04-12-2022, 01:06 PM | #1035 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
Well, given that on their own website, the remote is an option with the OG M2 MPE and not the M2 Comp MPE, I'd guess whomever you spoke with was incorrect.
04-13-2022, 07:09 PM | #1037 |
Present:
111
Rep 33
Mods
Just had a MPE installed today. Is it worth $5k? Not sure but it looks and sounds better. I just purchased the car last week with under 600 miles on the odometer. I drove about 200 miles in the car but it was enough for me to know the stock exhaust had to go.
04-13-2022, 10:56 PM | #1038 | |
Rep 2,819
Drives: e82 1M, f87 M2cs
On my 1M I reused my strut pinch bolts twice when I installed camber plates and then later coilovers. I had no idea they were single use only. They are aluminum and can only hold their specified torque once. I got away with it the first time, but when road testing the coilovers, I felt and heard a loud snap when turning right into my garage . . . the drivers side shock had rotated enough that the sway bar end link got turned into it and snapped in two! That was an easy fix (Turner adjustable links FTW!). If you are doing track days, and those caliper bolts are meant to be used once, their failure could be catastrophic, and could fail more easily due to the heat cycles and stress.
04-14-2022, 12:04 AM | #1039 |
3024
Rep 13,768
If you want to hear my CS with Akra back and AA Equal Length Mid, let me know since you're in the OC and I'm not that entirely far from you.
~loud noises~
04-14-2022, 11:39 AM | #1040 |
Present:
111
Rep 33
I appreciate that. Like "most" CS owners considering a new exhaust it will "likely" come down between Akra and MPE. After a deep dive on both systems I went MPE for the OEM factor and no valve control remote required. However I do think the Akra is slightly more visually appealing and the fit and finish "might" just be a tad higher even though MPE was reportedly developed in partnership with Akra
RideM317.00 |
04-14-2022, 11:44 AM | #1041 | |
3024
Rep 13,768
~loud noises~
04-14-2022, 11:46 AM | #1042 |
Present:
111
Rep 33
04-14-2022, 02:21 PM | #1043 | |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
04-14-2022, 03:48 PM | #1044 | ||
Rep 2,208
Drives: G81 M3 Touring (Frozen Black)
04-14-2022, 06:00 PM | #1045 | |
Present:
111
Rep 33
04-14-2022, 06:29 PM | #1046 | ||
Rep 2,062
Melborne Red 08' E90 M3 6spd Hockenheim Silver 20' F87 M2 CS MDCT White 21' Jeep Gladiator Rubicon |
04-14-2022, 07:15 PM | #1047 | ||
Rep 2,208
tunawi7cheese219.00 |
04-14-2022, 07:30 PM | #1048 |
3024
Rep 13,768
The remote, at times, does require a few pushes on initial startup to open or close the flaps, so that is my only annoyance with the remote because it has it's own wireless signal it keeps to pair with the module in the trunk.
~loud noises~
04-15-2022, 12:49 PM | #1049 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
Yes, the Akra sound kit comes with the link pipe, but it is only to have full control over the valves. It is not needed to run stock automatic valve control. I didn't install it because it is a pretty invasive installation and there are easier to install solutions on the market (ie, VSC2).
04-15-2022, 02:49 PM | #1050 |
Rep 2,208
Some profile pics. Clean and mean.
04-15-2022, 03:48 PM | #1051 | |
Rep 375
After a few weeks of local and highway high speed driving I have decided to switch to the BMW HAS. The rear was perfect but front just a little too low. The stiffness of the springs also really accentuated road vibration at speeds 80+ FYI originally the thought was 5mm spacers were not perfectly aligned so switched to 10mm with lip but no difference. At 10mm there was slight wheel poke in the rear. Ill go back to 5mm with the BMW HAS Timing was now as I ran into some bad luck with nail front passenger tire and the rears were getting close so Ill change all 4 tires. With respect to the CDV delete could not be happier and a must do mod IMO The Porterfield R4-S pads feel very good with no noise or clicking. Approx 50% less dust front and 70% rear. |
frostyrides311.00 |
04-16-2022, 08:13 AM | #1052 |
Rep 129
M Performances carbon fibre fuel cap on 10 bhp added .🤣
04-18-2022, 04:10 PM | #1053 |
Rep 27
Are these the BMW winglets for aftermarket? Does anyone have some history on the aftermarket ones for looks, durability etc.? At roughly $200 vs the OEM at $1200, I'm curious as I want a set...
04-18-2022, 04:15 PM | #1054 |
Rep 91
Those look to be the BMW ones. I have the same, purchased from a seller on this board. He seems to be have another set his selling at the moment.
04-19-2022, 03:24 PM | #1055 |
Rep 27
04-19-2022, 03:28 PM | #1056 |
Rep 27
Who's winglets are these? I'm looking for a pair, aftermarket if they're good enough, or discounted OEM.
