03-01-2022, 08:53 AM | #177 |
Rep 345
Im about to change my manual transmission and rear differential for my 2018 OG M2 sometime this month. The links on newtis is no longer working so I can't actually see the correct fluid that I need. I also do 1-3 track days a year. What fluid is correct? Oem would be good for occasional track days right?
TIA |
03-01-2022, 11:25 AM | #178 |
New BMW owner
325
Rep 843
Manual Transmission oil: BMW OEM MTF-LT5 or Redline DCTF 1.6 liter
Rear Diff: MSP/A. One bottle Yes fine for track days. First change or now second after the first free service? |
03-01-2022, 11:45 AM | #179 | |
Rep 7,429
You will need 1L of diff oil, and 2L of transmission oil (you will use much less than this but 1L is insufficient) OEM fluids are fine for 1-3 track days, you'll just need to lower the change intervals.
03-01-2022, 11:45 AM | #180 | ||
Rep 345
03-02-2022, 03:00 PM | #181 |
Rep 7,429
03-02-2022, 07:36 PM | #182 |
Rep 345
03-02-2022, 08:17 PM | #183 | |
Rep 7,429
The manual transmission doesn't utilize o-rings or even a washer (super strange), and it's not a torque to yield fastener so it's good for reuse.
M2RAW121.00 |
03-03-2022, 03:49 AM | #184 |
New BMW owner
325
Rep 843
Why they needed to change the whole bolt instead of just the o-rings I don't know.
03-04-2022, 05:41 AM | #185 | ||
Rep 345
03-04-2022, 07:33 AM | #188 |
The Seeker
13863
Rep 3,325
03-04-2022, 12:00 PM | #189 |
Rep 7,429
The diff drain and fill aren't tty, it's also going into an aluminum diff cover plate, I'm pretty sure it's aluminum.
///MPhatic13862.50 |
03-16-2022, 04:23 PM | #191 |
844
Rep 1,962
03-17-2022, 05:38 AM | #192 |
New BMW owner
325
Rep 843
he is showing a bottle of Motul gear oil on the photo.
04-15-2022, 09:52 PM | #194 |
Rep 345
Just did my MTF and rear diff today, when I was filling the rear diff I noticed it didn't overflow but I filled it with the whole bottle. Any inputs?
Also, what's that interval of drain and flush of our transmission? Thanks in advance |
04-15-2022, 10:00 PM | #195 | |
Rep 7,429
There is no set interval for the transmission because bmw thinks it is a life time fill - which is total nonsense. So I generally do it in sync with the diff - every 4 years or ~50,000km whatever comes first (you can do a UOA to get more accurate numbers but this is what I do, factoring in that maintainece is cheap and these parts are not, and the fact that these diffs are not the most bullet proof thing ever and are known to fail it would be best to lower the oil change interval down to these numbers vs. what bmw recommends).
M2RAW121.00 |
04-15-2022, 10:02 PM | #196 | ||
Rep 345
Is this transmission need to be drain and flush too at some point? |
04-15-2022, 10:17 PM | #197 | |
Rep 7,429
Yes, didn't you ask about the transmission? My reply was in regards to both the transmission and the differential. I would do both at the same time.
M2RAW121.00 |
04-15-2022, 10:19 PM | #198 | |
Rep 345
