M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > ♛ OFFICIAL ♛ HEX Tuning BMW ///M2 ECU Software Release
Closed Thread
      08-23-2017, 04:22 PM   #111
VF-Engineering
VF-Engineering's Avatar
1009
Drives: F82 M4
Originally Posted by arwin View Post
YESSSSS!!!
I like the sounds of that!
What happens if I have the MPE but try to go for the stage 2?
Stage TWO firmly requires aftermarket downpipes, which means the
MPE exhaust (with factory DP's) will only qualify you for Stage ONE.
The Stage TWO calibrations take advantage of the reduced back pressure
and subsequent lower EGT's in order to make more power in a safe and
reliable manner. Running a Stage TWO file without the proper hardware
setup can result in poor drivability and potential engine damage.
The benefit of OBDII Port Flashing / MAP Switching is that it's very easy
to upgrade when the time comes. It's a convenience feature that allows
for future upgrades without having to revisit a dealer.
      08-24-2017, 02:14 PM   #112
Orange fever
Orange fever's Avatar
Thailand
2351
On the comfort is like stock but when you use Sport+more throttle more response more faster. Not sure about sport I always skip to Sport Plus...Lol
Originally Posted by djacts View Post
Looking to eventually do a stage 2 tune and HEX seems to be the best option. I called the local shop here who is an approved dealer and asked what happens to the comfort, sport and sport + mode after the tune. They didn't really know and said that once tuned it probably just has one setting and the comfort, sport and sport+ have no variance anymore.
Is this true? Once tuned, does comfort, sport and sport+ do anything anymore?
Any insight would be greatly appreciated.
Also, asked if I got stage 1 done now, how much would be it to go up to a stage 2 after I got me dp and FMIC. They said full pop on price again for stage 2.
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged ///
F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87)
djacts60.00
      08-25-2017, 02:43 AM   #113
Smiley1175
Smiley1175's Avatar
283
So the Stage 1 & Stage 2 maps are standard OTS maps? I was told that the dealer does a custom tune. Is that not the case?
If I buy a Stage 1 map locally, can I then purchase Stage 2 from you guys direct (for $100)?
      08-25-2017, 11:55 AM   #114
VF-Engineering
1009
Drives: F82 M4
Yes, they can be described as "Off The Shelf" by the fact that the software
is pre-engineered, tested, and validated for distribution through any of our
Certified HEX Tuning Installers.
That being said, all of our current Stage Level software options see
significant in-house dyno and on-road testing and validation before
release; which comes with far more expertise and experience than
one could argue you'd get from a single custom tuning session.
That is correct as well. Once the ECU has been "unlocked" all flashing
or MAP switching functions are a process you can execute yourself.
When it's time to upgrade form Stage ONE to Stage TWO you can
purchase the file which will then be e-mailed to you.
      08-25-2017, 06:35 PM   #115
SloppyMitt
14
I can't decide on an exhaust and was thinking of just doing a catless downpipe with the stock exhaust. Would I still be able to do the stage two tune?
      08-25-2017, 07:57 PM   #116
NO_USER_
Drives: .
Yes.
      08-25-2017, 09:30 PM   #117
arwin
Drives: 2017 AW M2
Originally Posted by inline6ax View Post
Yes.
Didn't vf just say a few posts up that it needs an after market exhaust?
      08-25-2017, 09:37 PM   #118
NO_USER_
Drives: .
No. You just need an aftermarket downpipe whether it be catless or high flow catted (200 cell), stock exhaust is completely fine.
      08-25-2017, 09:59 PM   #119
arwin
Drives: 2017 AW M2
I've specifically asked this question to vf engineering before and their response was always that I needed an aftermarket exhaust.
Would like secondary clarification though
      08-25-2017, 10:03 PM   #120
NO_USER_
Drives: .
I had the stock exhaust with the VF Stage 2 tune...
I'm sure VF can confirm too.
