M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > ☛ MHD Flasher F Series (F87) discussion ☚
      08-11-2019, 05:33 PM   #221
M&M
M&M's Avatar
South Africa
80
Drives: Boosted Beemers!
Originally Posted by Jungman View Post
Today I mapped my GTS TCU for my car, N55 M2. Then my instrumental panel which initially showed D1 now changed to C1. Even when I converted to sports plus, my car changes shift during low RPM. Also when I accelerate, my down shift doesn't work. I feel like original comfort mode is way faster and better. So I changed it back to stock map. How should I fix this problem?
Yeah, had the same issue. I don't think the GTS flash is for the N55 M2. It shouldn't have allowed it to flash. I had to get the gearbox programmed back to stock and it's fine now.
      08-12-2019, 05:59 AM   #222
MVersi
XSS11V
116
Drives: M2 LCI - Mineral Grey
What's the CS flash difference? Anyone done it?
      10-05-2019, 04:30 PM   #223
Yellowflash21
Slovenia
351
After very long time, and thinking to either go with custom tune or bootmod3 or mhd.
I've decided to go with MHD option as their OTS maps seems to be little bit less agressive compared to bootmod3 and it would give me a little bit piece of mind.
The only downside was a very long initial flashing process which took 24 min. and I'm sure this is fixed now with the upcoming wifi adapter.
But, after reflash was completed I'm very pleased with overall results!
My stock FBO without remap 100-200 was around 10.5 (manual
Also, 3rd gear pull 100-150km/h was flat 4 seconds.
With their Stage2+ 93/98RON, I got the following results on the same rode in similar conditions:
100-150 km/h flat 2.99seconds
100-200 km/h around 9.4 seconds!
If I would be little bit on shifting from 3rd to 4th, I'm sure I could get to 9s without prob!
Thank you! MHD Tuning
      12-10-2019, 08:12 AM   #224
MHD Tuning
MHD Tuning's Avatar
Germany
1674
Drives: M3F80#M5F90#340iF31#SupraA90
Thank you, feel free to send us a datalog!
      12-10-2019, 03:10 PM   #225
Cristian135
Drives: Bmw m2
Will there be an improved stage 2+ map for m2 n55?
      12-11-2019, 06:19 AM   #226
MHD Tuning
MHD Tuning's Avatar
Germany
1674
ST2+ already runs on the edge of the the stock fuel system.
We like to keep the OTS maps a bit on the safer side but a great upgrade for the M2 is a B58 HPFP and custom tune to max out the stock turbo.
      12-14-2019, 04:28 PM   #227
MVersi
XSS11V
116
If I upgraded to the B58 HPFP, what would be the best turbo upgrade to suit? TTE/Pure?
      12-14-2019, 06:29 PM   #228
F87source
F87source's Avatar
482
Drives: 2017 Bmw M2 6mt
The B58 hpfp has 2 variants B and C, the B variant is available in NA and on most b58's and only flows slightly more than the F series n55 hpfp. The C variant found in the new Z4 m40i (mostly Euro spec) and supra is a Bosch hpd6 Evo 3.5 bar pump which flows significantly more than the F series n55 pump.
So depending on which pump you have, you may or may not require additional fuelling to Max out a turbo upgrade.
I personally prefer the pure upgrade since they've been around for awhile and are quite reputable. But imo I would skip the hybrid turbos and go straight for a "stage 3" turbo to remove the restrictive factory turbo fold.
Follow me on Instagram @f87source
      12-16-2019, 12:32 PM   #229
MHD Tuning
MHD Tuning's Avatar
Germany
1674
on B58 OG pump you can max out the pump with the stock turbo so both are then maxed out.
If you want 480+ then go with Pure Stage 2 and XDI HPFP.
      12-19-2019, 03:35 AM   #230
D CHOI
D CHOI's Avatar
540
Drives: 2017 BMW M2
I noticed you guys don't offer ACN tunes like BM3 does for the west coast people? Is it because your tunes aren't as aggressive as BM3?
      12-19-2019, 08:43 AM   #231
F87source
F87source's Avatar
482
The best way to find out if your gas is good enough quality to run the tune is to data log it, buy a map pack that suits your mods. Then data log the lowest octane rating first, look for knock and of course afrs and other variables, then move your way up in terms of octane. But first look to see how the stock tune is doing.
The best option is to use a custom tune, you can't always rely on ots maps to perfectly suit your car....
      12-21-2019, 03:43 AM   #232
oranzada_m2c
Czech_Republic
9
Drives: M2C 2019
I need just coding M2C with stock map from factory:
1)VMAX limiter
2)cold start off
Is it possible?
Thanks mark
      12-27-2019, 09:09 PM   #233
///Monika
Drives: '18 X3 M40i & '18 M2
Just loaded S2+ using the OBD WiFi black. Unlock and load took approx. 3 1/2 minutes. Haven't had a chance to drive it yet but being able to kill the cold start (MPE exhaust rattle here) was well worth it. Will gen a log once we get back into town.
Awesome job MHD...
      12-29-2019, 10:11 AM   #234
///Monika
Will there be support for Spool FX-150 in a future release or is this something that a customer tuner will have to implement ?
http://spoolperformance.us/index.php...&product_id=77
      12-29-2019, 11:27 AM   #235
cecaa850
According to their site, they'll provide data to whatever tuning platform you might be using.
      12-29-2019, 11:43 AM   #236
prompt
prompt's Avatar
72
Drives: M2 COMP
asking for a friend
Will MHD work for a 2019 bmw M2 Competition?
      12-29-2019, 11:44 AM   #237
///Monika
Yes, read that too. Was hoping we wouldn't have to go the custom tuning route until we do a Pure Stage 2 upgrade here in a couple of months. We see support in the MHD app for the XDI so we're hoping they implement the 150 as well. So much easier to do these upgrades in incremental stages.
So until then, finger on the purchase button (FX-150) if/when MHD intends on expanding support. Otherwise I guess we do everything all at once and have it tuned.
      01-05-2020, 04:56 AM   #238
oranzada_m2c
Czech_Republic
9
Drives: M2C 2019
Originally Posted by prompt View Post
asking for a friend
its not possible, because locked DME... you have to visit some tuner and tuner have to take ecu from engine and flash dme.
prompt71.50
      01-08-2020, 01:32 PM   #239
///Monika
We contacted Spool Performance yesterday and inquired about 2 of their kits (HPFP, Ethanol Analyzer, micron inline filter and long line kit) which we'll probably order in the next week or so. Spool indicated that MHD and BM3 will be rolling out support within their next update.
MHD Tuning , can you please confirm support of the FX-150 in the near future ?
For others, they indicated that the harness is definitely PNP - no cutting of the OEM harness. More questions went their way today so I'll post updates once my husband forwards me their response.
      01-10-2020, 08:51 AM   #240
MHD Tuning
MHD Tuning's Avatar
Germany
1674
Two nice dyno results from our European customers, both are running our ST2+ E20, DP + FMIC.
      01-10-2020, 11:00 AM   #241
AmuroRay
Drives: M235i
1)VMAX limiter
2)cold start off
Is it possible?
Thanks mark
Yes.
      01-13-2020, 03:37 PM   #242
besjamin
I've just installed a DP and tuned with Stage 2+.
Fellas, care to share your burble settings? Thanks
Tags
flash, mhd, tune
Copyright ©2000 - 2020, vBulletin Solutions Inc.
