10-17-2022, 04:12 AM | #221 | |
Rep 7,298
Yeah, nothing is going to work on a VW FSI motor, and there is no problem with most diesels because the vapors aren’t burning there. However, it can easily be conceived that there is a middle ground where a small difference can be made with oil formulation. I happen to agree with you that the oil’s influence on this is minimal compared to the engine design. However, if you look at the tests manufacturers have added to their newer standards, it’s clear they believe it has a role in helping control deposits. I’d run M1 0w-40 FS without hesitation in S55 also, but let’s be more civil about it. Can’t believe it’s me saying that but yeah. |
10-17-2022, 04:25 AM | #222 | |
Rep 1,335
I just remembered a customer who had sent me the turbos of the n54 to improve them, he is a guy who used the car hard, the oil change intervals were every 4000km (motul xclean oil), and the turbine shaft were the same as the left one in the picture, in all the years that I work with turbos I have never seen anything like it, the shaft on the right is typical in almost all the turbos (oil intervals 20/30k km) that come to me for repair, then a brat tries to explain to me that the oil intervals do not matter.... Last edited by Track/S; 10-17-2022 at 05:20 AM.. |
10-17-2022, 04:46 AM | #223 | |
Rep 7,429
1) if carbonization occurs due to fuel vapor contact then your entire oil supply would be carbonized due to fuel dilution... The fact that the oil supply isn't completely soldified is proof this isn't the mechanism for carbon formation. 2) Why do we not see any carbon deposits in the pcv hoses and turbo inlet? There is a rich oil and gasoline vapor mixture there - hint: it isn't hot enough. 3) Diesel engines even without the EGR will still have diesel vapors mixing with the fuel and reciruclated by the pcv system, because the pcv system recycles crank case vapors which consists of oil and combustion by products........ 4) Oil is designed to tolerate fuel dilution, which is espeically prevelant on direct injection engines, if the oil carbonizes due to fuel then clearly that would defeat the entire purpose of tolerating fuel dilution. So again you are completely wrong, and now you exposed yourself for not even understanding how the pcv system works, I asked you to detail it before and you failed to do so. Now I know why. Again you have zero evidence to prove that there are no deposits in an EGR deleted diesel engine, and you have no proof gasoline vapors cause carbonization - I literally just logically debunked that. Now the reality of the situation is the oil "cooks" or "bakes" onto the valves, because the valves are fricken insanely hot when the engine is operating. So when the pcv vapors hit the valves the oil and gasoline vapors instantly evaporates off and leaves behind deposits. This is why OEMS keep saying to use high quality fuel - because there will be less crap in the fuel to leave behind deposits, and this is also why they say to use low SAPS oils because it leave deposits behind.
chris7197334.00 |
10-17-2022, 05:16 AM | #224 | |
Rep 7,429
"The results indicate that the deposits mainly originate from engine oil, and suggest that the main reaction route of the deposit formation is the carbonization of oxidized engine oil. Namely, low boiling point (light) fractions in the engine oil easily evaporate from the valve surface. On the other hand, the remaining heavy fractions are subjected to deposit forming reactions. These final states are amorphous and carbonaceous aggregates. The deposit has a tendency to form in the temperature range of about 230 to 350 °C. The location of accumulating deposit depends on the valve surface temperature. " So now that is 2 research studies done by 2 independent multi-billion dollar companies absolutely refuting everything that you have said. Literally you are refuting 2 major pieces of laboratory grade research, with zero backing (still waiting for any form of legitimate proof). Yeah, you are out of your depth on this one.
10-17-2022, 05:35 AM | #225 | |
Rep 1,335
There are no carbon deposits in the turbo no, ahahah.... but today you are going to learn that gasoline vapors go to the intake manifold and oil vapors to the turbo inlet. |
10-17-2022, 05:45 AM | #226 |
Rep 7,298
That’s all correct, but none of what you posted refutes the fact that what is burned on the valve surface has some impact on the deposits left behind.
If you ran olive oil in your engine you don’t think the deposits on the intake valves would look different? Oil is clearly a component of what is burned on the valves. Last edited by chris719; 10-17-2022 at 05:56 AM.. |
10-17-2022, 06:14 AM | #227 | |
Rep 1,335
Easier still, gasoline vapors cause this: |
10-17-2022, 07:01 AM | #228 | |
Rep 7,429
1) compressor temps get to at most 250F maybe 300F, and that's the max upper limit of air temps that should ever go through the turbo (https://www.google.com/amp/s/www.det...fhs_amp=true): Oil has a flash point of 400F and up, so it's no where hot enough in the turbo or intake tract to evaporate the oil and cause carbon build up. The valves on the other hand operate at around 230c (446F) and up. This is hotter than most flash points of oil, explaining exactly why it instantly evaporates and carbonizes on the valves. This correlates exactly to what Toyota found in their research, again disproving what you said... It's crazy how little you actually know about cars in general and can still nake these claims with confidence. Literally every single reply you post makes you look like an idiot. 2) you should Google what the pcv system does, because it takes combustion gases which includes both oil and gasoline vapors and ducts it into the turbo inlet. There's no special separation on the n55 or s55 for gas and oil vapors, there is only a single pcv system for both oil and gasoline (combustion vapors) gases, and it goes either directly to the turbo inlet or right into the valves via the head ports. This your turbo example is meaningless. Again the fact you don't know this further shows how little you know as a whole, like I said before you're out of your depth not only with oil but it seems with how engines work as well... Quote:
But it makes me laugh when idiots think they know more than research scientists who actually have reliable and proven results that say otherwise. Btw please post the chemical reaction between gasoline and oil that causes carbonization and prove your claims. Guess what oil is designed to tolerate gasoline to avoid fuel dilution. It's not gasoline that causes carbonization it's the extreme valve temps that exceeds the flash point of oil that does it.
