12-06-2020, 09:31 AM | #1 |
Rep 4,049
Rubbing
I thought I'd put this in technical but its slow there. I put on 437s with winters yesterday, and notice some rubbing up front almost immediately as I pulled out of the garage. Tried to replicate it this morning and it happens only at slow (crawl) speed while a bit past half turn. So like pulling out of a parking spot while turning out. I took a picture and confirmed the tire rubbed against the front part of the fender liner. So, I went from the stock 245s to 255/35/19 Pirelli Sottezeros. This is not a lot wider than stock so what gives? Did I do something wrong?
Thoughts and advice appreciated |
12-06-2020, 09:39 AM | #2 |
6643
Rep 4,145
Drives: '18 M2 6MT
That is weird. Compared to the stock PSS it's actually .5 skinnier, and only .2 taller (only .1 of that is on the top side). I'm guessing it's down to the shape of the tire.
Still weird. I would not have believed these tires would rub at all. Sure you didn't get a 255/40? |
BigKutta3910.50 |
12-06-2020, 09:49 AM | #4 |
Rep 4,554
Drives: 2015 328d xDrive
Known issue. M2C has a different front-liner than the OG (because of the difference in cooling hardware maybe) and doesn't accommodate as much tire. Some people have heated the contact area up with a heat gun and then pushed it inwards and poured cold water on it immediately after to push/bend it away from the wheels. That seems to be the most elegant workaround:
https://f87.bimmerpost.com/forums/sh...4&postcount=33 |
12-06-2020, 10:03 AM | #5 | |
Rep 4,049
VisualEcho6642.50 |
12-06-2020, 10:05 AM | #6 |
Rep 4,049
12-06-2020, 11:03 AM | #7 | |
6643
Rep 4,145
Drives: '18 M2 6MT
12-06-2020, 11:07 AM | #8 |
Rep 4,049
So this may take us down a technical path, but now that my OEM 788s with PSS are sitting off to the side, i do notice the fronts are not as tall as the rears with tires mounted, much more so that the 437s with Pirellis (difference was slightly less between rears and fronts). Sorry if this is a stupid questions but could it be that the rim sizes different in our OEM setup versus the 437s I installed?
12-06-2020, 11:30 AM | #9 | |
Rep 4,554
BigKutta3910.50 NYC Bimmer259.50 |
12-06-2020, 11:35 AM | #10 | |
6643
Rep 4,145
Drives: '18 M2 6MT
OEM OD specs are 25.8/26.3, so you should see the difference visually. |
BigKutta3910.50 |
12-06-2020, 11:46 AM | #11 | ||
Luxury at the redline :)
9108
Rep 7,563
BigKutta3910.50 |
12-06-2020, 12:37 PM | #12 |
6643
Rep 4,145
Drives: '18 M2 6MT
12-06-2020, 01:03 PM | #13 | |
Rep 1,602
12-06-2020, 01:05 PM | #14 |
Rep 4,554
Wheels were identical, just came with 255/275 tires instead of 245/265
Poochie9107.50 NYC Bimmer259.50 |
12-06-2020, 01:17 PM | #15 | ||
Rep 4,049
Moflow2484.50 |
12-06-2020, 01:31 PM | #16 | |||
9108
Rep 7,563
Regardless, smart and responsible choice in opting for bonafide winter rubbers, instead of just winging it with the stock summer tires. I just SMH 🤦 when I hear folks ignorantly brag about getting by fine, in winter, on summer wheel. I'm like; 'Oh, so you must one of folks that Darwin refers to..' |
///AVM2531.00 |
12-06-2020, 01:45 PM | #17 | |
2531
Rep 1,908
I feel like I just participated in psychiatric experiment and failed. . . I watched the entire 3:02 of your video . . . thinking the Jeep would magically grow snow shoes by the end. ///AVM |
12-06-2020, 01:56 PM | #18 | ||
9108
Rep 7,563
If it's not you're daily driver and you barely drive it in the winter, then you can chance it and leave on the summer tires but one should invest in season-appropriate rubber, if it's driven frequently in winter weather. I mean, it's right there in the name; "summer" or "winter" tires, that's not there for style. But I guess if a person can't use the common sense approach, that a powerful, RWD, with already limited traction vehicle requires the proper tire, then they'll just have to learn the hard way. |
///AVM2531.00 |
12-06-2020, 02:08 PM | #20 |
Rep 4,049
12-06-2020, 02:11 PM | #21 | ||||
Rep 4,049
12-06-2020, 02:19 PM | #22 | |
2531
Rep 1,908
If you had bought from unknown seller (e.g., eBay), then I would question authenticity and size of the wheels . . . which could explain the fitment mystery. Anyway, you seem to have bought from a trustworthy seller. . . wonder where he bought the wheels? ///AVM |
