04-06-2023, 02:41 PM | #1 |
Rep 17
Oil temperature not getting hot!!!
Hi,
New to the forum and just picked up an M2 LCI. Found the oil temperature gauge and it really struggles to get to temperature. Whether it be the oil itself struggling to get to temperature or the sensor is dodgy I don't know? Can anyone shed any light as I can only find threads for oil getting too hot!!! Have found in sport/sport + in particular it keeps the temp right down at the bottom of the gauge and in comfort it moves very slowly towards the centre... but it's never got there or even close! Please help!
04-06-2023, 02:46 PM | #2 |
Rep 267
make sure you warm up the car in comfort mode, sport and sport + make the oil cooler run so it takes longer to get to temp. if it isn't up to temp in comfort mode after about 15-20 min take it in to a local shop.
04-06-2023, 03:14 PM | #3 |
Rep 393
Mine hits about 90 after 15 mins of warmup in comfort, then i switch to sport and the temp will somewhere around 95c - 105c for the rest of the drive. If i forget and leave it in comfort, it'll end up much closes to 120c. If yours isn't going much higher than 80, there's a problem somewhere.
04-07-2023, 01:54 PM | #4 |
Rep 180
Drives: 2017 BMW M2
Is this an lci only feature or can I get to that info on my og as well?
04-07-2023, 03:51 PM | #5 |
The Seeker
14175
Rep 3,422
04-07-2023, 04:04 PM | #6 | |
Rep 7,539
So it looks like this: Credit: https://f87.bimmerpost.com/forums/sh...04&postcount=7
BadgerDog197.00 imperfectluck434.00 |
04-07-2023, 04:30 PM | #7 | |
Rep 180
Drives: 2017 BMW M2
F87source7367.00 |
04-07-2023, 04:58 PM | #8 | |
The Seeker
14175
Rep 3,422
And it's universal that the oil needs to be 180° before you really run the car hard, yet there is no 180° line that's clearly shown. Total letdown. |
04-07-2023, 05:12 PM | #9 | |
Rep 180
Drives: 2017 BMW M2
04-07-2023, 05:19 PM | #10 | |
Rep 7,539
///MPhatic14174.50 |
04-07-2023, 05:33 PM | #11 |
The Seeker
14175
Rep 3,422
Mine doesn't have a center line since it's an '18. I can calculate where 180° is, but IMO it's BMW's responsibility to make it very clear when it's safe to drive the car hard. And why it goes to 340° F is anybody's guess.
F87source7367.00 |
04-07-2023, 05:41 PM | #12 | |
Rep 7,539
Pesonally I don't look at the dash guages, I only look at my tablet guages which gets data directly from the canbus network.
04-07-2023, 05:45 PM | #13 |
Rep 7,539
Yeah it's a combined guage, because even when coolant is at operating temp or above if the oil temp isn't good this guage will not be at the middle. I have monitored it on my tablet to verify this.
04-07-2023, 07:37 PM | #14 |
The Seeker
14175
Rep 3,422
I have considered getting a dedicated oil temp gauge, as it's the only one I really need, but don't want to lose my air vent to do it.
ThatBlueM24.50 |
04-07-2023, 08:35 PM | #15 | |
Rep 1,972
Edit: Looks like the v2 only shows water temp in diesel cars, odd. I liked having them both in my E82, even though I only looked at oil temp. To get oil temp in an pre-LCI OG, another option is to install new gauge cluster (from LCI or M2C) and have it coded: https://f87.bimmerpost.com/forums/sh...6&postcount=48 I have the cluster but didn't get it coded since I have the P3 gauge on oil temp always. |
04-07-2023, 09:00 PM | #16 |
Rep 435
Drives: F87 M2 DCT, F15 X5
When the engine calibration is in Sport, it targets a lower coolant temperature. It may also do something similar with the oil cooler control valve. The oil circuit is thermostatically controlled. 70-80c oil temp is perfectly fine, especially if it’s only 9c out. My C6Z would sit around 60C oil temp on the highway when it was 9C outside. But that oil cooler ran wide open all the time.
04-08-2023, 07:22 AM | #17 | ||
The Seeker
14175
Rep 3,422
My Lotus has trouble getting the oil warm at times as well, which is why some cars have cam issues. 180°F is still the benchmark, even in freezing temps. |
04-08-2023, 06:41 PM | #18 |
Rep 17
Turned off max cooling mode in BM3 (previous owner must have ticked it) and still struggling to get over 85 degrees c oil temperature! Got to 90 a few times in traffic... maybe need to accept this is what the car likes and drives absolutely fine with no stored codes etc and coolant warms up pretty quick!
04-08-2023, 07:15 PM | #19 |
Rep 7,539
if you have a used car, make sure the previous owner didn't delete the oil thermostat.
chris7197393.50 |
04-08-2023, 08:51 PM | #20 |
Rep 435
Are you able to look at target coolant temp with that app? I can see it in BimmerLink app. It changes whether the engine is in sport or comfort calibration
04-09-2023, 12:49 PM | #21 | |
Rep 4,216
This brand has fallen off hard. I’m still angry that I don’t have an oil temp gauge on my M235i. |
04-09-2023, 08:40 PM | #22 | |
The Seeker
14175
Rep 3,422
The N55/S55 engines should not go past 3K rpm's until 180° or it'll have massively accelerated wear. |
F87source7367.00 |
