08-16-2023, 10:43 AM | #375 |
Rep 3,695
I don't think any of the aftermarket intakes for the M2 have shown any gains in power. As for IATs, most of the options are open/semi-open under hood, except for the one you posted. I remembered seeing at the time thinking it'd be good for IATs, but cringed b/c it scared me about reduced airflow to the radiator.
We're still trying to figure out how much of an issue airflow is for engine cooling vs certain hardware upgrades, but in the meantime I'm running the stock intake with the aFe inlet scoop via F87source recommendation to get a little more cooler nose air into the intake tract. |
F87source7251.50 |
08-16-2023, 10:52 AM | #376 | |
Rep 4,146
I still may sell my intake and scoop (too bad I gave away my Stock and M2 box/filter) and grab one. I have posted in the MILVS thread, I can get IATs as low as ambient - 5F when cold, and regularly within < 15F during daily driving. Part of that is the intercooler, but I did note the IAT improvements with my previous intercooler. I'll also note, my WGDC is lower than most other users at the same given boost level - I posted about it in M2guru thread. It's uncommon I see over 90% at any given time.
Mods: Yes.
08-16-2023, 06:56 PM | #377 | |
Rep 7,429
If you don't need it to be done controlled you can have it like ZM2 where it turns on with the ignition.
08-16-2023, 06:59 PM | #378 |
Rep 7,429
I'd rather do water injection at this point rather than get a larger intercooler. And if you add ice cubes to the water you will probably get below ambient iats.
08-16-2023, 08:20 PM | #379 |
Rep 4,146
Mods: Yes.
08-16-2023, 08:27 PM | #380 | |
Rep 7,429
08-16-2023, 08:30 PM | #381 | |
Rep 3,695
F87source has put some thought into it with me, but we wanted to try most all other options first. |
F87source7251.50 |
08-16-2023, 08:45 PM | #382 | |
Rep 7,429
But yes, the question is how to retain the heat exchanger.
08-17-2023, 06:51 PM | #383 |
Rep 4,146
RealOEM and BMW say that the pump is present on the M2. Anyhow, separating the coolant and oil seems like the next and best step. No reason to have them together.
08-17-2023, 07:23 PM | #384 | |
Rep 7,429
If it were there, then ZM2's shop would have spotted it when they retrofitted him an e39 aux water pump. There is a purpose of retaining the heat exchanger, in the summer it acts to help cool the oil temps when the car is stationary in traffic because there will not be flow through the oil cooler. In the winter it will help heat the oil up using coolant temp. You can notice this working because despite the oil thermostat being completely mechanical, the car can control oil temps via the coolant thermostat. For example if it is cold outside and your oil temps are 100C or more, you'd expect the oil thermostat to be open and the oil temps to drop. But no, the oil temps stay stable. I suspect because the DME is controlling coolant temps (which it does do based on ambient temp) and keeping the thermostat shut, the heat exchanger is now using that 100C coolant temp to warm the oil up.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 08-17-2023 at 07:28 PM.. |
08-18-2023, 05:17 PM | #385 |
Rep 573
d088 oil cooler installed. Still not sure how people can replace the oil cooler without removing the headlight. Both times, I feel like I had no option. Removing the headlight may add time, but it adds ease.
Here are the differences between the d088, csf, and stock oil coolers. Also, a photo of how I modified the fender liner - it didn't make sense to add a big cooler to only have the larger size blocked on the back side by the liner. |
08-18-2023, 10:39 PM | #386 | |
Rep 4,146
08-18-2023, 10:43 PM | #387 |
Rep 7,429
I wouldn't suspect there to be any change from street use because the oil thermostat needs to be keeping oil temps in check.
08-18-2023, 11:01 PM | #388 |
Rep 4,146
08-18-2023, 11:32 PM | #389 | |
Rep 7,429
So I'm not sure you would see too much of a decrease in absolute temps. Plus the heat exchanger does a good job keeping temps consistent by helping cool the oil when the oil temps exceed coolant temps.
08-19-2023, 07:56 AM | #390 | |
Rep 4,146
But to the second point, another user recorded lower temps (stock thermostat) with the oil cooler on normal driving. I was curious if it was that efficient. But the issue everyone has been running into is using that coolant to cool the oil and not having an efficient enough cooler that can do the work on its own. |
08-19-2023, 02:31 PM | #391 | |
Rep 7,429
What car was the one you said saw drops in oil temps with an upgraded cooler? It could absolutely happen if the oil temps were way above the cars ability to control oil temps with the heat exchanger + stock oil cooler (if they even had one, so this is more likely observed in cars without the oil cooler).
08-19-2023, 03:13 PM | #392 | |
Rep 4,146
08-19-2023, 03:49 PM | #393 |
Rep 7,429
That's interesting, very interesting.
08-19-2023, 06:25 PM | #395 | |
Rep 573
08-19-2023, 07:23 PM | #396 | |
Rep 7,429
Do you have any before logs? Because it might not be too helpful without those.
