our BMW M2 customers, only buy the dynamic package. Others often flash between Series and Road&Track or Clubsport (DCT). Drives to the Racetrack “Series” and flash on the pit lane to Clubsport.
But thank you very much for your note. One thing is certain. The DCT Flash on the BMW M2 polarized. You love it or hate it. I’m loving it but I can also understand who does not.
      12-07-2018, 04:37 AM   #8
Lukeni
THOR the M Flasher - iOS tuning app for F8X (DCT, MDM,...)
I am driving a 2017 m2 pre lci with manual gearbox (eu spec).
Can we flash the m2comp mdm, differencial software and stearing with THOR? If not: is it planed in the future?
      12-07-2018, 05:36 AM   #9
THOR_Flasher
Austria
90
Hi Lukeni,
we are already working on it.
      12-07-2018, 06:07 AM   #10
Lukeni
Hi Lukeni,
Great news!
scflaw185.00
      12-07-2018, 09:27 AM   #11
Bee Pee
1295
Drives: AW M2 DCT
Hi Lukeni,
Doesn't dynamic pack ie MDM / diff / EPS do this already
R&T map level = OEM F87 Comp & CS level = OEM F82 GTS ??
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      12-08-2018, 06:37 AM   #12
THOR_Flasher
Austria
90
It's possible. We have not verify it at the moment. We're waiting for our development M2 Comp.
But I think it's a difference between M2Comp. and M3CS MDM.
      12-12-2018, 03:49 AM   #13
THOR_Flasher
Austria
90
Additional information about our maps.
FULL FLASH Package with Road&Track and Clubsport Map consists of:
⚡️ DCT: improved gear changes, optimized clutch pressures
⚡️ DSC: more traction, better control and an advanced MDM Mode
⚡️ LSD: better cornering, more sensitive torque management
⚡️ Steering: improved steering wheel feel.
      01-22-2019, 06:25 AM   #14
THOR_Flasher
Austria
90
Hi Guys,
there’s a lot going on at THOR. As you might have noticed, we released our update v1.4 in the last week with some usability optimizations and the launch of our THOR dealer program. (Tuners welcome ☺ - please contact us by mail office@thorflasher.com)
Standing still is a step backwards: we look to the future! At the moment, we are working on following additions:
- CS-EDC Coding (M3/M4)
- roll out our Android Version
- support of M2 Competition
Estimated release our Android Version will be end of February. We got a lot of mails and messages about EDC-Coding. Currently we need a few more weeks for internal testing before we start with a wider beta group of M3 and M4.
And for all those who do not know THOR yet, a short introduction.
⚡THOR - The M Flasher ⚡
2 Different Maps Road&Track (CS) and Clubsport (GTS). Flash how often you want and feel the difference between Stock, GTS and CS factory maps.
�� DCT (dual-clutch transmission): improved gear changes, optimized clutch pressures, sharper rev. matching and removal of the harsh jockeying feel from the transmission.
�� DSC (dynamic stability control): more traction, better control and an advanced MDM Mode
�� LSD (limited slip differential): better cornering, more sensitive torque management.
�� EPS (electronic power steering): improved steering wheel feel (feels proper)
THOR highlights
⚡faster and smoother shifts
⚡improved MDM Mode
⚡change how often you want between stock, GTS or CS maps
⚡earlier upshift in comfort mode (eco tune)
⚡more traction
⚡improved clutch pressures
⚡update safety
⚡Ideal for vehicles with enhanced engine performance.
⚡Modified torque limiters.
To use THOR – the M Flasher, you’ll need an OBD II WiFi adapter. THOR is compatible only with the THOR OBD II WiFi adapter.
Download on iOS app store
      01-22-2019, 05:38 PM   #15
AndrewC1989
AndrewC1989's Avatar
Drives: 2017 M2 | 2015 328dx
2017 M2  [5.00]
2015 328d xDrive  [0.00]
Yeah, you can do all the coding yourself with a little knowhow but flashing the DCT software yourself isn't a walk in the park for the inexperienced. This app is pretty cool just because of the ease of use and convenience factor. I'm assuming people who know how to do this stuff on their own aren't their target audience.
      01-22-2019, 08:13 PM   #16
SeanWRT
SeanWRT's Avatar
2571
Anyone flashed CS DCT and would that make a difference from GTS in term of the responsiveness or more precisely the downshift sluggishness?
Lemania 2320
      03-25-2019, 10:27 AM   #17
THOR_Flasher
Austria
90
With our latest update v1.6, we brought a new Map for the BMW M2 F87
⚡️ M2 Competition Map ⚡️
Dynamic Package
- Electronic Power Steering Setup from the M2 Competition
- the improved limited slip differential
- and a more sensitive DSC / new MDM-Mode
DCT Package
- M2 Competition DCT Map
      03-26-2019, 07:07 AM   #18
MZWIE
1 - Explain the DCT upgrade. So far the EURO MDM does not work with the M2 DCT. When installed it the tranny will be stuck in COMFORT mode when choosing any of the self shifting modes.
2- Will interfere with any previously installed upgrades.
3 - Verify that this will work with other WIFI OBD adapters. Having to purchase one specifically for this app will most likely dissuade most people.
      03-26-2019, 09:55 AM   #19
THOR_Flasher
Austria
90
1) of course, it's the same situation like the GTS DCT Flash.
2) it's no problem - the most of our customers have more modifications
3) I know, but at the moment it works with our adapter only. our android version works with cable as well, but it doesn't work on the iPhone/iPad.
Regardless of the dct package, the Highlight of the Competition Map is definitely the Dynamic Package with the Power Steering, MDM and Differential upgrade
      03-30-2019, 02:09 PM   #20
Big Fabri
Big Fabri's Avatar
Italy
73
Drives: Lamborghini Huracan
Hi. i'm waiting for my M2 Competition to arrive. it will be there in may, so really soon.
I read about the problem with the m2 and the n55 engine.
I was wondering if flashing my M2 Competition which has a s55 engine everything works.
I'd like to try the cs and gts settings from the m3/m4 cars but i donàt want to spend 399 and be disappointed.
      03-31-2019, 09:42 AM   #21
biggripper
biggripper's Avatar
278
Drives: 2016 F82 SS/SO (Traded)
2016 M4  [0.00]
Is this strictly for M2/3/4's equipped with DCT? That's kind of what it seems like. Can you tell me what benefits, if any, your app has for cars equipped with manual transmissions. If you had a package designed for the M2C which could offer tuning to bring my M2C up to the same HP as my M4 I'd be interested. I'd also be interested in CS and GTS tunes as well as the ability to adjust burbles, start up roar, etc. Do you offer anything like that for manual equipped cars?
      03-31-2019, 10:06 AM   #22
Lukeni
All works for the manual as well
Tags
bmw m2, dct, gts dct, gts flash, gts steering, m2lci, mdm
Copyright ©2000 - 2020, vBulletin Solutions Inc.
