03-29-2021, 06:55 AM | #1 |
Rep 1,591
BM3 Stage 2 Logs
In light of reading through a few threads on here about the extremely rare blown M2 motors the recurring comment was always "log your car" after a tune. While I'm not new to modding or tuning, I am also not a tuner so I'd like to share these logs and see what input more experienced people than I have to say.
Car is a 2016 M2 DCT with 58k AA Catted DP, AA Chargepipe, CSF FMIC, Shell V Power 93 BM3 Stage 2 93 OTS tune From my look things seem pretty good, no boost leaks, no recorded knock although it seems some timing was pulled but for an OTS it seems good and safe. No fuel pump issues either. I am thinking of going the custom tune route in the future but would do so after my hardware is 100% and before I get further I want to make sure everything is good and safe, especially given the mileage. Car has only been tuned for a few hundred miles and plugs are OEM with about 25k on them. Thanks in advance I ran 3 logs almost back to back the other day when it was about 55 degrees or so. https://www.bootmod3.net/log?id=605f...90c67d4e5b153b https://www.bootmod3.net/log?id=605f...90c67d4e5b153a https://www.bootmod3.net/log?id=605f...729b4128b08e9c |
03-29-2021, 10:56 AM | #2 |
Rep 259
your fuel could be better. in your last log, you did in fact have knock at the upper rpm with timing being pulled in 2 cylinders. if you could add a splash of ethanol and that may clean up your timing. im running the same map as you are with similar IAT/temps but i have ethanol in my tank and my timing is equal and no knock in all cylinders with timing advance up to 11.5 at 6500 rpm. although its interesting youre not overboosting on tip in like i am and your boost takes a while to build up before it hits target. so i dunno what is going on there. someone with more knowledge can chime in.
03-29-2021, 11:24 AM | #3 | |
Rep 1,591
03-29-2021, 11:35 AM | #4 |
Rep 259
yeah it looked definitely fuel related. i had to add 5 gallons of ethanol to make the map work. although may be a bit too much tbh but if its working i cant complain lol.
