M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Getting Ready for Stage 2
      12-21-2019, 11:11 AM   #23
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Originally Posted by MZWIE View Post
I looked in my car at the OEM charge pipe. About half way down it is attached to a hard mount.
I do not see this in any of the pictures of the aftermarket versions. I haven't seen this in any videos of installations either????????
After Market Charge Pipes do not use this press fit connection. It is only for the cheap OEM Pipe.
At a Point above 7,000 RPM.
      12-22-2019, 01:11 AM   #24
5678
Originally Posted by digimattic View Post
Thanks to everyone who has provided their experience. Based on everyone above, my shopping list appears to consist of the following:
  • Wagner Evo II Competition FMIC
  • NGK SILZKBR8D8S spark plugs BMW oem part no 12120039664
  • FTP Charge and boost pipes
  • Pure Turbos turbo inlet pipe
Any issues with the parts listed above? Will everything play nice together?
That’s pretty much my stage 2 shopping list. I’m still not 100% on the spark plugs though. I can’t see anything conclusive about if they are required or not.
      12-22-2019, 01:17 PM   #25
digimattic
digimattic's Avatar
37
Drives: 2017 6MT LBB M2
My understanding from other cars is that you should go a step cooler for every 70-100 HP added. Doing so will keep head temps within an acceptable range and prevent knock. I expect that being full bolt on, with a tune will easily add 70-100 HP, so it's something I will do for piece of mind
      12-22-2019, 03:04 PM   #26
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Is that the part number for the stock M2 plugs? If so then you're good to go.
(Too lazy to punch it into google myself lol)
      12-22-2019, 05:01 PM   #27
digimattic
digimattic's Avatar
37
No, they are a step cooler than stock.
      12-22-2019, 05:43 PM   #28
Anthony1s
756
Drives: 2018 Mineral Grey M2
So that part number I believe is the hotter plug, because RealOEM shows it listed for non-M cars.
https://www.realoem.com/bmw/enUS/partxref?q=12120039664
The colder plug, I'm assuming is this one. Which comes as OEM in the M2.
https://www.realoem.com/bmw/enUS/par...&q=12120039634
But I really have no way to know for sure. I haven't seen a spec sheet for each plug... Though it doesn't make sense, maybe the lesser models use a colder plug than the M cars. But I am also going off the tech specs released for the M2 saying that the M2 N55 uses the colder plug from the S55.
With that said, I advise against running a colder plug for Stg2 tune. Because not a single person has shown a log of it being needed and BM3 doesn't recommend changing plugs. Running a colder plug than needed will make the car run worse.
Edit I stand corrected. Here are BM3's recommendations...
https://bootmod3.atlassian.net/wiki/...+and+which+gap
https://f80.bimmerpost.com/forums/sh...7&postcount=28
      12-22-2019, 06:09 PM   #29
///Monika
Drives: '18 X3 M40i & '18 M2
https://www.jordan-tuned.com/faq
      12-22-2019, 06:33 PM   #30
digimattic
digimattic's Avatar
37
Good information, thanks. My car still only has 7k kms on it, so maybe I'll just gap down the plugs and go from there.