10-17-2022, 07:32 AM | #229 | |
Rep 1,335
10-17-2022, 11:09 AM | #230 | |
Rep 7,298
“TGA results showed that, in GDI engines, lubricants might be an important source of IVD” |
blkonblk195.00 |
10-17-2022, 12:17 PM | #231 | ||
Rep 1,485
F87source7251.50 |
10-17-2022, 12:55 PM | #232 | |
Rep 1,485
Just bcs. you don't like what you reading, doesn't mean it is not correct. |
10-17-2022, 12:57 PM | #233 |
Rep 4,672
There was a good point about heavyweight oils a few pages ago. Today's tighter tolerances require us being more careful with the oil weight that gets used. I know most know this, but wanted to make sure that point didn't get glossed over. An old miata engine from the mid 90s is different than a modern BMW engine.
10-17-2022, 01:44 PM | #234 | |
Rep 1,485
Track/racing is that situation where rules can be bend bcs. specific products, more knowledgeable crowd etc. But, you are absolutely right. Miata from 90's can almost run on olive oil, as long as it is extra virgin. |
10-17-2022, 01:48 PM | #235 |
Rep 7,429
There's 2 types of people, those who are willing to learn and those who aren't. When you aren't willing to learn it doesn't matter how wrong you are, you'll always make excuses to cover it up.
edycol1501.50 |
10-17-2022, 02:37 PM | #236 | |
Rep 1,335
10-17-2022, 04:32 PM | #237 | ||
Rep 1,485
Also, we are talking about engines that were tested for the first time some 21 years ago. Industry is using these oils for some 25 years now. I would say, discussion part about their effectiveness is long over. |
10-17-2022, 04:47 PM | #238 | |
Rep 7,429
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 10-17-2022 at 04:57 PM.. |
edycol1501.50 |
10-17-2022, 05:19 PM | #239 | ||
Rep 1,335
With GDI i thought it refers to the new hyundai engines. Quote:
If i were god i wouldn't be here wasting time with a freaky who watches youtube videos of colored catch can in subaru. Last edited by Track/S; 10-17-2022 at 05:25 PM.. |
10-17-2022, 06:06 PM | #240 | |
Rep 7,429
Don't be so quick to judge a video based on the color of a "catch can" (again you're wrong it's an air oil separator - which is further proof that gasoline isn't the root cause of carbonization because it recycles the oil with fuel contamination back to the sump and sludging isn't an issue because the can is heated), OC turbo joe is an air craft technician and the quality of work he is able to do rivals that and even exceeds many shops. The parts he uses is also top of the line and incredibly well engineered, and the setup he has is the most elaborate air oil separator setup I've ever seen.
edycol1501.50 |
10-17-2022, 10:42 PM | #241 | |||
Rep 1,485
When we were developing VW504.00/507.00 oils we put more on engines just to develop oils. And we knew the problem as specification from VW required less IVD deposits. And for our internal purposes we measured difference between VW502.00 (Full SAPS), VW 505.01 (Mid-SAPS) and VW504.00/507.00 oil. |
10-17-2022, 11:48 PM | #242 |
Rep 1,485
Sulfated Ash in that oil is 1.32%, which is some of the highest level. It is consequence of extremely stout additive package that is also designed for track use. M1 in previous 0W40 version (blended until 11/2015) using so called VISOM base stocks, had issues with TBN retention. This version resolved that issue, but at price of increased Sulfated Ash. What is difference? Pennzoil Platinum Euro 5W40 has SA level at 1.13%. Castrol Edge 0W40 at 1.15%. So difference between Edge 0W40 and M1 is .17%. That is difference between Edge and Mid-SAPS requirements that are up to 1%. Obviously Mercedes, Porsche or VW think that it is ok to run this oil in GDI, but there is difference. I have VW also in garage, with EA888 engine, and regardless that I do have 15qt of M1 0W40FS on the shelf, I run M1 ESP 0W30 with VW504.00/507.00 approval. |
