BMW M2 Forum > BMW M2 Competition Model > CF Mirror covers install? Remove mirror or not?
      03-10-2020, 09:16 AM   #1
F82_SID
F82_SID's Avatar
Drives: 2020 M2C 6mt HK Silver
Hey guys don't flame me, I have been searching this forum and YouTube for the past two days and I can't find clear instructions on installing CF mirror caps for the M2C? Some posts seem to indicate that you have to remove the mirrors and others seem to suggest that you can just pull the caps off? What's the consensus? Any install links or vids would be a huge help.
2011/E92/M3/MR/BB/ZCV/ZP2/EDC/2MT
      03-10-2020, 09:33 AM   #2
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
I'm planning to do this, and based on my research you do not need to pop out the mirror for our models. See this video. I also plan to do the CF caps soon.
      03-10-2020, 09:34 AM   #3
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
There's a ton of YouTube videos on how to do this.
Motorcity BMWCCA Member
Instagram | YouTube
      03-10-2020, 09:46 AM   #4
HODLM
HODLM's Avatar
Drives: 2018 M2/AW/6MT; '16 X5 Hybrid
Pro tip (from an amateur): put a towel down on the floor that covers about 3 feet in front of the mirror (basically to the front wheel).
I was so focused on popping the mirror cap off carefully that I didn't realize it would go flying off and hit the ground. The towel will provide a safe landing spot and prevent scratches. This is especially important if you're removing the CF cap (for whatever reason).
FWIW: While you may not need to, I did pop the mirrors out to make it easier to pop the cap off.
      03-10-2020, 03:18 PM   #5
///MCollection
///MCollection's Avatar
184
Drives: M2C X5M M4
2018 BMW M4  [0.00]
2019 BMW M2 Competi ...  [10.00]
2017 BMW X5M  [0.00]
If it is cold I always run a hot air gun over the glass and then pop it out then warm the plastic clips too. Plastic is so much less fragile when warm just keep pointing the air away and feeling the piece to not over heat. You lucky ones in warmer climates can just park it in the sun.
      03-10-2020, 03:38 PM   #6
Tag
this is the way
Tag's Avatar
18151
Drives: N-1 starfighter
Trying to pop out the mirror is tricky, it's super thin with little backing and easy to crack... ask me how I know. If you don't plan on using the old caps and don't mind if some clips break than you can take the safer route and pop them off from the back. If you to decide to pop out the mirror to get the old caps off use a really wide pry tool, take your time, do not force it and cross your fingers.
      03-10-2020, 03:42 PM   #7
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
I would just follow the video above. Gentle taps, while holding the cap, until is slowly gets wedged out. No need to rush it, just push it out a few mm at a time.
      03-10-2020, 05:12 PM   #8
VFK_by_Midnight
VFK_by_Midnight's Avatar
79
Drives: BMW M2 Comp
If you don't have the tool in the video above, I've found you can use a small flathead screwdriver wrapped in a thin cloth to pop out the initial tabs.
      03-10-2020, 08:12 PM   #9
Cannondale900
Drives: '20 M2C, '10 535ixT, '91 M5
2023 X5 45e  [0.00]
2015 LR4 HSE Lux + HD  [0.00]
1965 Shelby Cobra 4 ...  [0.00]
2020 M2C  [0.00]
1991 M5  [0.00]
2010 535ixT  [0.00]
I just installed mine this evening; no need to mess with the mirror glass at all. The video referenced above is perfect. I didn't have a trim tool (no clue where it went) but I did have a plastic shim. I laid a microfiber towel over the mirror and tapped along the seam exactly as per the video referenced above.....the painted cover popped off gradually over the course of four or five firm taps. I would use an implement made of plastic and at least 2" wide. This will prevent the implement from slipping through any protective cloth and inadvertently scratching or tearing the cover you are removing.
      03-11-2020, 07:48 AM   #10
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
Great to hear and thanks for reporting back. I haven't done this yet but certainly plan to soon. Which caps did you end up going with? Care to share some pics? Thanks.
      03-11-2020, 11:44 PM   #11
Cannondale900
2023 X5 45e  [0.00]
2020 M2C  [0.00]
1991 M5  [0.00]
2010 535ixT  [0.00]
I picked up the M Performance caps. No pics in the sun yet as it's still crappy in Chicagoland but here is a quick pic from the garage tonight along with a recreation of how I popped the stock covers off (except I had my hip in front of the mirror cap to keep it from falling).
      03-12-2020, 05:49 AM   #12
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2020 M2C  [0.00]
They look great! And thanks for taking the time to show me.
