04-21-2021, 10:10 AM | #89 | |
Rep 3,130
2. Flash will not account for the sport cat but the lack of some restriction in the path will have some minor benefit to efficiency, etc. Put simply, it will not be fully maximized to its potential is all. |
04-22-2021, 07:25 AM | #91 | |
Rep 3,130
87 AKI = 91 RON 91 AKI = 93 RON 93 AKI = 98 RON 100 AKI = 104 RON 104 AKI = 108 RON |
04-24-2021, 12:16 PM | #92 |
Rep 52
I was waiting for a while for this to be released and I must have missed the announcement.
With that said, I just went through the Dinan website and I'm a bit confused; when I look at the dynos for each product am I correctly reading that both the Dinantronics Stage 4 and the electronic wastegate version of the Stage 2 flash are making (mostly) more power and torque than the one for the M2? (at 93 octane) Also, the dyno graph lists stage 1 (93 octane) peak torque at 447 but the table at the bottom of the page lists 430. What's going on? I understand that it was said all along that the Stage 2 flash was going to make very comparable numbers to the Dinantronics Stage 4, but I would like to know if the stage 2 flash is actually making slightly (but noticeably) less power than Stage 4 piggyback. If that is the case, is the case for upgrade to flash to gain some additional features (octane versatility, gauges, speed governor) at the expense of some power? |
04-26-2021, 09:04 AM | #93 | |||
Rep 3,130
04-28-2021, 02:14 PM | #94 |
Rep 989
Drives: 2024 M4 Comp X-Drive
With these tunes are you able to turn off ASD, edit burbles, or other simple configuration options?
2024 Dravit Grey M4 Competition X-Drive
04-28-2021, 03:00 PM | #95 | |
Rep 3,130
For those 2 mentioned specifically -- ASD is a coding function not calibration. In terms of burble settings we avoid altering intensity (minimum ignition timing) with the stock catalysts in the equation. Goes down a slippery slope with emissions. Typically the most we will do is implement CP burble settings on a non-CP car as an example so it is still deemed within acceptable factory tolerances. Duration is changed in some instances on platforms where the window for the burble is next to non-existant so you can at least enjoy a bit of sound but those instance usually only apply to 4-cylinder vehicles. |
04-28-2021, 07:12 PM | #96 |
Rep 39
Crap. I been waiting for this flash for months now. Been in Florida for winter and just came back north. Turns out my two local BMW dealers stopped selling DINAN products. It was so easy going to them for my maintenance and loaner.
I'll have to find another place now. |
04-30-2021, 03:48 PM | #97 | ||
Rep 989
Does your stage 1 93 tune leave the burbles stock? Cheers, Chris
04-30-2021, 03:52 PM | #98 | |
Rep 3,130
Burbles are stock. IMHO, on the N55 M2, especially with the Dinan exhaust, they are pretty aggressive as is. |
04-30-2021, 04:43 PM | #99 |
Rep 2,515
Any updates to the Stage 4 software?
04-30-2021, 04:47 PM | #100 | ||
Rep 989
04-30-2021, 04:56 PM | #102 |
Rep 3,130
04-30-2021, 05:23 PM | #103 | |
Rep 2,515
04-30-2021, 05:34 PM | #104 | ||
Rep 3,130
DrKevM52276.00 |
08-09-2021, 07:46 AM | #105 |
Rep 33
Hey Dinan_Engineering
A couple of quick questions for the M2 LCI I just bought: 1. Does the 93 octane dinan+ honor factory extended warranty as well? What about the Zurich extended warranty? The warranty on my LCI expires this Fall 2. Any concerns about the compatibility of 93 octane Dinan+ with the Fabspeed sport cat? 3. If I were to go from the Dinan+ tune to something more (IE stage4), am I interpreting right that I would have a credit for the tune associated with the stage4? |
08-09-2021, 09:54 AM | #106 | |
Rep 3,130
2. No issues with compatibility but please be aware that running a non OEM Cat with Dinan+ could jeopordize coverage given the tune is technically being run "out of spec" (Dinan/OEM modifications only). 3. With Dinan+ you can switch over to Stage 1 at any time and there would be no cost from Dinan although the dealer may charge labor to perform the update. Once you go to Stage 1 however there is no going back to Dinan+. As far as a cost to upgrade to stage 2 from there it would be the cost difference between the 2 stages which is $50 currently. |
08-10-2021, 01:26 PM | #107 | |
Rep 1,153
But in any event, is it still the case that actual performance with this flash is basically the same as performance with the piggy/IC set up we started with, all else being equal? |
08-10-2021, 01:36 PM | #108 |
Rep 3,130
If you are just comparing peak numbers then yes they are basically the same considering the limitation in both cases is still the fuel system. The flash will give you a bit more juice in the lower RPM's and has the other inherent advantages such the top speed governor defeat, more control in general for smoother power delivery, enhanced safety mechanisms, and sport gauges rescaled to reflect correct output to name a few.
BruceM985.50 |
08-10-2021, 01:42 PM | #109 | |
Rep 1,153
Only downside I can see is that if you like to update your ISTEP regularly, the piggy makes that a one-step process, instead of an update and a reflash.... |
08-10-2021, 01:53 PM | #110 | |
Rep 3,130
When flashed you will specify which octane mapping you want to flash but you have access to all of them-- just a matter of reflashing to whatever mapping you want at any given time. |
BruceM985.50 |