      08-26-2017, 07:31 AM   #121
velociti
Drives: 2009 E90 M3
When most people hear exhaust, they usually think of a cat-back, but a downpipe is part of the exhaust "stage." Aftermarket exhausts are really no less restrictive in terms of back pressure / exhaust flow than stock. But trading the stock downpipe for one with a high-flow cat, or no cat at all, allows for decreased back pressure / increased flow. Tuners can take advantage of this by having boost levels taper less quickly at higher RPMs since there's less load on the turbo and motor. If you ran VF's Stage 2 map with the stock downpipe, you likely wouldn't cause any immediate damage, but the increased heat levels and stress on the turbo itself would definitely shorten its lifespan. Bottom line, you only need to upgrade your downpipe for VF's Stage 2 tune. This is supported by the very first post in this thread and the fact that the Stage 2 dyno plot was done with the stock cat-back and an ER downpipe.
geogerf115.50
arwin132.50
D CHOI581.00
      10-03-2017, 04:27 PM   #122
emargul
emargul's Avatar
Drives: M3
I was told by VF that a high flow cat like Fabspeed won’t do for stage 2 and it needs to be a catless downpipe. Anybody running stage 2 with high flow cats?
      10-03-2017, 05:39 PM   #123
RPM2-85
Drives: 2017 M2 AW
I am, with an intercooler.
      10-04-2017, 10:42 AM   #124
emargul
emargul's Avatar
Drives: M3
Thanks! And I’m assuming no issues?
I wonder why I was told I needed a catless dp.
      10-04-2017, 01:56 PM   #125
Orange fever
Thailand
2351
Maybe to get more out of it, the tune
      10-04-2017, 08:28 PM   #126
velociti
Drives: 2009 E90 M3
I'd bet because they did the tune with a catless downpipe and don't want to be on the hook for anyone who has issues running a catted one. Easy out for them. Honestly can't imagine it'd be an issue for a daily driver. For a tracked car, though...maybe not ideal.
      10-18-2017, 11:19 PM   #127
Archie Bunker
Originally Posted by raysspl View Post
Can we opt out of the GTS style startup roar & throttle burble?
Originally Posted by VF-Engineering View Post
Yes, you sure can.
Just keep in mind that if you want to add it back later, it's a separate performance
file which will cost $100.
Is it possible to have the GTS startup roar but NOT the GTS throttle burble with a stage 2 flash?
      10-19-2017, 07:13 PM   #128
VF-Engineering
1009
Drives: F82 M4
Yes, that is possible.
You'll just make that request at the time of purchase
and the tuned file will be created with no "burble".
      10-20-2017, 03:01 PM   #129
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
is there a way to have the burble adjusted? Meaning length and aggression?
      10-20-2017, 03:03 PM   #130
Supadice
Supadice's Avatar
1028
Drives: 2020 M2CS
Is there a way to have the burble adjusted? Meaning length and aggression?
      10-20-2017, 06:01 PM   #131
VF-Engineering
1009
Drives: F82 M4
Yes there is, by selecting the different drive modes, the "burble"
duration and aggression will change.
Efficient = No burble. Sport = Mild burble. Sport + = High-burble.
There are quite a few factors that influence the "burble" sound
quality, both from the calibration strategy we use, as well as the
physical arrangement of the exhaust system itself.
Cars with aftermarket down-pipes and resonator delete will be much
more aggressive sounding with sharper "pops" and "bangs". Cars
with factory downpipes will be more mild and controlled sounding.
Example: Stock Exhaust - Stage ONE Software
Example: Stock Exhaust - Stage TWO Software
Both of those vehicles have identical calibration strategies for the
throttle overrun (aka: burble). The only difference is the exhaust
configuration.
      10-20-2017, 09:01 PM   #132
RPM2-85
Drives: 2017 M2 AW
My stage two setup is a beast. Absolutely love it guys.
Closed Thread
